    SketchUp 2015 is 64bit
    302 Posts 74 Posters 115.5k Views 74 Watching
      Don't draw one rectangle on top of another. ๐Ÿ˜„
      • BoxB
        Dave you're always a font of good advice, one might even say you are full of it.
        • hellnbakH
          hellnbak
          ๐Ÿคฃ
          • tt_suT
            tt_su
            @hellnbak said:
            Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
            And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
            They seem to be getting serious about making changes that really matter.
            Kudos, Trimble ๐Ÿ‘
            We're just getting warmed up! ๐Ÿ˜Ž It takes time to turn a big boat around. ๐Ÿ˜‰
            • srxS
              srx
              http://www.michaelspornanimation.com/splog/wp-content/uploads/2013/02/toot17.jpg
              www.saurus.rs
                meanmrmustard85
                Hi - Any advice on whether V-Ray 2.0 is compatible with 2015? Want to make sure before I upgrade and wipe out our rendering capability!
                • N
                  numerobis
                  so, finally... 64bit. Thanks!
                  And if the slow exploding/importing is really improved, this is even better!
                  And the PhotoMatch upgrade looks very useful
                  http://help.sketchup.com/en/article/3000075
                  http://help.sketchup.com/en/article/1004436
                  Is this working with manually imported photos or only with images imported via special Trimble software?
                  Concerning the new license system... so it is possible to install v8 and 2015 side by side and i'm not loosing my v8 license, right?
                  (the new arc and rectangle tools are nice to have but not really worth mentioning i think, the same applies to the fast styles - i suppose it will not be faster than simple lines...)
                    It's exactly the same as it's always been. You can have multiple versions installed and one license doesn't affect the other. They are entirely separate installations. And in case you haven't seen this before: Do not simply copy plugins from your old SU8 installation to SU2015. It's been repeat ad nauseum for most of the last year so you should have seen it by now.
                      Might be worth getting in touch with the V-ray people and get the information from the source.
                        The only downside I can see at the moment is that we now have 64 bit but I cannot think of a thing to do with it. No rendering for some time I reckon but at least I can get the modelling done in preparation. I just hope it is not too long for renders to begin.
                        • N
                          numerobis
                          Thanks! ๐Ÿ˜„
                          • BoxB
                            And as has been pointed out, you can run both side by side. Which means even if Vray doesn't yet work with 2015 you can still model in it and render in 2014.
                            • olisheaO
                              olishea
                              Congratulations SU team. This is a huge advancement for SketchUp. I was getting so frustrated with the software but now it's onwards and upwards I guess. ๐Ÿ˜„
                              oli
                              • bmikeB
                                bmike
                                Guess you have to go get it 'manually'?
                                • jujuJ
                                  juju
                                  +1
                                  • FrederikF
                                    Frederik
                                    Not sure you'll get a message from the "Update" as this is an "UpGrade"... ๐Ÿ˜„
                                    Cheers
                                    Kim Frederik
                                    • Tyler MillerT
                                      Tyler Miller
                                      [attachment=0:3g8mdq0x]<!-- ia0 -->Screen Shot 2014-11-04 at 10.06.20 AM.png<!-- ia0 -->[/attachment:3g8mdq0x]
                                      Yes, for the moment. We typically wait a day or two to make sure everything is running smoothly before turning on the update service in previous versions.
                                        meanmrmustard85
                                        Thanks, that makes sense.
                                        Spoke to Chaosgroup and they're working on a free update for release as soon as possible.
                                        • N
                                          numerobis
                                          I think it has to be recompiled to 64 bit. At least the Maxwell plugin needs an update...
                                          • Al HartA
                                            Al Hart
                                            The SketchUp description of 64 bit says: "The exception to this 32-bit status is that SketchUp for Windows has been built with an exception to allow 64-bit memory usage which allows SketchUp to use more than 4 Gb of RAM."
                                            http://help.sketchup.com/en/article/3000069
                                            DO you think the second use of the word exception is a mistake, or do you think SketchUp found a way to create a "pseudo" 64-bit - which uses more memory, but isn't really recompiled for 64 bits?
                                            Al Hart
                                            IRender nXt from Render Plus
                                            • 15
                                            • 16
                                            • 3 / 16
