    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
    • tt_suT
      tt_su
      Are you using the first release of SketchUp 2014? If so, please update to maintenance release 1.
        smuncky
        We were having the same problem as xjhossef. Couldn't figure out what it was because it worked on one half of the computers but not the other.
        Looks like IT didn't update the half w/ the problem to maintenance release 1.
        Thanks for the heads up ThomThom!
          jemoto
          Thanks for all the great work. I have a problem installing TT_Lib2 and Bezier Surface to my Sketchup 2013, actually on two different computers, one running W7 32-bit and one running W8 64-bit. The error messages are the same. I am told TT_Lib is not installed although it is listed under extensions, and then I get the following error messages in the Ruby Console:
          Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/TT_Lib2/core.rb
          5: Access is denied. - C:/Users/Anybody/AppData/Local/Temp/TT_Lib2.rb/2.9.15/1.8/win32/tt_lib2.so
          Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/TT_Lib2.rb
          Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/tt_bezier_surface/core.rb
          uninitialized constant TT::Version
          Error Loading File tt_bezier_surface.rb
          Do you have any idea what causes this? I have searched the net, but without success.
          • tt_suT
            tt_su
            How are you installing the extension?
            Are you using a User or Administrator account?
              jemoto
              I am using a User account (supposedly with administrator privileges), and I suspected that could have something to do with it. I just tried to install under a "real" administrator account, and then it works. Only problem now is that I cannot invoke the "Create Quadpatch" icon, but it is in the Draw menu, so not a big deal.
              Thanks a lot for your help!
              • P
                Pherim
                Hello,
                I just installed CleanUp v3.3.1, Solid Inspector 2.4.3, and TT Library 2.10.2 and now ThomThom's Menu doesn't work any more, apparently. Only PickIt remains in the Menu, all other plugins are scattered around the Extensions Menu, which also breaks some of my Shortcuts.
                  @pherim said:
                  Hello,
                  What else do you have installed? You use Fredo'd extension loader or the SCF manager?
                  • P
                    Pherim
                    Not as far as I know. I used the Sketchucation Plugin Store to install them and until now everything worked fine.
                      What OS and SketchUp version are you one?
                      Can you post a screenshot of your Plugins folder?
                      • P
                        Pherim
                        Windows 7 Professional 64bit, Sketchup Make 2015 64bit.
                        Screenshot Plugins Folder:
                        https://lh3.googleusercontent.com/-dtMvjgoBDnw/VQwCvnPQsgI/AAAAAAAACLM/EaD94OZRPWY/s0/plugins.png
                        (The ones with the .rb! extension are deactivated with Sketchucation Plugins Manager)
                        • P
                          Pherim
                          Alright, I just installed ONLY TT_Lib v2.10.2 on my laptop and not Cleanup v3.3.1 and Solid Inspector² v2.3.4 and the same thing happened again: Only Pickit (and Similar Objects, which I don't have installed on my desktop) remains in the "ThomThoms Plugins" Menu, all your other plugins are just in the Extensions Menu now. Am I the only one with this problem?
                            I managed to track down a regression in TT_Lib. I uploaded a new version (2.10.4) to PluginStore. That should restore the old behaviour.
                            • P
                              Pherim
                              Great, thanks!
                              • U
                                uzunaruto93
                                When I updated my windows from 8.1 to 10, something happened 😞
                                Someone help me...
                                https://drive.google.com/file/d/0BzPrcUc2sd5RS0daNkVaZjRDeW8/view?usp=sharing
                                Error Loading File C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
                                Error: #<Encoding::ConverterNotFoundError: code converter not found (UTF-16LE to Windows-1258)>
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in each' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in to_a'
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in entries' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in prepare_path'
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:127:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:110:in module:TT'
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension'
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:14:in module:TT'
                                C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>'
                                  adamj0112
                                  Does the current version work with SU2016
                                    Why wouldn't it ?
                                    Always provided you have v2016's Preference > 'Extension [Loading] Policy' set to 'Unrestricted'...
                                    The shipped default !
                                      Yes.
                                        Yes, I finally got around to mark it as SU2016 compatible in the EW store.
                                        • ludnidL
                                          ludnid
                                          @thomthom said:
                                          Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
                                          Coming a bit late but did you ever resolve the tt_lib showing as disabled in the sketchucation store?. Had this for a while but never really bothered with it as everything loaded fine....still does even after updating to the latest versions.
                                          EDIT: Removing your plugins safe subD and vertex, I started all over with TTLib2 coming first. The following plugins make TT_lib2 show as disabled in the Sketchucation UI.
                                          tt_camera
                                          tt_cleanup
                                          tt_edgetools
                                          The other plugins installed that didn't generate this error include
                                          tt_material replacer
                                          tt_material tools
                                          tt_Quadface tools
                                          tt_replacer
                                          tt_selection toys
                                          tt_shell
                                          tt_text editor
                                          tt_subD
                                          tt_vertex
                                          tt_vray tools
                                          If you don't ask, the answer will always be no.
                                          • L
                                            LinaKudinar
                                            I'm having some trouble downloading this plugin so that I can use CleanUp³. I am using Sketchup2016 on a windows. below are some images of what I am encountering. Is it something wrong with my connection and computer or is the problem coming from the extension warehouse?
                                            When downloading from extension warehouse in sketchup
                                            When downloading from the web browser
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
