    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.4k Views 20 Watching
      jpalm32
      @careca said:
      "...with Maintenance 2 release, ACT installs with SketchUp 8.
      Not free version! Unless I'm getting a missing module.
        mirale999
        Great plugin~ I was worrying how to compare two designs the very last minute~
        paranoia is a higher form of awareness...
        • F
          floffy1983
          Works exactly as advertised,thank you.
            ACT is a Pro-only add-on...
            Just like LayOut, Solid tools, some Exporters/Importers etc...
            • G
              grasset17
              Merci beaucoup pour ce script qui fonctionne à merveille
              • Q
                qazokm
                Finally I found it, thanks
                • lsztukaL
                  lsztuka
                  I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
                  • OxerO
                    Oxer
                    Thanks you very much!! 👍
                    Very useful for a project that I'm working on.
                    • halroachH
                      halroach
                      Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
                      Basically exporting/importing whole scenes, and not just the cameras?
                      FlexTools - Super Quick Windows, Doors, Slats...
                      • OxerO
                        Oxer
                        Hi again,
                        I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
                        Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
                        The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
                        If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
                        SU_export_camera.txt file generated by SU2013
                        Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
                        SU_export_camera.txt file generated by SU2014
                        ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                          This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                          Here is how to fix it...
                          Open the file in Notepad++ on PC or TextWrangler on the MAC.
                          Find line #152, which reads:
                          myfile.write(new_array_entry.to_s)
                          Change it to read
                          if Sketchup.version.to_i < 14
                          else ### >=v2014
                            new_array_entry.each{|e| myfile.write(e) }
                          Save it and restart SketchUp.
                          Now it should write the same format of data-file in all versions of SketchUp.
                          The import [reading] part should remain unaffected across versions...
                            Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
                            • OxerO
                              Oxer
                              Thanks TIG!!
                              • ToboboT
                                Tobobo
                                Thank you TIG 👍
                                Toby
                                Philippians 4:13
                                • F
                                  faust07
                                  Thank you careca and TIG - this plugin has saved my day!
                                  • P
                                    poiseis
                                    2d perspective scenes are not exported properly, i hope you add that features soon.
                                    • romboutR
                                      rombout
                                      Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                                      Does anyone know a trick or script?
                                      • jujuJ
                                        juju
                                        a quick search
                                        • in the SketchUcation plugin store
                                          http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                                        • in the extension warehouse
                                          http://extensions.sketchup.com/en/search/site/camera
                                          mshdyh
                                          找了这个插件很久了,修改后可以使用,自己修改了下界面换成中文了。
                                          • aomaoA
                                            aomao
                                            你好 我发现1.2版的这个插件在处理两点透视(并且缩放平移过)的相机时会出现问题,直观来说就是无法正确的导出和导入,我看了下代码,不知是不是因为没有加入“CX,CY,比例”这三个参数(在普通机位,这三个数值分别为0,0,1),如果是的话,我想请教如何自行添加?如果不是话,那无法正确处理两点透视相机的问题在哪里?
                                            • 2 / 2
