    [Plugin] TT_Lib²
    310 Posts 66 Posters 408.2k Views 66 Watching
    • tt_suT Offline
      tt_su
      How are you installing the extension?
      Are you using a User or Administrator account?
        jemoto
        I am using a User account (supposedly with administrator privileges), and I suspected that could have something to do with it. I just tried to install under a "real" administrator account, and then it works. Only problem now is that I cannot invoke the "Create Quadpatch" icon, but it is in the Draw menu, so not a big deal.
        Thanks a lot for your help!
          Pherim
          Hello,
          I just installed CleanUp v3.3.1, Solid Inspector 2.4.3, and TT Library 2.10.2 and now ThomThom's Menu doesn't work any more, apparently. Only PickIt remains in the Menu, all other plugins are scattered around the Extensions Menu, which also breaks some of my Shortcuts.
            @pherim said:
            Hello,
            What else do you have installed? You use Fredo'd extension loader or the SCF manager?
              Pherim
              Not as far as I know. I used the Sketchucation Plugin Store to install them and until now everything worked fine.
                What OS and SketchUp version are you one?
                Can you post a screenshot of your Plugins folder?
                  Pherim
                  Windows 7 Professional 64bit, Sketchup Make 2015 64bit.
                  Screenshot Plugins Folder:
                  https://lh3.googleusercontent.com/-dtMvjgoBDnw/VQwCvnPQsgI/AAAAAAAACLM/EaD94OZRPWY/s0/plugins.png
                  (The ones with the .rb! extension are deactivated with Sketchucation Plugins Manager)
                    Pherim
                    Alright, I just installed ONLY TT_Lib v2.10.2 on my laptop and not Cleanup v3.3.1 and Solid Inspector² v2.3.4 and the same thing happened again: Only Pickit (and Similar Objects, which I don't have installed on my desktop) remains in the "ThomThoms Plugins" Menu, all your other plugins are just in the Extensions Menu now. Am I the only one with this problem?
                      I managed to track down a regression in TT_Lib. I uploaded a new version (2.10.4) to PluginStore. That should restore the old behaviour.
                        Pherim
                        Great, thanks!
                        • U Offline
                          uzunaruto93
                          When I updated my windows from 8.1 to 10, something happened 😞
                          Someone help me...
                          https://drive.google.com/file/d/0BzPrcUc2sd5RS0daNkVaZjRDeW8/view?usp=sharing
                          Error Loading File C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
                          Error: #<Encoding::ConverterNotFoundError: code converter not found (UTF-16LE to Windows-1258)>
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in each' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in to_a'
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in entries' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in prepare_path'
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:127:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:110:in module:TT'
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension'
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:14:in module:TT'
                          C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>'
                            adamj0112
                            Does the current version work with SU2016
                            • TIGT Online
                              Why wouldn't it ?
                              Always provided you have v2016's Preference > 'Extension [Loading] Policy' set to 'Unrestricted'...
                              The shipped default !
                                Yes.
                                  Yes, I finally got around to mark it as SU2016 compatible in the EW store.
                                  • ludnidL Offline
                                    ludnid
                                    @thomthom said:
                                    Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
                                    Coming a bit late but did you ever resolve the tt_lib showing as disabled in the sketchucation store?. Had this for a while but never really bothered with it as everything loaded fine....still does even after updating to the latest versions.
                                    EDIT: Removing your plugins safe subD and vertex, I started all over with TTLib2 coming first. The following plugins make TT_lib2 show as disabled in the Sketchucation UI.
                                    tt_camera
                                    tt_cleanup
                                    tt_edgetools
                                    The other plugins installed that didn't generate this error include
                                    tt_material replacer
                                    tt_material tools
                                    tt_Quadface tools
                                    tt_replacer
                                    tt_selection toys
                                    tt_shell
                                    tt_text editor
                                    tt_subD
                                    tt_vertex
                                    tt_vray tools
                                    If you don't ask, the answer will always be no.
                                      LinaKudinar
                                      I'm having some trouble downloading this plugin so that I can use CleanUp³. I am using Sketchup2016 on a windows. below are some images of what I am encountering. Is it something wrong with my connection and computer or is the problem coming from the extension warehouse?
                                      When downloading from extension warehouse in sketchup
                                      When downloading from the web browser
                                      • TIGT Online
                                        Download that Lib's latest RBZ from the SketchUcation PluginStore, or install our toolset and then use the ExtensionStore³, from within SketchUp itself to AutoInstall anything you want from here...
                                        • uwesketchU Offline
                                          uwesketch
                                          As I had the ruby console open at startup of sketchup, I saw the following warning message during initialization of TT lib latest version 2.12.3:
                                          C;/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/TT_Lib2/win32.rb;12; [b]warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead[/b]
                                          Probably unimportant, but just wanted to mention.
                                          • designerbursaD Offline
                                            designerbursa
                                            It gives an error on startup!..
                                            Please update it.
                                            The sketchup version I'm using is 2021
                                            • 15
                                            • 16
                                            • 2 / 16
