    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
      Yes, better documentation is indeed in need - as well as improving the tools. But docs are on the top of my list when I get home from my travels next week.
      I plan to set up a new site for QFT - move away from the BitBucket wiki.
      Better text and visuals describing the various features of QFT. GIFs to illustrate common topology pattern.
      And extend SUbD's site to include more examples of how various topology patterns subdivide.
        cuttingedge
        I was thrilled by the panton chair example shared by Ithil3d on youtube. I thought I'll build one trying slightly different method. A good few minutes and here's what i got.
        model
        test render
        • HornOxxH Offline
          HornOxx
          @cuttingedge said:
          ... I thought I'll build one trying slightly different method. A good few minutes and here's what i got...
          This is a very good SubD example!
          how often and unsuccessfully I tried exactly this chair πŸ˜›
          never trust a skinny cook
            Yes the difficulty with Subdivision modeling against the Nurbs modeling where you have yet all the curves of the model, is to imagine the "rustic" cubic form before it's transformation! πŸ˜„
            https://s-media-cache-ak0.pinimg.com/236x/1a/d5/a5/1ad5a5b1e29b783619d44f7751f6c285.jpg
              miikka1978
              Is there any plugin working like Blender's Add Loop cut, see link below? I think that this would be really useful when using SubD.
              https://www.blender.org/manual/modeling/meshes/editing/subdividing/loop_subdivide.html
              https://www.youtube.com/watch?v=_f4XKe8lZEU
              • ely862meE Offline
                ely862me
                If you look back a little you will see that we talk about that too, it's called Quad face tools, you can find it in the plugins library.
                Elisei (sketchupper)
                Come and See EliseiDesign
                • HornOxxH Offline
                  HornOxx
                  ...completed the wing to a plane - certainly not a beauty πŸ˜•
                  plane4_proxy.skp
                  • JQLJ Offline
                    JQL
                    Not bad either... but it was a very promising wing
                    www.casca.pt
                    Visit us on facebook!
                    • HornOxxH Offline
                      HornOxx
                      @jql said:
                      ... but it was a very promising wing...
                      thanks
                      πŸ˜† ok - give this wing an other try
                        Yet a charm certain! πŸ˜‰
                        • StinkieS Offline
                          Stinkie
                          @thomthom said:
                          There are talks going on with various render engines to allow for them to render high-poly variants from the low-polys.
                          Nice! πŸ‘
                          • O Offline
                            optimaforever
                            In the same order of idea, can you thomthom develop a quadchamfer4SU?
                            Ideally it would be a mix between the editability of SubD and the easiness of RoundCorner...
                            Roundcorner is good but it doesn't allow for editing. I have to keep a non-chamfered version in a temp layer if I need to edit it again. And SubD need manually offsetted lines to control the distance of chamfering. On complex models, it can quicky become a time-consuming burden, just to create chamfered edges, not to mention the file size and the memory footprint.
                            This TTQuadchamfer would be a quick 3D chamfer/fillet tool that automatically creates the needed lines offsets according to pre-entered parameters, which in return could allow easy re-editing, should the need arise. And afterward, one could tweak the fillet values edge by edge for more flexibility.
                            What do you think?
                              Got some visuals to illustrate expected result?
                              • O Offline
                                optimaforever
                                Have you seen http://www.mariussilaghi.com/products/quad-chamfer ?
                                • gillesG Offline
                                  gilles
                                  Streamliner, based on Norman E. Timbs 48 buick.
                                  • JQLJ Offline
                                    JQL
                                    What do you think?
                                    Actually I'm simply not using SubD, because it would be the most fun plugin I'd have, but it's not really useful for what I need right now. I would have yet another toy to have fun with and deviate my attention for what I do for a living... I must resist...
                                    If you'd do it, it would be extremelly useful if you'd integrate it with SubD methodology and chamfer it only when subdividing, keeping UV's, allowing for creases worflow to be integrated too and, probably integrate it in the rendering workflow too.
                                    I didn't know it yet but if SubD would be able to produce that, it would turn into the most useful toy an architect that deals with archviz needs apart from the renderers themselves.
                                    Thanks for that feature request Optimaforever, I really hope Thomthom pulls that one off!
                                    www.casca.pt
                                      @: Gilles where is the model ? πŸ˜‰
                                      Inspiration Vrooum, vrooum! πŸ’š
                                      car_v6.zip
                                      • gillesG Offline
                                        gilles
                                        [attachment=2:2ruqdqif]<!-- ia2 -->blobcar.jpg<!-- ia2 -->[/attachment:2ruqdqif]
                                        STREAMLINER.skp
                                        • StinkieS Offline
                                          Stinkie
                                          Oooh, it'd be great to have that in SU.
                                          • O Offline
                                            optimaforever
                                            Indeed, my next request would be that the quad chamfer only applies when rendering, a bit alla Skatter-way, with the "render only" option.
                                            I don't know if it's in the pipeline but I guess that having the SUbD not visible when working and only visible during rendertime would be an equally useful feature. A kind of general SUbD toggle on/off in the SUbD preferences. The thing is, there is always an SUbD object on which I forget to apply the subdivision before pushing on the render button (lazy me), and having a "all subd on when rendering" toggle button would save my ass for sure 🀒
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 82
                                            • 83
                                            • 47 / 83
