    SketchUp 2015 is 64bit
    302 Posts 74 Posters 121.7k Views 74 Watching
    • tt_suT
      tt_su
      @hellnbak said:
      Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
      And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
      They seem to be getting serious about making changes that really matter.
      Kudos, Trimble ๐Ÿ‘
      We're just getting warmed up! ๐Ÿ˜Ž It takes time to turn a big boat around. ๐Ÿ˜‰
      • srxS
        srx
        http://www.michaelspornanimation.com/splog/wp-content/uploads/2013/02/toot17.jpg
        www.saurus.rs
          meanmrmustard85
          Hi - Any advice on whether V-Ray 2.0 is compatible with 2015? Want to make sure before I upgrade and wipe out our rendering capability!
          • N
            numerobis
            so, finally... 64bit. Thanks!
            And if the slow exploding/importing is really improved, this is even better!
            And the PhotoMatch upgrade looks very useful
            http://help.sketchup.com/en/article/3000075
            http://help.sketchup.com/en/article/1004436
            Is this working with manually imported photos or only with images imported via special Trimble software?
            Concerning the new license system... so it is possible to install v8 and 2015 side by side and i'm not loosing my v8 license, right?
            (the new arc and rectangle tools are nice to have but not really worth mentioning i think, the same applies to the fast styles - i suppose it will not be faster than simple lines...)
              It's exactly the same as it's always been. You can have multiple versions installed and one license doesn't affect the other. They are entirely separate installations. And in case you haven't seen this before: Do not simply copy plugins from your old SU8 installation to SU2015. It's been repeat ad nauseum for most of the last year so you should have seen it by now.
                Might be worth getting in touch with the V-ray people and get the information from the source.
                  The only downside I can see at the moment is that we now have 64 bit but I cannot think of a thing to do with it. No rendering for some time I reckon but at least I can get the modelling done in preparation. I just hope it is not too long for renders to begin.
                  • N
                    numerobis
                    Thanks! ๐Ÿ˜„
                    • BoxB
                      And as has been pointed out, you can run both side by side. Which means even if Vray doesn't yet work with 2015 you can still model in it and render in 2014.
                      • olisheaO
                        olishea
                        Congratulations SU team. This is a huge advancement for SketchUp. I was getting so frustrated with the software but now it's onwards and upwards I guess. ๐Ÿ˜„
                        oli
                        • bmikeB
                          bmike
                          Guess you have to go get it 'manually'?
                          • jujuJ
                            juju
                            +1
                            • FrederikF
                              Frederik
                              Not sure you'll get a message from the "Update" as this is an "UpGrade"... ๐Ÿ˜„
                              Cheers
                              Kim Frederik
                              • Tyler MillerT
                                Tyler Miller
                                [attachment=0:3g8mdq0x]<!-- ia0 -->Screen Shot 2014-11-04 at 10.06.20 AM.png<!-- ia0 -->[/attachment:3g8mdq0x]
                                Yes, for the moment. We typically wait a day or two to make sure everything is running smoothly before turning on the update service in previous versions.
                                  meanmrmustard85
                                  Thanks, that makes sense.
                                  Spoke to Chaosgroup and they're working on a free update for release as soon as possible.
                                  • N
                                    numerobis
                                    I think it has to be recompiled to 64 bit. At least the Maxwell plugin needs an update...
                                    • Al HartA
                                      Al Hart
                                      The SketchUp description of 64 bit says: "The exception to this 32-bit status is that SketchUp for Windows has been built with an exception to allow 64-bit memory usage which allows SketchUp to use more than 4 Gb of RAM."
                                      http://help.sketchup.com/en/article/3000069
                                      DO you think the second use of the word exception is a mistake, or do you think SketchUp found a way to create a "pseudo" 64-bit - which uses more memory, but isn't really recompiled for 64 bits?
                                      Al Hart
                                      IRender nXt from Render Plus
                                        driven
                                        @Al, if you read the prominent notice at the top of the page...
                                        NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
                                        I think you will find your looking at v2014...
                                        • KrisidiousK
                                          Krisidious
                                          Why would plugins need to be recompiled then? And that would mean Mac was not 64 bit at all?
                                          By: Kristoff Rand
                                          • AndrewSA
                                            AndrewS
                                            You're looking at the wrong version of the article--for 2014 instead of 2015. Go back to that article and read the bright red warning at the top that tells you to use the dropdown menu to change to the 2015 article. Then you'll see what you'd expect.
                                            SketchUp 2015 x64 is absolutely, 100%, without a doubt, compiled for native 64-bit execution. The exception message was in regard to 2013 and 2014.
                                            Andrew
                                            Andrew S.
                                            SketchUp Release Engineer
                                            • 15
                                            • 16
                                            • 3 / 16
