    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 74.1k Views 55 Watching
    • ntxdaveN Offline
      ntxdave
      @massimo said:
      @ntxdave said:
      BTW: Someone enlighten me what I did wrong with my attempt to include the YouTube video.
      Just erase the "s" from "https".
      I embedded it for you.
      Thanks - I appreciate that so that I can do it in the future.
      For those viewing the animation, please notice how smooth it is. In the original animation posted by Fredo, also notice that while his SU model has multiple scenes, the animation appears to be taking place in a single scene. Think about that.....
      Wouldn't it be wonderful if these types of animations could be included in things like Lumion, LumenRT and Twinmotion. We are heading toward the ability to show off products in an environment something like a video game.
      • soloS Offline
        It is possible in Lumion.
        • ntxdaveN Offline
          ntxdave
          When I looked at the animation capabilities in Lumion, it said (at least what I remember) was that you could not do subcomponents. Therefore if I had parts that I wanted to animate at two levels (like the first brush that both spins and pivots on an arm) you could not do that (at least that was my understanding). It would be great if we could do the basic animations within SU and then import them into those products and take advantage of their rendering and other capabilities.
          • soloS Offline
            It would be fantastic if this animation could be exported to a 3rd party animation app as .fbx, will not hold my breath however, In lumion to create this you would have to import all moving components separately however, can become very fiddly.
            I hope that this animation gets supported by the SU integrated render engines like Twilight, Thea, Podium, Corona, Vray, etc.
            • chriC Offline
              chri
              Hi Fredo
              Many Thanks for this new plugin.
              I think that the movement is done by the timeline .
              Is it possible to combine 2 movements like following examples from SKETCHYPHYSICS ?
              in french
              Il me semble avoir compris que la "timeline" commande les mouvements
              Est-il possible de combiner des mouvements pour qu'une pièce en pilote une deuxième , comme dans les exemples SKETCHYPHYSICS ?.
              Bye
              Chri
              FOURBAR.skp
              CAME+TRANSLATION.skp
              CAME+ROTATION.skp
              ROTATION+ROTATION.skp
              • PixeroP Offline
                Pixero
                I really hope it will be possible with ease in and out and not just linear interpolation between key frames.
                • fredo6F Offline
                  @Pilou and chri
                  Animator is purely based on kinematics, not physics. In addition, Animation is predictive, as you specify the movements, whereas Physics will dynamically calculate the movements based on physical laws (weight, collisions, ...).
                  Therefore the purpose is very different, one is for illustrating, the other for playing or simulating.
                  Animator should however include a Visit Controller mode, where you can animate the sequences individually.
                  • fredo6F Offline
                    I plan to include Easing hopefully. You can see it in the video of the first post (look at Homer or some small cubes, which move with acceleration).
                    • PixeroP Offline
                      Pixero
                      Another wish.
                      Perhaps for a later version, would be a curve editor for those who wish more precise control over animation.
                      • PixeroP Offline
                        Pixero
                        ...and another one...
                        A way of retiming a animation "clip" by making it longer or shorter.
                        • fredo6F Offline
                          Actually you can adjust the duration and start time of each element of a clip.
                          You can also play the animation with variable speed.
                          See at the end of the video, where I used a model provided by chri.
                          • soloS Offline
                            That is very cool, I like the control one has.
                            Will we be able to include section cuts and hide/show layers?
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              Can I kiss you?
                                So seems we will be to make that? 😎
                                And this plugin by Cplassais will be very useful for put easilly some pieces! 😎
                                • alsomarA Offline
                                  alsomar Extension Creator
                                  Looks really great, thank you!
                                  Alejandro Soriano Visuals · All my links
                                  • PixeroP Offline
                                    Pixero
                                    Could you explain how to set up hierarchies?
                                    Does it come from how objects are grouped inside other groups, or can you set it up independently through some hierarchy building function?
                                    Will it be possible with inverse kinematics as well as forward kinematics?
                                    • PatrickP Offline
                                      Patrick
                                      Hello..
                                      I have this model...
                                      Formes béton.skp
                                      See explain in french Forum : http://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=64057#p587158
                                      Bye
                                      Patrick
                                        Can you animate instances within other instances?
                                        • ntxdaveN Offline
                                          ntxdave
                                          Not sure if this is what you are asking but in my car wash model, there are goups & components within groups and components. As an example, if you look at the first spinning brush, it is a subcomponent of the brush/arm assembly which is also a component. There are multiple things like that in the car wash animation.
                                          So, if I am correctly understanding your question, the answer is yes.
                                          • F Offline
                                            faust07
                                            Great! I could post a 2,400-year-old tricycle with driver when BryanK (the designer) does not mind. You could convert it from SketchyPhysics into your parametric animation process.
                                            SketchyPhysics test
                                            • 11
                                            • 12
                                            • 4 / 12
