    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
      Yes, I finally got around to mark it as SU2016 compatible in the EW store.
      • ludnidL
        ludnid
        @thomthom said:
        Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
        Coming a bit late but did you ever resolve the tt_lib showing as disabled in the sketchucation store?. Had this for a while but never really bothered with it as everything loaded fine....still does even after updating to the latest versions.
        EDIT: Removing your plugins safe subD and vertex, I started all over with TTLib2 coming first. The following plugins make TT_lib2 show as disabled in the Sketchucation UI.
        tt_camera
        tt_cleanup
        tt_edgetools
        The other plugins installed that didn't generate this error include
        tt_material replacer
        tt_material tools
        tt_Quadface tools
        tt_replacer
        tt_selection toys
        tt_shell
        tt_text editor
        tt_subD
        tt_vertex
        tt_vray tools
        If you don't ask, the answer will always be no.
        • L
          LinaKudinar
          I'm having some trouble downloading this plugin so that I can use CleanUp³. I am using Sketchup2016 on a windows. below are some images of what I am encountering. Is it something wrong with my connection and computer or is the problem coming from the extension warehouse?
          When downloading from extension warehouse in sketchup
          When downloading from the web browser
            Download that Lib's latest RBZ from the SketchUcation PluginStore, or install our toolset and then use the ExtensionStore³, from within SketchUp itself to AutoInstall anything you want from here...
            • uwesketchU
              uwesketch
              As I had the ruby console open at startup of sketchup, I saw the following warning message during initialization of TT lib latest version 2.12.3:
              C;/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/TT_Lib2/win32.rb;12; [b]warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead[/b]
              Probably unimportant, but just wanted to mention.
              • designerbursaD
                designerbursa
                It gives an error on startup!..
                Please update it.
                The sketchup version I'm using is 2021
                  What error exactly?
                  Please update it.
                  TT_Lib2 works fine in SketchUp 2021 and SketchUp 2022. Make sure you have the most recent version. Use the Extension Warehouse interface in SketchUp to install it.
                  Make sure SketchUp was installed correctly. That requires right clicking on the downloaded installer and selecting Run as administrator.
                  • designerbursaD
                    designerbursa
                    C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/win32.rb:12: warning: Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                    • designerbursaD
                      designerbursa
                      Thanks for the update, it works fine. Will there be updates to Edge tools?
                      • U
                        unearthed
                        I'm running SketchupPro 8.0.16846
                        When I try to load TT_Lib sketchup immediately crashes. I'm installing via the dialog pathway: Window > Preferences " Extensions > Install Extension route.
                        Is an early version of TT_Lib available? or is there another solution? Thanks.
                        Growplan - People ∩ Plants ∩ Place
                        windows 7 64b, 4GB RAM, SU 8.0.16846
                        Gimp, QGIS, Vectorworks 12, Bricscad 11
                        • 12
                        • 13
                        • 14
                        • 15
                        • 16
                        • 16 / 16
