    Animator: Parametric Animation plugin - Discussion
    249 Posts 56 Posters 144.8k Views 55 Watching
    • PixeroP
      Pixero
      ...and another one...
      A way of retiming a animation "clip" by making it longer or shorter.
      • fredo6F
        Actually you can adjust the duration and start time of each element of a clip.
        You can also play the animation with variable speed.
        See at the end of the video, where I used a model provided by chri.
        • soloS
          That is very cool, I like the control one has.
          Will we be able to include section cuts and hide/show layers?
          • jiminy-billy-bobJ
            jiminy-billy-bob
            @fredo6 said:
            I plan to include Easing hopefully.
            Can I kiss you?
              So seems we will be to make that? 😎
              And this plugin by Cplassais will be very useful for put easilly some pieces! 😎
              • alsomarA
                alsomar Extension Creator
                Looks really great, thank you!
                Alejandro Soriano Visuals · All my links
                • PixeroP
                  Pixero
                  Could you explain how to set up hierarchies?
                  Does it come from how objects are grouped inside other groups, or can you set it up independently through some hierarchy building function?
                  Will it be possible with inverse kinematics as well as forward kinematics?
                  • PatrickP
                    Patrick
                    Hello..
                    I have this model...
                    Formes béton.skp
                    See explain in french Forum : http://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=64057#p587158
                    Bye
                    Patrick
                    La CAO sans se casser la tĂȘte ? FreeCAO la CAO toute en vidĂ©o.
                      Can you animate instances within other instances?
                      • ntxdaveN
                        ntxdave
                        Not sure if this is what you are asking but in my car wash model, there are goups & components within groups and components. As an example, if you look at the first spinning brush, it is a subcomponent of the brush/arm assembly which is also a component. There are multiple things like that in the car wash animation.
                        So, if I am correctly understanding your question, the answer is yes.
                        Press F1...thank me later
                        • F
                          faust07
                          Great! I could post a 2,400-year-old tricycle with driver when BryanK (the designer) does not mind. You could convert it from SketchyPhysics into your parametric animation process.
                          SketchyPhysics test
                            @solo said:
                            I hope that this animation gets supported by the SU integrated render engines like Twilight, Thea, Podium, Corona, Vray, etc.
                            Ditto! I know they'd be very interested.
                            • ntxdaveN
                              ntxdave
                              I know this is pushing it but I would also like for it to be supported by one of the extensions that support exporting the model to WebGL.
                              Imagine being able to show you model on a web page with no plugin that included object animations.
                              • fredo6F
                                Answer is Yes.
                                Actually, grouping component instances and groups helps transform several objects at once, instead of selecting each of them (even if multi-selection is also supported).
                                But you can individually move an object within a group.
                                In the Car Wash example, the whole car is translated as a group, including the wheels, and the wheels are transformed by spin individually.
                                • fredo6F
                                  I tentatively built an API for acting externally on the animation, so that a rendering software can drive the animation frame by frame.
                                  Animator - API for Renderers - v1.pdf
                                  I am in contact with tomasz for Thea.
                                  But I don't know how to reach the others
                                  • fredo6F
                                    That would be a good feature, not just for animation.
                                    I'll have to explore WebGL to understand what it is about and if it is applicable in the case of an animation.
                                    I know Tak2hata has released a plugin doing WebGL export, so he is probably the best expert to contact.
                                    • soloS
                                      So when can we play?
                                      Planning a beta team?
                                      • O
                                        otb designworks
                                        Re beta test team: Pick Me Pick Me!!!
                                        I am more excited for this plugin than anything I have seen come out of the official team since they gave us Layout!
                                        Cheers, Chuck
                                        OTB Designworks is on Youtube
                                          PM me who you are looking for - I'll see what I can do. I have the ChaosGroup contacts for sure - but I should be able to obtain other as well.
                                          • soloS
                                            I have had so many issues in the past with the available tools/plugins, that is why this is a huge thing.
                                            See video below, a recent attempt to use SU and Thea, It failed and i needed to finally go into Thea studio to complete animation. I also needed to have layers animate, so I could show and hide panels, will it be possible with this plugin?
                                            • 12
                                            • 13
                                            • 2 / 13
