    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 86.1k Views 46 Watching
      keitheseymour
      Would it be difficult to create a version that works for Sketchup8 on a Mac? It would be very much appreciated... πŸ˜„
      • F Offline
        fluid
        We just released FluidImporter 2.1.4, you can get it here: http://www.fluidimporter.com/downloads.
        This version solves a lot of bugs and crashes, and is much faster for files containing many groups.
        • F Offline
          fluid
          We just released FluidImporter 2.1.5. You can get it here.
          In this version:
          • Support for SketchuUp 2015 and 64bit versions
          • Bug fixes
            AriseSavage
            I've tried to import an OBJ file in all OBJ importers I could find, and also tested in other apps like Blender or Rhino and I can't get the texture mapped ok.
            When I use the model inside the rendering app based on libgdx, it appears fine, at least the top of it.
            Anyone knows why the ship.obj file doesn't look ok in sketchup?
            This is how the model should look like:
            Ship rendered (how it should like)
            The texture
            Full zip archive
              I don't know why the UV mapping is messed up in this case...
              BUT it is fixable. πŸ˜„
              Import the OBJ and the UV mapping is rubbish...
              Now edit the 'ship' Material [oddly named 'cube1_auv' !] - edit its image ship.PNG.
              In Gimp [or PS] - rotate it 180 degrees and then flip it - see the thumbnail in the Materials Browser screen-shot, compared to the original ship.PNG [which I've also attached]...
              Save/close the image and the Material updates - the UV mapping is now corrected... πŸ€“
                AriseSavage
                Thanks, now I have to figure out a way to batch process the images I assume to convert from Sketchup to my LibGDX obj scene loader.
                  You could rotate 180 and then flip the PNG images using Gimp or PS, before the OBJ import...
                  There are batch plugins for Gimp to let you do this, en mass...
                  See Gimp's BIMP http://alessandrofrancesconi.it/projects/bimp/
                  • F Offline
                    fluid
                    Just released v.1.0.1 featuring:
                    • Units options
                    • Flip YZ option
                    • Read color and texture from material library
                    • Triangulate polygons option
                    • Should handle negative indices (not tested)
                    Thanks to TIG for the suggestions.
                    Check at the end of the page: http://www.fluidimporter.com/downloads
                      Rivalz
                      When ever I install the new FluidImporter 2 for SketchUp 2015 64bit - OSX my sketchup will crash on start up. Placing the .plugin file in the package contents only causes it crash when I go to select file>import. If anyone has any ideas or more info please let me know.
                        jumpjack
                        How do I install the plugin without running the executable? I extracted all the files using Uniextract, but now what?
                          What's the purpose of not using the .exe?
                            jumpjack
                            keeping my office pc clean
                            • F Offline
                              fluid
                              We just released FluidImporter Pro, which imports the following formats: .obj, .fbx, .stl, .ply, .x, .3ds, .dae, .ase
                              Also the regular FluidImporter has been updated (it's now called FluidImporter Lite).
                              Please check http://www.fluidimporter.com for instruction on how to install and use it.
                              • F Offline
                                fluid
                                We just released FluidImporter 3.1.0. You can get it here.
                                Here's what's new:
                                • Faster import
                                • FluidImporter is now a full .rbz extension, with a single file for Windows/OSX
                                • You can access FluidImporter funtionality through the menu Extensions -> FluidImporter
                                • Added edge smooth option
                                • Options are now saved so you don't lose your settings when closing SkechUp
                                • 9 / 9
