    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 27.2k Views 19 Watching
    • jeff hammondJ Offline
      there's a secondary message too. webGL not available-- falling back to canvas render
      (or something like that)
      so the alert system works ok on non compliant hardware/software
        [sw:l1sbv14m]MXdINzqAuUBxk4Z[/sw:l1sbv14m]
        @hammertime
        if we had it working on phones we'd be on a beach with Branson and Co.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Works for me.
          Although, the model doesn't appear until I click (Of course I clicked once first to load the model)
          Win7, Chrome 39.0.2171.71m
            Yes. It's just the lights need to fire on first rotate.
            Currently you can upload directly from SU and set models to be public or private.
            You can pick various lighting types and colours
            And materials will allow you set spec values.
            We use it internally to securely share 3D files with handing off assets.
              well, get to work on the phone version then.. pronto
              • BoxB Offline
                You don't seem to want feedback since you said Ignore, but I get these errors every time on FF but not on chrome.
                  [sw:2x3cfcfh]o5y6KNXjtiHCU6U[/sw:2x3cfcfh]
                  @Ben
                  Clear your cache
                  • BoxB Offline
                    Nope, cleared cache several times, restarted FF and even rebooted PC, still the same errors pop up. If you ok them away the model does open.
                      Works fine for me in FF.
                      What version you running ?
                      I have v34.0
                      Do you have the required FF-Plugin ?
                      Doesn't WebGL come built-in with the latest versions ?
                        driven
                        working on Safari on mac...
                        it should work on iOS 8 [ iPhone and iPad ] as it has native webGL unless your processing on the local system?
                        • BoxB Offline
                          I have 33.1, as soon as I opened about it started downloading the latest update, i'll see if that fixes it.
                          But don't get me wrong, the models are viewable and rotatable etc, it's just that it gives those errors first.
                            If it works, despite the messages, then maybe the error messages could be suppressed in a 'catch' block ?
                              [sw:2vtbmtdu]ljBmryyYoH4w0IK[/sw:2vtbmtdu]
                              • BoxB Offline
                                That fixed it, updated FF to 34.0 and no errors.
                                  GĂĄbor
                                  It needs a WebGL enabled browser. That is why it fails with "before WebGL" browsers....
                                  • ntxdaveN Offline
                                    ntxdave
                                    Works in Chrome and IE 11........
                                    Interesting piece of software. Is this something that is available somewhere? Can/will you supply any details about the software.
                                    The only model I have any problem with is the 2nd one (little chick cartoon). It always loads as all black.
                                    Some times I have to click a 2nd time in IE to get to see it (once to load it then the 2nd time to view it in 3d).
                                    It would be really neat if you could use this viewer in something like PowerPoint 😄
                                    Press F1...thank me later
                                      driven
                                      model loads on iOS Simulator on my desktop, but I can't swipe it and the mouse move actions don't function
                                        driven
                                        is it touch enabled?
                                        • BoxB Offline
                                          It almost works on android, viewable but not 3d rotate . You can use the Last 3 buttons.
                                            GĂĄbor
                                            Not (yet). 😄
                                            • 13
                                            • 14
                                            • 1 / 14
