    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 79.3k Views 46 Watching
    • F Offline
      fluid
      We just released version 2.1.2, you can get if here: http://www.fluidimporter.com/downloads
      Fixes:
      • Solved issues making the plugin not show up on some MAC configurations
      • Improved import accuracy
      • I Offline
        imx
        @krism said:
        Has anyone had any success with this plugin?
        I downloaded the trial which tells me it's expired even though I have never used it and installed it on the same day as I downloaded it. Two emails to the developer have gone unanswered.
        I tried the free version on SketchUp 8 but it doesn't work. I can't tell if it's a problem with my file or the plugin.
        I would like to incorporate this plugin into my workflow but am somewhat frustrated. I would like to hear if this plugin actually works.
        KrisM
        Instal
        Microsoft Visual C++ 2008 Redistributable Package (x86)
        or
        Microsoft Visual C++ 2008 Feature Pack Redistributable Package (x86)
        • vyctortumbuanV Offline
          vyctortumbuan
          I cant use the demo version.
            dtrarch
            Very good app.
            I have the paid for version and it is fast and accurate. πŸ‘ πŸ‘
            Works very well for Artlantis import too (v4.1)
            dtr
              keitheseymour
              Would it be difficult to create a version that works for Sketchup8 on a Mac? It would be very much appreciated... πŸ˜„
              • F Offline
                fluid
                We just released FluidImporter 2.1.4, you can get it here: http://www.fluidimporter.com/downloads.
                This version solves a lot of bugs and crashes, and is much faster for files containing many groups.
                • F Offline
                  fluid
                  We just released FluidImporter 2.1.5. You can get it here.
                  In this version:
                  • Support for SketchuUp 2015 and 64bit versions
                  • Bug fixes
                    AriseSavage
                    I've tried to import an OBJ file in all OBJ importers I could find, and also tested in other apps like Blender or Rhino and I can't get the texture mapped ok.
                    When I use the model inside the rendering app based on libgdx, it appears fine, at least the top of it.
                    Anyone knows why the ship.obj file doesn't look ok in sketchup?
                    This is how the model should look like:
                    Ship rendered (how it should like)
                    The texture
                    Full zip archive
                      I don't know why the UV mapping is messed up in this case...
                      BUT it is fixable. πŸ˜„
                      Import the OBJ and the UV mapping is rubbish...
                      Now edit the 'ship' Material [oddly named 'cube1_auv' !] - edit its image ship.PNG.
                      In Gimp [or PS] - rotate it 180 degrees and then flip it - see the thumbnail in the Materials Browser screen-shot, compared to the original ship.PNG [which I've also attached]...
                      Save/close the image and the Material updates - the UV mapping is now corrected... πŸ€“
                        AriseSavage
                        Thanks, now I have to figure out a way to batch process the images I assume to convert from Sketchup to my LibGDX obj scene loader.
                          You could rotate 180 and then flip the PNG images using Gimp or PS, before the OBJ import...
                          There are batch plugins for Gimp to let you do this, en mass...
                          See Gimp's BIMP http://alessandrofrancesconi.it/projects/bimp/
                          • F Offline
                            fluid
                            Just released v.1.0.1 featuring:
                            • Units options
                            • Flip YZ option
                            • Read color and texture from material library
                            • Triangulate polygons option
                            • Should handle negative indices (not tested)
                            Thanks to TIG for the suggestions.
                            Check at the end of the page: http://www.fluidimporter.com/downloads
                              Rivalz
                              When ever I install the new FluidImporter 2 for SketchUp 2015 64bit - OSX my sketchup will crash on start up. Placing the .plugin file in the package contents only causes it crash when I go to select file>import. If anyone has any ideas or more info please let me know.
                                jumpjack
                                How do I install the plugin without running the executable? I extracted all the files using Uniextract, but now what?
                                  What's the purpose of not using the .exe?
                                    jumpjack
                                    keeping my office pc clean
                                    • F Offline
                                      fluid
                                      We just released FluidImporter Pro, which imports the following formats: .obj, .fbx, .stl, .ply, .x, .3ds, .dae, .ase
                                      Also the regular FluidImporter has been updated (it's now called FluidImporter Lite).
                                      Please check http://www.fluidimporter.com for instruction on how to install and use it.
                                      • F Offline
                                        fluid
                                        We just released FluidImporter 3.1.0. You can get it here.
                                        Here's what's new:
                                        • Faster import
                                        • FluidImporter is now a full .rbz extension, with a single file for Windows/OSX
                                        • You can access FluidImporter funtionality through the menu Extensions -> FluidImporter
                                        • Added edge smooth option
                                        • Options are now saved so you don't lose your settings when closing SkechUp
                                        • 8 / 9
