    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.6k Views 69 Watching
      @box said:
      This rough test torso is less than five minutes work.
      Really? 😲 I didn't expect the extension to be that useful in it's current state. I hope people do post back more picture.
      • OxerO
        Oxer
        Thanks you very much for the plugin!! πŸ‘ πŸ‘
        I installed it in SU2014 & SU2015 on Mac but the plugin didn't work, I found a conflict with smartdrop.rb and Sketchyphysics, I deleted smartdrop.rb (I use tt.raytracer now to drop components) and I have deactivated Sketchyphysics on SU2014 with Sketchucation Plugins Manager and Bezier Surface work fine now.
          @panixia said:
          it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
          i suppose i installed it properly and also updated ttlib to last version..
          i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
          Should work with SU7 and up, I think. Any error messages?
            Same here. I only had it working in 2014.
            Error "defined method `force_encoding' for #String:0xb10993c"
            This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
            Yea, with my new subdivison extension I'm certainly dropping support for anything older than SU2014.
            Though this was written before SU2014 and it should work. (Though might have introduced a bug when I added SU2014 support. Can you provide the full error message and exact SketchUp version and OS?)
              @panixia said:
              yeah. force encoding blablabla.. getting similar message when loading sketchup
              The bla bla bla bit of error message is in fact very useful for developers when debugging errors - please post all of it when reporting issues.
                @jolran said:
                It may have be a condition set on line 26 in the loader rb
                "file = FILE.dup.force_encoding("UTF-8")"
                Ah - right, I'll fix that and push an update next week.
                  @unclex said:
                  It's just always updating...
                  Like the GIF[attachment=0:1br0oo34]<!-- ia0 -->8.gif<!-- ia0 -->[/attachment:1br0oo34]
                  Cannot Click or DoubleClick
                  and when SU opening, nothing prompt
                  Any errors in the Ruby Console?
                  What SketchUp version?
                    SketchyPhysics is known to clash with extensions. I think an update is coming.
                    Not sure about smartdrop.rb - not familiar with that one.
                    • OxerO
                      Oxer
                      A quick test taking like reference the torso of Box.
                      • panixiaP
                        panixia
                        i'm pretty much sure that the "blablabla" part of the message returned ad least 3 different values with different tries (that's pretty odd i suppose) the last try being: "Loading File tt_bezier_surface.rb
                        undefined method `force_encoding' for #String:0xec947b8no such file to load --" 😲
                        hope this can help
                          I'll mainly focus on my subdivision extension over this one. Though I'll try to maintain small bug fixes and pull requests. I'll see after SUbD is done what I do with this project.
                          Btw, I have a fix for the compatibility bug with SU2013 and older. I'll be pushing an update.
                          • jolranJ
                            jolran
                            I understand.
                            πŸ‘
                              When there is incompatibility (Sketchyphysics 3, SKalp, (my case) etc...
                              Who is faulty ? These plugins or Bezier Surface ?
                              @oxer : Rodin 2 πŸ˜„
                                Bezier Surface is confined to its own namespace - so the only thing I can think of would be possibly other extension clashing with observers. SketchyPhysics has been known to clash with many extensions - though I'm not sure if it's been updated recently to address that.
                                Odd if Skalp clashes... maybe observer fights?
                                Do you get any errors in the Ruby Console?
                                  See my previous posts from here
                                  Messages were the same that the restant on my post linked πŸ˜‰
                                  So for have no message errors I disconnect plugins after plugins.
                                  • CadFatherC
                                    CadFather
                                    ok, in my case progressbar.rb is the culprit
                                    now it's smartdrop
                                    it changes.. πŸ˜†
                                    • U
                                      unclex
                                      @thomthom said:
                                      Re: [Plugin][WIP][OpenSource] Bezier Surface
                                      Postby thomthom Β» Mon Nov 24, 2014 4:18 am
                                      unclex wrote:It's just always updating...
                                      Like the GIF
                                      Now I Know what happened
                                      Smartdrop clash with TTlib2
                                      something named "definition"
                                      so I change "definition" to "a4sddefinition" @ smartdrop.rb
                                      and it works
                                      Smartdrop.rb
                                      • jeff hammondJ
                                        here's a simple introductory example.. maybe something a lot of people can use..
                                        seamless background for rendering
                                        1- draw the patch next to a flat plane:
                                        2- double click the patch to enter the editing mode.. select the back line:
                                        3- using the blue arrow on the gizmo, move the edge vertical:
                                        4- using the red arc, rotate the edge downwards 90ΒΊ (degrees will be shown in the measurement box)
                                        5- using the blue square, scale downwards.. align the green control point with the green axis
                                        6- change the segmentation in the measurements box (i think i used 20)
                                        • jolranJ
                                          jolran
                                          Wow, this topic is moving fast now. πŸ˜„
                                          Ok, so it's cubic 4 X 4 Bezier Patch. (As can be seen).
                                          The idea I had was to conform my surfaces(from the node editor) to be valid with your nice editing possibilities after baked down to Sketchup.
                                          I've built a simple translation-Gizmo for moving points(must have that at least) but your editing abilities are way more advanced. More than I would need actually in my GUI, since mostly dependent on parameter values..
                                          This would be at a later stage anyway. There is still plenty of Math to deal with πŸ˜„
                                          In all case.
                                          Congratulations to this version! The Gizmo is spectacular. πŸ‘
                                          BTW
                                          I don't know if you are gonna continue updating this plugin, since focus is on the subdivision pligin. But if you do and stay with Beziers, have you had a look at the power basis forms ? I studied them a little before since easier to grasp.
                                          They are used a lot in gamers code.
                                          They should perform better.
                                          It's also possible to have other degree curves with different matrix.
                                          For example a 3 X 3 Patch with degree 2 Power basis.
                                          Although the @last Bezier code base the degree on n_points so that should be the same.. ?
                                          (this is for a curve)
                                          #                      β”Œ            ┐   β”Œ    ┐
                                          #                      β”‚ βˆ’1  3 βˆ’3 1 β”‚   β”‚ P1 β”‚     MATRIX FORM for Cubic Bezier with 4 controlpoints.
                                          # P(t) = [tΒ³ tΒ² t 1] Β· β”‚  3 βˆ’6  3 0 β”‚ . β”‚ P2 β”‚
                                          #                      β”‚ βˆ’3  3  0 0 β”‚   β”‚ P3 β”‚
                                          #                      β”‚  1  0  0 0 β”‚   β”‚ P3 β”‚
                                          #                      β””            β”˜   β””    β”˜
                                          # t = interval-value between 0 and 1. t2 = t*t, t3 = t2*t
                                          # For even greater efficiency a,b,c,t3 coefficients could be cached and reused,
                                          # and updated when interval/subd changes.
                                          def power_basis(t3,t2,t, p0, p1, p2, p3)
                                          	# Calculate 4 coefficients (MATRIX T*U) where 4th coefficient is simply reusing t3
                                          	a = t3*(-1) + t2*3    + t*(-3) + 1
                                          	b = t3*3    + t2*(-6) + t*3
                                          	c = t3*(-3) + t2*3
                                          	# Calculate Points coordinates (MATRIX U*V)
                                          	x = a*p0.x + b*p1.x + c*p2.x + t3*p3.x
                                              y = a*p0.y + b*p1.y + c*p2.y + t3*p3.y
                                              z = a*p0.z + b*p1.z + c*p2.z + t3*p3.z
                                          	return Geom;;Point3d.new(x,y,z) # Return 1 point from interpolation
                                          • BoxB
                                            I found a little problem with it.
                                            If you scale to 0 as a way of straightening an edge it freezes and won't update the surface. If you get out of edit mode and go back in an move a point it will revert to the unscaled skin.
                                            http://i155.photobucket.com/albums/s296/storeben/SU/0Scale.gif
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
