    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.6k Views 69 Watching
      @jolran said:
      it looks super nice thank you but it doesn't work for me (sketchup 8 on win7)
      Same here. I only had it working in 2014.
      Error "defined method `force_encoding' for #String:0xb10993c"
      This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
      Yea, with my new subdivison extension I'm certainly dropping support for anything older than SU2014.
      Though this was written before SU2014 and it should work. (Though might have introduced a bug when I added SU2014 support. Can you provide the full error message and exact SketchUp version and OS?)
        @panixia said:
        yeah. force encoding blablabla.. getting similar message when loading sketchup
        The bla bla bla bit of error message is in fact very useful for developers when debugging errors - please post all of it when reporting issues.
          @jolran said:
          It may have be a condition set on line 26 in the loader rb
          "file = FILE.dup.force_encoding("UTF-8")"
          Ah - right, I'll fix that and push an update next week.
            @unclex said:
            It's just always updating...
            Like the GIF[attachment=0:1br0oo34]<!-- ia0 -->8.gif<!-- ia0 -->[/attachment:1br0oo34]
            Cannot Click or DoubleClick
            and when SU opening, nothing prompt
            Any errors in the Ruby Console?
            What SketchUp version?
              @oxer said:
              Thanks you very much for the plugin!! 👍 👍
              I installed it in SU2014 & SU2015 on Mac but the plugin didn't work, I found a conflict with smartdrop.rb and Sketchyphysics, I deleted smartdrop.rb (I use tt.raytracer now to drop components) and I have deactivated Sketchyphysics on SU2014 with Sketchucation Plugins Manager and Bezier Surface work fine now.
              SketchyPhysics is known to clash with extensions. I think an update is coming.
              Not sure about smartdrop.rb - not familiar with that one.
              • OxerO
                Oxer
                A quick test taking like reference the torso of Box.
                • panixiaP
                  panixia
                  i'm pretty much sure that the "blablabla" part of the message returned ad least 3 different values with different tries (that's pretty odd i suppose) the last try being: "Loading File tt_bezier_surface.rb
                  undefined method `force_encoding' for #String:0xec947b8no such file to load --" 😲
                  hope this can help
                    I'll mainly focus on my subdivision extension over this one. Though I'll try to maintain small bug fixes and pull requests. I'll see after SUbD is done what I do with this project.
                    Btw, I have a fix for the compatibility bug with SU2013 and older. I'll be pushing an update.
                    • jolranJ
                      jolran
                      I understand.
                        When there is incompatibility (Sketchyphysics 3, SKalp, (my case) etc...
                        Who is faulty ? These plugins or Bezier Surface ?
                        @oxer : Rodin 2 😄
                          Bezier Surface is confined to its own namespace - so the only thing I can think of would be possibly other extension clashing with observers. SketchyPhysics has been known to clash with many extensions - though I'm not sure if it's been updated recently to address that.
                          Odd if Skalp clashes... maybe observer fights?
                          Do you get any errors in the Ruby Console?
                            See my previous posts from here
                            Messages were the same that the restant on my post linked 😉
                            So for have no message errors I disconnect plugins after plugins.
                            • CadFatherC
                              CadFather
                              ok, in my case progressbar.rb is the culprit
                              now it's smartdrop
                              it changes.. 😆
                              • U
                                unclex
                                @thomthom said:
                                Re: [Plugin][WIP][OpenSource] Bezier Surface
                                Postby thomthom » Mon Nov 24, 2014 4:18 am
                                unclex wrote:It's just always updating...
                                Like the GIF
                                Now I Know what happened
                                Smartdrop clash with TTlib2
                                something named "definition"
                                so I change "definition" to "a4sddefinition" @ smartdrop.rb
                                and it works
                                Smartdrop.rb
                                • jeff hammondJ
                                  here's a simple introductory example.. maybe something a lot of people can use..
                                  seamless background for rendering
                                  1- draw the patch next to a flat plane:
                                  2- double click the patch to enter the editing mode.. select the back line:
                                  3- using the blue arrow on the gizmo, move the edge vertical:
                                  4- using the red arc, rotate the edge downwards 90º (degrees will be shown in the measurement box)
                                  5- using the blue square, scale downwards.. align the green control point with the green axis
                                  6- change the segmentation in the measurements box (i think i used 20)
                                  • jolranJ
                                    jolran
                                    Wow, this topic is moving fast now. 😄
                                    Ok, so it's cubic 4 X 4 Bezier Patch. (As can be seen).
                                    The idea I had was to conform my surfaces(from the node editor) to be valid with your nice editing possibilities after baked down to Sketchup.
                                    I've built a simple translation-Gizmo for moving points(must have that at least) but your editing abilities are way more advanced. More than I would need actually in my GUI, since mostly dependent on parameter values..
                                    This would be at a later stage anyway. There is still plenty of Math to deal with 😄
                                    In all case.
                                    Congratulations to this version! The Gizmo is spectacular. 👍
                                    BTW
                                    I don't know if you are gonna continue updating this plugin, since focus is on the subdivision pligin. But if you do and stay with Beziers, have you had a look at the power basis forms ? I studied them a little before since easier to grasp.
                                    They are used a lot in gamers code.
                                    They should perform better.
                                    It's also possible to have other degree curves with different matrix.
                                    For example a 3 X 3 Patch with degree 2 Power basis.
                                    Although the @last Bezier code base the degree on n_points so that should be the same.. ?
                                    (this is for a curve)
                                    #                      │ −1  3 −3 1 │   │ P1 │     MATRIX FORM for Cubic Bezier with 4 controlpoints.
                                    # P(t) = [t³ t² t 1] · │  3 −6  3 0 │ . │ P2 │
                                    #                      │ −3  3  0 0 │   │ P3 │
                                    #                      │  1  0  0 0 │   │ P3 │
                                    # t = interval-value between 0 and 1. t2 = t*t, t3 = t2*t
                                    # For even greater efficiency a,b,c,t3 coefficients could be cached and reused,
                                    # and updated when interval/subd changes.
                                    def power_basis(t3,t2,t, p0, p1, p2, p3)
                                    	# Calculate 4 coefficients (MATRIX T*U) where 4th coefficient is simply reusing t3
                                    	a = t3*(-1) + t2*3    + t*(-3) + 1
                                    	b = t3*3    + t2*(-6) + t*3
                                    	c = t3*(-3) + t2*3
                                    	# Calculate Points coordinates (MATRIX U*V)
                                    	x = a*p0.x + b*p1.x + c*p2.x + t3*p3.x
                                        y = a*p0.y + b*p1.y + c*p2.y + t3*p3.y
                                        z = a*p0.z + b*p1.z + c*p2.z + t3*p3.z
                                    	return Geom;;Point3d.new(x,y,z) # Return 1 point from interpolation
                                    • BoxB
                                      I found a little problem with it.
                                      If you scale to 0 as a way of straightening an edge it freezes and won't update the surface. If you get out of edit mode and go back in an move a point it will revert to the unscaled skin.
                                      http://i155.photobucket.com/albums/s296/storeben/SU/0Scale.gif
                                        @box
                                        I'm not seeing that occur for me
                                        • BoxB
                                          IT doesn't happen on all axis, I have yet to determine exactly when it happens, but I will pin it down.
                                          • BoxB
                                            Try this and see if it is just me.
                                            The patch is drawn up the blue along the red. Second patch added, joint moved up on the blue. Select the two edges(3 points) on the red and scale to 0.
                                            Please excuse the sloppy movements, I find it's very hard to maneuver on a trackpad.
                                            http://i155.photobucket.com/albums/s296/storeben/SU/Red.gif
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
