SketchUcation 3D Viewer (formerly the '[ignore]' thread)
Yes. It's just the lights need to fire on first rotate.
Currently you can upload directly from SU and set models to be public or private.
You can pick various lighting types and colours
And materials will allow you set spec values.
We use it internally to securely share 3D files with handing off assets.
on a beach with Branson and Co.
well, get to work on the phone version then.. pronto
You don't seem to want feedback since you said Ignore, but I get these errors every time on FF but not on chrome.
Nope, cleared cache several times, restarted FF and even rebooted PC, still the same errors pop up. If you ok them away the model does open.
Works fine for me in FF.
What version you running ?
I have v34.0Do you have the required FF-Plugin ?
Doesn't WebGL come built-in with the latest versions ? -
working on Safari on mac...
it should work on iOS 8 [ iPhone and iPad ] as it has native webGL unless your processing on the local system?
I have 33.1, as soon as I opened about it started downloading the latest update, i'll see if that fixes it.
But don't get me wrong, the models are viewable and rotatable etc, it's just that it gives those errors first. -
If it works, despite the messages, then maybe the error messages could be suppressed in a 'catch' block ?
[sw:2vtbmtdu]ljBmryyYoH4w0IK[/sw:2vtbmtdu]
That fixed it, updated FF to 34.0 and no errors.
It needs a WebGL enabled browser. That is why it fails with "before WebGL" browsers....
Works in Chrome and IE 11........
Interesting piece of software. Is this something that is available somewhere? Can/will you supply any details about the software.
The only model I have any problem with is the 2nd one (little chick cartoon). It always loads as all black.
Some times I have to click a 2nd time in IE to get to see it (once to load it then the 2nd time to view it in 3d).
It would be really neat if you could use this viewer in something like PowerPoint
model loads on iOS Simulator on my desktop, but I can't swipe it and the mouse move actions don't function
It almost works on android, viewable but not 3d rotate . You can use the Last 3 buttons.
Swiping is not working (yet).
Not at the moment. It is still alpha
Understand.......I look forward to your tool. I have tested CL3VER and Spread3D which has a little bit more of a "presentation" focus but I started out looking for the ability to view Sketchup models without the need for a plugin. My focus was in being able to provide links on a web page that would allow me to access our models at a convention. The idea (for us) was to have a web page that listed various models/versions (we build car washes) that we could then show potential customers in full 3d.
I have not tried this on my iPad yet but I will go off and do it and see what happens.
Hope you will keep us all up-to-date as I see this as being VERY interesting. As I said before, it would also be neat if you could use the viewer inside something like PowerPoint.
And yes, having full touch support would be neat also (particularly on the iPad or at the convention).
With your input, this post could be even better đ
