    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 27.2k Views 19 Watching
      [sw:13d908s0]2y8Lh5PWMvoq7xa[/sw:13d908s0]
      Click image to load
        [sw:14zhv4zr]BdmkuN2KPz6PkSZ[/sw:14zhv4zr]
        • soloS Offline
          Works well on my side, oh, you have reversed faces between tail lights
            Not reversed
            It is a shading issue between hard and soft edges
            • jeff hammondJ Offline
              not that I thought it would work from a phone but..
              (I didn't realize I could upload images from my photoroll though.. so that's cool)
                there's a secondary message too. webGL not available-- falling back to canvas render
                (or something like that)
                so the alert system works ok on non compliant hardware/software
                  [sw:l1sbv14m]MXdINzqAuUBxk4Z[/sw:l1sbv14m]
                  @hammertime
                  if we had it working on phones we'd be on a beach with Branson and Co.
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    Works for me.
                    Although, the model doesn't appear until I click (Of course I clicked once first to load the model)
                    Win7, Chrome 39.0.2171.71m
                      Yes. It's just the lights need to fire on first rotate.
                      Currently you can upload directly from SU and set models to be public or private.
                      You can pick various lighting types and colours
                      And materials will allow you set spec values.
                      We use it internally to securely share 3D files with handing off assets.
                        well, get to work on the phone version then.. pronto
                        • BoxB Offline
                          You don't seem to want feedback since you said Ignore, but I get these errors every time on FF but not on chrome.
                            [sw:2x3cfcfh]o5y6KNXjtiHCU6U[/sw:2x3cfcfh]
                            @Ben
                            Clear your cache
                            • BoxB Offline
                              Nope, cleared cache several times, restarted FF and even rebooted PC, still the same errors pop up. If you ok them away the model does open.
                                Works fine for me in FF.
                                What version you running ?
                                I have v34.0
                                Do you have the required FF-Plugin ?
                                Doesn't WebGL come built-in with the latest versions ?
                                  driven
                                  working on Safari on mac...
                                  it should work on iOS 8 [ iPhone and iPad ] as it has native webGL unless your processing on the local system?
                                  • BoxB Offline
                                    I have 33.1, as soon as I opened about it started downloading the latest update, i'll see if that fixes it.
                                    But don't get me wrong, the models are viewable and rotatable etc, it's just that it gives those errors first.
                                      If it works, despite the messages, then maybe the error messages could be suppressed in a 'catch' block ?
                                        [sw:2vtbmtdu]ljBmryyYoH4w0IK[/sw:2vtbmtdu]
                                        • BoxB Offline
                                          That fixed it, updated FF to 34.0 and no errors.
                                            Gábor
                                            It needs a WebGL enabled browser. That is why it fails with "before WebGL" browsers....
                                            • 13
                                            • 14
                                            • 1 / 14
