    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
    • P
      Pherim
      Great, thanks!
      • U
        uzunaruto93
        When I updated my windows from 8.1 to 10, something happened 😞
        Someone help me...
        https://drive.google.com/file/d/0BzPrcUc2sd5RS0daNkVaZjRDeW8/view?usp=sharing
        Error Loading File C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb
        Error: #<Encoding::ConverterNotFoundError: code converter not found (UTF-16LE to Windows-1258)>
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in each' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in to_a'
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in entries' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in prepare_path'
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:127:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:110:in module:TT'
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
        C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension'
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:14:in module:TT'
        C:/Users/Le Bao Duy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>'
          adamj0112
          Does the current version work with SU2016
            Why wouldn't it ?
            Always provided you have v2016's Preference > 'Extension [Loading] Policy' set to 'Unrestricted'...
            The shipped default !
              Yes.
                Yes, I finally got around to mark it as SU2016 compatible in the EW store.
                • ludnidL
                  ludnid
                  @thomthom said:
                  Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
                  Coming a bit late but did you ever resolve the tt_lib showing as disabled in the sketchucation store?. Had this for a while but never really bothered with it as everything loaded fine....still does even after updating to the latest versions.
                  EDIT: Removing your plugins safe subD and vertex, I started all over with TTLib2 coming first. The following plugins make TT_lib2 show as disabled in the Sketchucation UI.
                  tt_camera
                  tt_cleanup
                  tt_edgetools
                  The other plugins installed that didn't generate this error include
                  tt_material replacer
                  tt_material tools
                  tt_Quadface tools
                  tt_replacer
                  tt_selection toys
                  tt_shell
                  tt_text editor
                  tt_subD
                  tt_vertex
                  tt_vray tools
                  If you don't ask, the answer will always be no.
                  • L
                    LinaKudinar
                    I'm having some trouble downloading this plugin so that I can use CleanUp³. I am using Sketchup2016 on a windows. below are some images of what I am encountering. Is it something wrong with my connection and computer or is the problem coming from the extension warehouse?
                    When downloading from extension warehouse in sketchup
                    When downloading from the web browser
                      Download that Lib's latest RBZ from the SketchUcation PluginStore, or install our toolset and then use the ExtensionStore³, from within SketchUp itself to AutoInstall anything you want from here...
                      • uwesketchU
                        uwesketch
                        As I had the ruby console open at startup of sketchup, I saw the following warning message during initialization of TT lib latest version 2.12.3:
                        C;/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/TT_Lib2/win32.rb;12; [b]warning; Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead[/b]
                        Probably unimportant, but just wanted to mention.
                        • designerbursaD
                          designerbursa
                          It gives an error on startup!..
                          Please update it.
                          The sketchup version I'm using is 2021
                            What error exactly?
                            Please update it.
                            TT_Lib2 works fine in SketchUp 2021 and SketchUp 2022. Make sure you have the most recent version. Use the Extension Warehouse interface in SketchUp to install it.
                            Make sure SketchUp was installed correctly. That requires right clicking on the downloaded installer and selecting Run as administrator.
                            • designerbursaD
                              designerbursa
                              C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/win32.rb:12: warning: Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead
                              • designerbursaD
                                designerbursa
                                Thanks for the update, it works fine. Will there be updates to Edge tools?
                                • U
                                  unearthed
                                  I'm running SketchupPro 8.0.16846
                                  When I try to load TT_Lib sketchup immediately crashes. I'm installing via the dialog pathway: Window > Preferences " Extensions > Install Extension route.
                                  Is an early version of TT_Lib available? or is there another solution? Thanks.
                                  Growplan - People ∩ Plants ∩ Place
                                  windows 7 64b, 4GB RAM, SU 8.0.16846
                                  Gimp, QGIS, Vectorworks 12, Bricscad 11
                                  • 12
                                  • 13
                                  • 14
                                  • 15
                                  • 16
                                  • 16 / 16
