    [PLUGIN] Flowify v1.1.0 (updated 150327)
    124 Posts 56 Posters 193.8k Views 56 Watching
      Excellent! 😎
      Frank Gehry will love it! πŸ˜‰
      PS
      You have also a "Flow" function inside Moi3D πŸ€“
      (Ctrl + C, Ctrl + V between Rhino <--> Moi on the 2 ways)
        alpro
        This looks very cool, thanks for sharing and also for the good tutorial.
        • tt_suT Offline
          tt_su
          Loving the haunted house example! πŸ˜„
          It's been a while since I used Rhino - is the operation of setting up the meshes the same as FlowAlongSrf?
          (Btw, nice example of Bezier Surface there - it's seem to be more versatile than I expected. πŸ˜„ )
          • silvershadowS Offline
            silvershadow
            this is amazing!! Thank you so much for this,something i could definitely use with my current project and save some long boring hours.
            • duanekempD Offline
              duanekemp
              This looks amazingly useful!
              tt_su's question about meshes is good.
              How does this wrap textures? Are they projected in the same way as meshes?
              Duane Kemp
              Kemp Productions
              Puidoux, Switzerland
              Gallery:
              https://duanekemp.artstation.com/
              • F Offline
                faust07
                The demonstrations and examples are impressive and inspiring. This offers completely new possibilities to deform objects specifically and flowing. "Fredo6_FredoScale Radial Bending" on the next level. πŸ‘
                Will test it under SU8.
                  rv1974
                  CAUL, this is awesome thing! Thank you for sharing.
                  I tried some primitive case of 'panelization'. Everything went smooth except point A got split into A1 and A2. Is it possible to tweak the algorithm so it'd keep the same number of vertices?
                  Edit: I found 'flowify without cut' mode that solves this issue β˜€
                  BTW What exactly 'Aux' tools do?
                  nn.skp
                    CAUL
                    I was just going to suggest this πŸ˜„
                    The first Aux tool "Edge -> CLine" converts an edge to a construction line. If two connection edges intersect each other (if you pair your corners crosswise), then they split into four edges and that is not handled by the extension. The extension let you convert an edge to a construction line to handle this.
                    The purpose of the second Aux tool cannot really be explained in less than 2500 words. There will eventually be a tutorial with this tool playing a small part.
                    • cmdC Offline
                      cmd
                      Caul
                      I tried to mimic your example and I am have a few problems.
                      1. The IMPOSE GRID function does not modify my "Projection Surface".
                      • I am not getting any errors in the Ruby Console when initiating the IMPOSE GRID feature.
                      1. I am receiving an error dialog message concerning the " Target grid".
                      INPUT ERROR: Error while parsing the Target grid
                      The grid must conform to:
                      • A cell consists of exactly four edges. Beware of collinear edge segments
                      • Connection edges must attatch to two adjecent corners
                      • The grid must have four corners
                      • Every row in the grid must have the same number of cells
                      • No holes
                      • I checked the Target Grid and it all seems to comply with the rules.
                      Attached is the skp.
                      Can anyone figure out why it's not working?
                      Although I believe I am following the instructions step by step... user error?
                      Problem file
                      • CMD
                        CAUL
                        It is very similar, in Rhino there are no explicit connection edges though.
                        That was a nice summary, the projective version of Flow is actually coded and may end up in a later version of Flowify.
                        @duanekemp said:
                        Is v1.2 addressing texture mapping? πŸ˜„
                        I will look into this, it would certainly be a nice feature.
                          @Cmd
                          You must draw the 2 lines' Extremities Start to extremities' Target! πŸ’š
                          • cmdC Offline
                            cmd
                            Just as I thought..... USER ERROR Doh!!
                            • CMD
                            • PixeroP Offline
                              Pixero
                              Very very cool. Great job! πŸ‘
                              • pep75P Offline
                                pep75
                                These are the plugins that make SU more valuable! Great scripting Caul!
                                  Martin i Uixan
                                  Thamk you very much, you are magician Caul. It's awesome. First test now
                                  • panixiaP Offline
                                    panixia
                                    Great and useful plugin sir! thank you so much! πŸ‘
                                    i played a bit with it and it's really enjoiable, but i have a request if possible/not toohard to accomplish..
                                    it looks like the "flow without" cut doesn't add triangles but unsfoften every edges.. can we have an option to preserve edge properties so that this tool could be more esily integrated in an organic/quadfacetools-friendly workflow?
                                    edit - attached example
                                      +1e6
                                        duanekemp
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                          CAUL
                                          Good suggestion! This feature is now introduced in v1.1.0.
                                          • panixiaP Offline
                                            panixia
                                            wow! thank you so much! it works fine!
                                            • 3 / 7
