    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 319.4k Views 89 Watching
    • V Offline
      valerostudio
      Same here in Win7 64 bit - I hit the button and nothing.
        Your message is at odds with the ones following the update πŸ˜•
        Works fine for me in Win7 64bit !
        You do have the latest version installed from the PluginStore?
        You have restarted SketchUp ?
        AND you have removed any earlier versions of the tool before this ?
        Are there any error messages in the Ruby Console ?
        When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
        More feedback please...
        • BoxB Offline
          Make sure you have a surface to spray on.
          • soloS Offline
            same here and I do have a plane to spray on.
            • BoxB Offline
              As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
                What button exactly ?
                Also any Ruby Console errors ?
                Have you definitely removed all of the legacy stuff before installing it ?
                Some of you were installing the older version into the Tools folder, and all manner of foolishness !
                The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently πŸ˜•
                • soloS Offline
                  Error; #<NoMethodError; undefined method `dec' for 0.0;Length>
                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize'
                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new'
                  c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main'
                  C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>'
                  SketchUp;1;in `call'
                    @Solo
                    Now I see... β˜€
                    Didier's code [ill advisedly] messes with 'Float'.
                    I suspect it adds 'dec' as a method.
                    In v2015 'Length' is somewhat divorced from 'Float', so his method 'dec' is probably orphaned with some Units set ups !
                    I look at a fix and update when I can...
                      I think that this updated version will now work in v2015 with all units settings...
                      http://sketchucation.com/pluginstore?pln=compoSpray Please try it, and report back...
                      • chonC Offline
                        chon
                        Many thanks TIG ! πŸ‘
                        Works fine for me with AdditionalPluginFolders !!
                        • soloS Offline
                          πŸ‘
                          Thanks Tig, working now.
                          • V Offline
                            valerostudio
                            Yes, working. Made sure to delete any old versions and working now in 2015 x64 Win7. HUGE THANKS!!!!
                            • V Offline
                              valerostudio
                              When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                Didier's code is Byzantine in its complexity !
                                I suspect it's because he used 'break' in the earlier version that itself broke in Ruby2.
                                I replaced it with 'return', but that does nothing !
                                Maybe the earlier 'break' effectively stopped the tool ?
                                I'll look through and see if I can adjust things...
                                  Here's an updated version in the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                                  Now if you are about to add thousands of components and the warning dialog asks if you want to proceed and you answer NO, then the tool quits and the dialog closes.
                                  Answer YES and it continues...
                                  • CadFatherC Offline
                                    CadFather
                                    now it is perfect. thank you TIG πŸ‘
                                    • V Offline
                                      valerostudio
                                      Actually I just got a Bugsplat when it tried to close. 😒
                                        Please outline your steps.
                                        e.g. what was open, or what was the last thing you did when you closed and splatted ?
                                        • chonC Offline
                                          chon
                                          TIG,
                                          with your last version, i've got the same problem as Shape Bender, it works fine when i put the CompoSpray plugin in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins folder, but it doesn't work when i put it my Fredo6's AdditionalPluginFolder. 😳
                                          I've got that : When you get the warning box that it will take X minutes to complete and you click NO the box doesn't go away and the plugin will not close.
                                          Any suggestion ? πŸ˜•
                                            @chon said:
                                            TIG,
                                            I deliberately removed the limitations of using when loading from a non-default Plugins folder - I have it working from a custom-folder on my PC, so it works - and so something is adrift with your set up...
                                            Do you have the very latest version from the PluginStore ?
                                            I also did a fix to stop when you say so...
                                            That leads me to suspect you haven't installed the latest version in your custom-folder ?
                                            How are you installing it ?
                                            The SketchUcation submenu > Archive Installer... will install an RBZ in a custom-folder...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
