    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 53.5k Views 20 Watching
    • F Offline
      floffy1983
      Works exactly as advertised,thank you.
        ACT is a Pro-only add-on...
        Just like LayOut, Solid tools, some Exporters/Importers etc...
          grasset17
          Merci beaucoup pour ce script qui fonctionne à merveille
          • Q Offline
            qazokm
            Finally I found it, thanks
            • lsztukaL Offline
              lsztuka
              I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
              • OxerO Offline
                Oxer
                Thanks you very much!! 👍
                Very useful for a project that I'm working on.
                • halroachH Offline
                  halroach
                  Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
                  Basically exporting/importing whole scenes, and not just the cameras?
                  FlexTools - Super Quick Windows, Doors, Slats...
                  • OxerO Offline
                    Oxer
                    Hi again,
                    I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
                    Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
                    /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
                    The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
                    If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
                    SU_export_camera.txt file generated by SU2013
                    Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
                    SU_export_camera.txt file generated by SU2014
                    ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                      This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                      Here is how to fix it...
                      Open the file in Notepad++ on PC or TextWrangler on the MAC.
                      Find line #152, which reads:
                      myfile.write(new_array_entry.to_s)
                      Change it to read
                      if Sketchup.version.to_i < 14
                      else ### >=v2014
                        new_array_entry.each{|e| myfile.write(e) }
                      Save it and restart SketchUp.
                      Now it should write the same format of data-file in all versions of SketchUp.
                      The import [reading] part should remain unaffected across versions...
                        Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
                        • OxerO Offline
                          Oxer
                          Thanks TIG!!
                          • ToboboT Offline
                            Tobobo
                            Thank you TIG 👍
                            Toby
                            Philippians 4:13
                            • F Offline
                              faust07
                              Thank you careca and TIG - this plugin has saved my day!
                                poiseis
                                2d perspective scenes are not exported properly, i hope you add that features soon.
                                • romboutR Offline
                                  rombout
                                  Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                                  Does anyone know a trick or script?
                                  • jujuJ Offline
                                    juju
                                    a quick search
                                    • in the SketchUcation plugin store
                                      http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                                    • in the extension warehouse
                                      http://extensions.sketchup.com/en/search/site/camera
                                      mshdyh
                                      找了这个插件很久了,修改后可以使用,自己修改了下界面换成中文了。
                                      • aomaoA Offline
                                        aomao
                                        你好 我发现1.2版的这个插件在处理两点透视(并且缩放平移过)的相机时会出现问题,直观来说就是无法正确的导出和导入,我看了下代码,不知是不是因为没有加入“CX,CY,比例”这三个参数(在普通机位,这三个数值分别为0,0,1),如果是的话,我想请教如何自行添加?如果不是话,那无法正确处理两点透视相机的问题在哪里?
                                          rcnorve
                                          Re: [Plugin] Camera Settings Export/Import
                                          Is there an update for this plugin that works in 2023?
                                          Thanks!!
                                          • 2 / 2
