    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 227.1k Views 57 Watching
    • C
      CAUL
      @tt_su said:
      It's been a while since I used Rhino - is the operation of setting up the meshes the same as FlowAlongSrf?
      It is very similar, in Rhino there are no explicit connection edges though.
      @pilou said:
      You have also a "Flow" function inside Moi3D πŸ€“
      That was a nice summary, the projective version of Flow is actually coded and may end up in a later version of Flowify.
      @duanekemp said:
      Is v1.2 addressing texture mapping? πŸ˜„
      I will look into this, it would certainly be a nice feature.
        @Cmd
        You must draw the 2 lines' Extremities Start to extremities' Target! πŸ’š
        • cmdC
          cmd
          Just as I thought..... USER ERROR Doh!!
          • CMD
          • PixeroP
            Pixero
            Very very cool. Great job! πŸ‘
            • pep75P
              pep75
              These are the plugins that make SU more valuable! Great scripting Caul!
                Martin i Uixan
                Thamk you very much, you are magician Caul. It's awesome. First test now
                • panixiaP
                  panixia
                  @caul said:
                  @rv1974 said:
                  Edit: I found 'flowify without cut' mode that solves this issue β˜€
                  I was just going to suggest this πŸ˜„
                  Great and useful plugin sir! thank you so much! πŸ‘
                  i played a bit with it and it's really enjoiable, but i have a request if possible/not toohard to accomplish..
                  it looks like the "flow without" cut doesn't add triangles but unsfoften every edges.. can we have an option to preserve edge properties so that this tool could be more esily integrated in an organic/quadfacetools-friendly workflow?
                  edit - attached example
                    +1e6
                    • duanekempD
                      duanekemp
                      Duane Kemp
                      Kemp Productions
                      Puidoux, Switzerland
                      Gallery:
                      https://duanekemp.artstation.com/
                      • C
                        CAUL
                        Good suggestion! This feature is now introduced in v1.1.0.
                        • panixiaP
                          panixia
                          wow! thank you so much! it works fine!
                          • CadFatherC
                            CadFather
                            Thank you Caul. fantastic extension.
                            on my pc the impose grid has no effect on the plane.
                            hence flowify shows errors (but at least it fires), got the 3 groups in place etc.
                            tried with a default plugins set up (flowify the only extension). no success.
                            attach the sample, in case someone can see any blindspots...
                            the tutorials were some of the best i've seen. πŸ‘ πŸ‘
                            %(#BF0080)[EDIT: 😳 i think i made a mistake. i thought i could place the lines a bit inside the group, not always on the extremities. sorry the false alarm! πŸ˜„]
                            EDIT 2: %(#FF0000)[OUT OF THIS WORLD! πŸ˜†]
                            2.skp
                            • duanekempD
                              duanekemp
                              This is the most amazing thing I've seen in a while. Brilliant! I've been following a little... but, just took the time to really look at this. I can't believe what this does for workflow! I'm sharing this with friends... people have GOT to know about this.
                              Unless... of course... I'm the last one of my friends to start paying attention... either way. I'm really excited to use this. Thank you for sharing with us.
                              Duane Kemp
                              Kemp Productions
                              Gallery:
                              • T
                                Taner Batu
                                Hello Caul! I like it. I watched videos again many times, but I could not use it.
                                Please, share SketchUp files of examples with us. So everyone will know better. Thank you.
                                  Are you sure to make all steps in the good order ?
                                  • C
                                    CAUL
                                    I've added an example file to the initial post. Hope that helps!
                                      Seems you are not obliged to past the volume on the surface! πŸ˜„
                                      Model By Caul
                                      Render real time by the free Visualizer 1.3
                                        sepo
                                        Would it be possible to have timer while flowify calculates?
                                        • C
                                          cuttingedge
                                          excellent excellent plugin.. extensions like these will take SU to a whole new level..Thanks Caul... and keep it coming. πŸ˜„
                                          • deaneauD
                                            deaneau
                                            @ pilou
                                            @pilou
                                            "Render real time by the free Visualizer 1.3"
                                            this is not right..the version you must pay
                                            here a part of the main page
                                            https://www.getvisualizer.com/
                                            **"Why is it now free?
                                            [b]ooops i have read "not" and not "now"
                                            As part of Imagination Technologies’ longer term plans and investment to bring interactive ray-tracing to a mainstream mobile audience , we’ve decided to focus the Visualizer development team’s expertise on helping us bring a new generation of graphics chip technology to market. Unfortunately, there’s so much to do we’ve had to do this at the expense of ceasing all further development of the Visualizer product line.
                                            Our final release 1.3 of Visualizer for SketchUp is the most capable yet, and we think every one of our thousands of Visualizer fans will want to use it. We have no plan for further changes to Visualizer for SketchUp beyond our 1.3 release."**[/b]
                                            ~~iΒ΄m not really sure, however maxwell for sketchup have a free version.
                                            if you show renderings with Viz 1.3 than pay this please..provide the developer in this new project.
                                            19.90 euro is not really expansive.. and you can better sleep if you use a registered version.
                                            i know many developer here.. give away some plugins for free..however keep in mind...writing code, bugfixing etc. is lifetime, too..and many plugins are free and have safe my time... freeware is a good will...
                                            example: if eneroth would work for the Townhouse System i would pay this. however Eneroth have actually not many time for this project.. im unhappy about this...however this is eneroth life time.
                                            spend time is everytime a good will.. and when the plugin doing a good job..i can pay this..and i can sleeping well.~~
                                            • 2 / 7
