    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 217.2k Views 57 Watching
    • F Offline
      faust07
      The demonstrations and examples are impressive and inspiring. This offers completely new possibilities to deform objects specifically and flowing. "Fredo6_FredoScale Radial Bending" on the next level. πŸ‘
      Will test it under SU8.
        rv1974
        CAUL, this is awesome thing! Thank you for sharing.
        I tried some primitive case of 'panelization'. Everything went smooth except point A got split into A1 and A2. Is it possible to tweak the algorithm so it'd keep the same number of vertices?
        Edit: I found 'flowify without cut' mode that solves this issue β˜€
        BTW What exactly 'Aux' tools do?
        nn.skp
          CAUL
          I was just going to suggest this πŸ˜„
          The first Aux tool "Edge -> CLine" converts an edge to a construction line. If two connection edges intersect each other (if you pair your corners crosswise), then they split into four edges and that is not handled by the extension. The extension let you convert an edge to a construction line to handle this.
          The purpose of the second Aux tool cannot really be explained in less than 2500 words. There will eventually be a tutorial with this tool playing a small part.
          • cmdC Offline
            cmd
            Caul
            I tried to mimic your example and I am have a few problems.
            1. The IMPOSE GRID function does not modify my "Projection Surface".
            • I am not getting any errors in the Ruby Console when initiating the IMPOSE GRID feature.
            1. I am receiving an error dialog message concerning the " Target grid".
            INPUT ERROR: Error while parsing the Target grid
            The grid must conform to:
            • A cell consists of exactly four edges. Beware of collinear edge segments
            • Connection edges must attatch to two adjecent corners
            • The grid must have four corners
            • Every row in the grid must have the same number of cells
            • No holes
            • I checked the Target Grid and it all seems to comply with the rules.
            Attached is the skp.
            Can anyone figure out why it's not working?
            Although I believe I am following the instructions step by step... user error?
            Problem file
            • CMD
              CAUL
              @tt_su said:
              It's been a while since I used Rhino - is the operation of setting up the meshes the same as FlowAlongSrf?
              It is very similar, in Rhino there are no explicit connection edges though.
              @pilou said:
              You have also a "Flow" function inside Moi3D πŸ€“
              That was a nice summary, the projective version of Flow is actually coded and may end up in a later version of Flowify.
              @duanekemp said:
              Is v1.2 addressing texture mapping? πŸ˜„
              I will look into this, it would certainly be a nice feature.
                @Cmd
                You must draw the 2 lines' Extremities Start to extremities' Target! πŸ’š
                • cmdC Offline
                  cmd
                  Just as I thought..... USER ERROR Doh!!
                  • CMD
                  • PixeroP Offline
                    Pixero
                    Very very cool. Great job! πŸ‘
                    • pep75P Offline
                      pep75
                      These are the plugins that make SU more valuable! Great scripting Caul!
                        Martin i Uixan
                        Thamk you very much, you are magician Caul. It's awesome. First test now
                        • panixiaP Offline
                          panixia
                          Great and useful plugin sir! thank you so much! πŸ‘
                          i played a bit with it and it's really enjoiable, but i have a request if possible/not toohard to accomplish..
                          it looks like the "flow without" cut doesn't add triangles but unsfoften every edges.. can we have an option to preserve edge properties so that this tool could be more esily integrated in an organic/quadfacetools-friendly workflow?
                          edit - attached example
                            +1e6
                            • duanekempD Offline
                              duanekemp
                              Duane Kemp
                              Kemp Productions
                              Puidoux, Switzerland
                              Gallery:
                              https://duanekemp.artstation.com/
                                CAUL
                                Good suggestion! This feature is now introduced in v1.1.0.
                                • panixiaP Offline
                                  panixia
                                  wow! thank you so much! it works fine!
                                  • CadFatherC Offline
                                    CadFather
                                    Thank you Caul. fantastic extension.
                                    on my pc the impose grid has no effect on the plane.
                                    hence flowify shows errors (but at least it fires), got the 3 groups in place etc.
                                    tried with a default plugins set up (flowify the only extension). no success.
                                    attach the sample, in case someone can see any blindspots...
                                    the tutorials were some of the best i've seen. πŸ‘ πŸ‘
                                    %(#BF0080)[EDIT: 😳 i think i made a mistake. i thought i could place the lines a bit inside the group, not always on the extremities. sorry the false alarm! πŸ˜„]
                                    EDIT 2: %(#FF0000)[OUT OF THIS WORLD! πŸ˜†]
                                    2.skp
                                      duanekemp
                                      This is the most amazing thing I've seen in a while. Brilliant! I've been following a little... but, just took the time to really look at this. I can't believe what this does for workflow! I'm sharing this with friends... people have GOT to know about this.
                                      Unless... of course... I'm the last one of my friends to start paying attention... either way. I'm really excited to use this. Thank you for sharing with us.
                                      Duane Kemp
                                      Kemp Productions
                                      Gallery:
                                        Taner Batu
                                        Hello Caul! I like it. I watched videos again many times, but I could not use it.
                                        Please, share SketchUp files of examples with us. So everyone will know better. Thank you.
                                          Are you sure to make all steps in the good order ?
                                            CAUL
                                            I've added an example file to the initial post. Hope that helps!
                                            • 2 / 7
