    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.4k Views 20 Watching
    • G
      grasset17
      Merci beaucoup pour ce script qui fonctionne à merveille
      • Q
        qazokm
        Finally I found it, thanks
        • lsztukaL
          lsztuka
          I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
          • OxerO
            Oxer
            Thanks you very much!! 👍
            Very useful for a project that I'm working on.
            • halroachH
              halroach
              Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
              Basically exporting/importing whole scenes, and not just the cameras?
              FlexTools - Super Quick Windows, Doors, Slats...
              • OxerO
                Oxer
                Hi again,
                I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
                Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
                /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
                /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
                /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
                The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
                If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
                SU_export_camera.txt file generated by SU2013
                Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
                SU_export_camera.txt file generated by SU2014
                ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                  This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                  Here is how to fix it...
                  Open the file in Notepad++ on PC or TextWrangler on the MAC.
                  Find line #152, which reads:
                  myfile.write(new_array_entry.to_s)
                  Change it to read
                  if Sketchup.version.to_i < 14
                  else ### >=v2014
                    new_array_entry.each{|e| myfile.write(e) }
                  Save it and restart SketchUp.
                  Now it should write the same format of data-file in all versions of SketchUp.
                  The import [reading] part should remain unaffected across versions...
                    Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
                    • OxerO
                      Oxer
                      Thanks TIG!!
                      • ToboboT
                        Tobobo
                        Thank you TIG 👍
                        Toby
                        Philippians 4:13
                        • F
                          faust07
                          Thank you careca and TIG - this plugin has saved my day!
                          • P
                            poiseis
                            2d perspective scenes are not exported properly, i hope you add that features soon.
                            • romboutR
                              rombout
                              Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                              Does anyone know a trick or script?
                              • jujuJ
                                juju
                                a quick search
                                • in the SketchUcation plugin store
                                  http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                                • in the extension warehouse
                                  http://extensions.sketchup.com/en/search/site/camera
                                  mshdyh
                                  找了这个插件很久了,修改后可以使用,自己修改了下界面换成中文了。
                                  • aomaoA
                                    aomao
                                    你好 我发现1.2版的这个插件在处理两点透视(并且缩放平移过)的相机时会出现问题,直观来说就是无法正确的导出和导入,我看了下代码,不知是不是因为没有加入“CX,CY,比例”这三个参数(在普通机位,这三个数值分别为0,0,1),如果是的话,我想请教如何自行添加?如果不是话,那无法正确处理两点透视相机的问题在哪里?
                                      rcnorve
                                      Re: [Plugin] Camera Settings Export/Import
                                      Is there an update for this plugin that works in 2023?
                                      Thanks!!
                                      • 2 / 2
