    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • W Offline
      witjazz
      thanks
      • Y Offline
        yaseerr
        like it thank you
        • fredo6F Offline
          NEW RELEASE 1.7a - 19 Oct 2014
          This release is required for SU 2014 when your username contains non-ascii characters
          Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
          Download new release at main post
          • W Offline
            WebBeau
            Thanks a lot
            • E Offline
              Esense3d
              Hello Fredo
              I would like to translate this plugin on all German but can not find language files
              Bezier spline is only partially translated
              Fredo I now have this new address
              Roland F Swiss
              • fredo6F Offline
                @esense3d said:
                Hello Fredo
                Roland F Swiss
                Thanks for this proposal.
                BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                Anyway, the current version already includes a German translation.
                • E Offline
                  Esense3d
                  Hello Fredo
                  I See but it is not Full Translated
                  Just Parts of it
                  I also have your other plugins translated fully ie including the main folder
                  and other
                  Therefore, any icons etcetera in German
                  If you want I send you these versions as rbz versions to
                  If you do not mind I would publish in the German part please
                  Roland F.
                  • fredo6F Offline
                    NEW RELEASE 1.7b - 22 Mar 2015
                    This release removes noisy traces at startup of Sketchup
                    • fredo6F Offline
                      NEW RELEASE 1.7c - 23 Mar 2015
                      This release removes noisy traces at startup of Sketchup - second trial
                        rdcraighead
                        This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                          Gábor
                          What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                            It's free.
                            • MsketcherM Offline
                              Msketcher
                              I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                              • N Offline
                                NZSnowman
                                Just downloaded. Can not wait to try. Looks great!
                                • I Offline
                                  iris1211
                                  why I can't download it....
                                    I can only guess it's because you didn't follow any of the links in the first post of this thread.
                                    Since several options are provided, surely you can get it from one of them.
                                      dbrenders
                                      Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. 😄 .
                                      These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
                                      Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
                                      Best
                                      David
                                      Enviat des del meu SM-P600 usant Tapatalk
                                      • fredo6F Offline
                                        Best
                                        David
                                        You can use arrow and Ctrl-Arrows to get some inferences along axes.
                                        But otherwise, the best is to try to use Construction points.
                                        I'll try to make it easier in a next version.
                                        • N Offline
                                          numerobis
                                          A spline behavior like in ACAD would be nice. 😉
                                          I think they are more harmonic or fluent. Here is a direct comparison:
                                          http://abload.de/img/splinetesth9sgw.jpg
                                          • fredo6F Offline
                                            Which method did you use in your example: CubicBezier, Catmull, FSpline?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
