    Measurment text in black area
    24 Posts 5 Posters 4.4k Views 5 Watching
    • robertWanR Offline
      robertWan
      Why while printing with HLR option turned on there are appearing black "highlights" of measurement text. SU8.
      Robert
        You might try changing OpenGL settings but at this point you can pretty much assume SU8 isn't going to get any changes. Does it happen for you with SU2015?
          robertWan
          But it happens only when printing. It is visible only on the print.
          Su2015 doesn`t work with WinXP.
          Robert
            Did you try changing the OpenGL settings anyway?
              robertWan
              Yes, I've tried any possible OpenGL settings, which are in System preferences window.
              Robert
                Sketchup menu > Window > Preferences > OpenGL ...
                  robertWan
                  Of course, I changed OpenGL in SU. No effects.
                  Robert
                    Did you try turning off Hardware Acceleration?
                      robertWan
                      Yes. All combinations.
                      Robert
                        kaas
                        just for testing: have you tried a different pdf-printer like bullzip? Also, the object behind the text wouldn't have opacity applied to it? If so, did you try different opacity settings in the style?
                          I can print HLR PDFs using PDF995, without any graphic glitches...
                          So it is probably either an issue with your PDF-maker or a Graphics Card issue ?
                            robertWan
                            I've noticed that it only happens with measurements which are aligned to dimension line.
                            Robert
                              Yes !
                              A break through...
                              I too confirm that only if the dim-text is 'aligned', then the HLR PDF shows a black rectangle.
                              Without the HLR setting they all print OK !
                                robertWan
                                So it is a bug? In SU2014 same.
                                How is it in SU2015?
                                Robert
                                  I don't see it in 2015.
                                    I see it in v2015.
                                      I wonder why I don't have any issue on my machine with this.
                                        Charlie__V
                                        @tig said:
                                        I see it in v2015.
                                        +1
                                        Camera set to Parallel Projection....default views (top/front/right..etc) gives expected results.
                                        Perspective views not so much.
                                        Charlie
                                        SUv15
                                        MS Win7 64 Bit
                                          kaas
                                          maybe its due to different gfx cards / gfx card settings / OS versions / ...?
                                            Charlie__V
                                            Could still be Print Driver........I am using Adobe Acrobat ProXI.
                                            Charlie
                                            • 2 / 2
