    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      @pherim said:
      Hello,
      I just installed CleanUp v3.3.1, Solid Inspector 2.4.3, and TT Library 2.10.2 and now ThomThom's Menu doesn't work any more, apparently. Only PickIt remains in the Menu, all other plugins are scattered around the Extensions Menu, which also breaks some of my Shortcuts.
      What else do you have installed? You use Fredo'd extension loader or the SCF manager?
      • P
        Pherim
        Not as far as I know. I used the Sketchucation Plugin Store to install them and until now everything worked fine.
          What OS and SketchUp version are you one?
          Can you post a screenshot of your Plugins folder?
          • P
            Pherim
            Windows 7 Professional 64bit, Sketchup Make 2015 64bit.
            Screenshot Plugins Folder:
            https://lh3.googleusercontent.com/-dtMvjgoBDnw/VQwCvnPQsgI/AAAAAAAACLM/EaD94OZRPWY/s0/plugins.png
            (The ones with the .rb! extension are deactivated with Sketchucation Plugins Manager)
            • P
              Pherim
              Alright, I just installed ONLY TT_Lib v2.10.2 on my laptop and not Cleanup v3.3.1 and Solid Inspector² v2.3.4 and the same thing happened again: Only Pickit (and Similar Objects, which I don't have installed on my desktop) remains in the "ThomThoms Plugins" Menu, all your other plugins are just in the Extensions Menu now. Am I the only one with this problem?
                I managed to track down a regression in TT_Lib. I uploaded a new version (2.10.4) to PluginStore. That should restore the old behaviour.
                • P
                  Pherim
                  Great, thanks!
                  • U
                    uzunaruto93
                    When I updated my windows from 8.1 to 10, something happened 😞
                    Someone help me...
                    https://drive.google.com/file/d/0BzPrcUc2sd5RS0daNkVaZjRDeW8/view?usp=sharing
                    Error Loading File C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
                    Error: #<Encoding::ConverterNotFoundError: code converter not found (UTF-16LE to Windows-1258)>
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in each' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in to_a'
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in entries' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in prepare_path'
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:127:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:110:in module:TT'
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                    C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension'
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:14:in module:TT'
                    C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>'
                      adamj0112
                      Does the current version work with SU2016
                        Why wouldn't it ?
                        Always provided you have v2016's Preference > 'Extension [Loading] Policy' set to 'Unrestricted'...
                        The shipped default !
                          Yes.
                            Yes, I finally got around to mark it as SU2016 compatible in the EW store.
                            • ludnidL
                              ludnid
                              @thomthom said:
                              Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
                              Coming a bit late but did you ever resolve the tt_lib showing as disabled in the sketchucation store?. Had this for a while but never really bothered with it as everything loaded fine....still does even after updating to the latest versions.
                              EDIT: Removing your plugins safe subD and vertex, I started all over with TTLib2 coming first. The following plugins make TT_lib2 show as disabled in the Sketchucation UI.
                              tt_camera
                              tt_cleanup
                              tt_edgetools
                              The other plugins installed that didn't generate this error include
                              tt_material replacer
                              tt_material tools
                              tt_Quadface tools
                              tt_replacer
                              tt_selection toys
                              tt_shell
                              tt_text editor
                              tt_subD
                              tt_vertex
                              tt_vray tools
                              If you don't ask, the answer will always be no.
                              • L
                                LinaKudinar
                                I'm having some trouble downloading this plugin so that I can use CleanUp³. I am using Sketchup2016 on a windows. below are some images of what I am encountering. Is it something wrong with my connection and computer or is the problem coming from the extension warehouse?
                                When downloading from extension warehouse in sketchup
                                When downloading from the web browser
                                  Download that Lib's latest RBZ from the SketchUcation PluginStore, or install our toolset and then use the ExtensionStore³, from within SketchUp itself to AutoInstall anything you want from here...
                                  • uwesketchU
                                    uwesketch
                                    As I had the ruby console open at startup of sketchup, I saw the following warning message during initialization of TT lib latest version 2.12.3:
                                    C;/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/TT_Lib2/win32.rb;12; [b]warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead[/b]
                                    Probably unimportant, but just wanted to mention.
                                    • designerbursaD
                                      designerbursa
                                      It gives an error on startup!..
                                      Please update it.
                                      The sketchup version I'm using is 2021
                                        What error exactly?
                                        Please update it.
                                        TT_Lib2 works fine in SketchUp 2021 and SketchUp 2022. Make sure you have the most recent version. Use the Extension Warehouse interface in SketchUp to install it.
                                        Make sure SketchUp was installed correctly. That requires right clicking on the downloaded installer and selecting Run as administrator.
                                        • designerbursaD
                                          designerbursa
                                          C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/win32.rb:12: warning: Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                                          • designerbursaD
                                            designerbursa
                                            Thanks for the update, it works fine. Will there be updates to Edge tools?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
