    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.9k Views 20 Watching
      Aerilius
      In addition to using a module, avoid any hard-coded file paths:
      %(#000000)[D:\SU_camera_export.txt] does most likely not exist.
      An alternative is to use environment variables ( %(#000000)[ENV["TEMP"]||(ENV["TMP"]]; %(#000000)[ENV["USERPROFILE"]||ENV["HOME"]]) to get a default path or to ask the user directly for a path.
      Example:
      mypath = [UI.savepanel](https://developers.google.com/sketchup/docs/ourdoc/ui#openpanel)("Save the camera settings") return if mypath.nil? mypath = [File.expand_path](http://www.ruby-doc.org/core-1.8.6/File.html#method-c-expand_path)(mypath) myfile = File.new(mypath, "w")
      UI.messagebox exported_cams.to_s + " Cameras were successfully exported to #{mypath}"
      Lastly file_loaded?("camera_export_import.rb") does not look up a file path but just an arbitrary string. That means after the file has loaded, we have to tell it SketchUp at the end of the file by using the same string: file_loaded("camera_export_import.rb")
      Otherwise it looks good for the first script! πŸ‘ We are always happy if people accomplish the first step . Once you're infected by Ruby, you can not get away from it.
      • C
        careca
        hi Aerilius, thomthom, all.
        thanks for the feedback, i have updated the script accordingly and replaced it in my original post.
        regards,
        martin
        p.s. advanced camera tools would be great - maybe you can convince our sysadmins to install it for us πŸ˜‰
          Should be bundled with SketchUp 8... Maybe you need to enable it under you list of Extensions?
          Anyway - looking forward to seeing more plugin creations! πŸ˜„
            rv1974
            Could you add support for hidden geometry, visible layers, style and shadows please?
              jpalm32
              Is that a pro tool only? Not in my free 8.
              Not in Ext. list either
                Ah! Now that's a good point! Could very well be a Pro feature. Didn't think of that. 😳
                • C
                  careca
                  Re: [Plugin] Camera Settings Export/Import
                  Postby rv1974 on Wed Aug 29, 2012 11:36 am
                  thanks for your comment - but to be honest, this was not the intention of this plugin, I only wanted to transfer camera settings between files. going into "hidden geometry, visible layers, style and shadows" will require to write a script for transferring complete scenes/pages, a completely different approach...
                  martin
                  • C
                    careca
                    "...with Maintenance 2 release, ACT installs with SketchUp 8.
                      jpalm32
                      Not free version! Unless I'm getting a missing module.
                        mirale999
                        Great plugin~ I was worrying how to compare two designs the very last minute~
                        paranoia is a higher form of awareness...
                        • F
                          floffy1983
                          Works exactly as advertised,thank you.
                            ACT is a Pro-only add-on...
                            Just like LayOut, Solid tools, some Exporters/Importers etc...
                            • G
                              grasset17
                              Merci beaucoup pour ce script qui fonctionne Γ  merveille
                              • Q
                                qazokm
                                Finally I found it, thanks
                                • lsztukaL
                                  lsztuka
                                  I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
                                  • OxerO
                                    Oxer
                                    Thanks you very much!! πŸ‘
                                    Very useful for a project that I'm working on.
                                    • halroachH
                                      halroach
                                      Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
                                      Basically exporting/importing whole scenes, and not just the cameras?
                                      FlexTools - Super Quick Windows, Doors, Slats...
                                      • OxerO
                                        Oxer
                                        Hi again,
                                        I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
                                        Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
                                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
                                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
                                        /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
                                        The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
                                        If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
                                        SU_export_camera.txt file generated by SU2013
                                        Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
                                        SU_export_camera.txt file generated by SU2014
                                        ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                                          This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                                          Here is how to fix it...
                                          Open the file in Notepad++ on PC or TextWrangler on the MAC.
                                          Find line #152, which reads:
                                          myfile.write(new_array_entry.to_s)
                                          Change it to read
                                          if Sketchup.version.to_i < 14
                                          else ### >=v2014
                                            new_array_entry.each{|e| myfile.write(e) }
                                          Save it and restart SketchUp.
                                          Now it should write the same format of data-file in all versions of SketchUp.
                                          The import [reading] part should remain unaffected across versions...
                                            Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
