    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.9k Views 20 Watching
    • OxerO
      Oxer
      Hi again,
      I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
      Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
      /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
      The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
      If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
      SU_export_camera.txt file generated by SU2013
      Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
      SU_export_camera.txt file generated by SU2014
      ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
        This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
        Here is how to fix it...
        Open the file in Notepad++ on PC or TextWrangler on the MAC.
        Find line #152, which reads:
        myfile.write(new_array_entry.to_s)
        Change it to read
        if Sketchup.version.to_i < 14
        else ### >=v2014
          new_array_entry.each{|e| myfile.write(e) }
        Save it and restart SketchUp.
        Now it should write the same format of data-file in all versions of SketchUp.
        The import [reading] part should remain unaffected across versions...
          Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
          • OxerO
            Oxer
            Thanks TIG!!
            • ToboboT
              Tobobo
              Thank you TIG 👍
              Toby
              Philippians 4:13
              • F
                faust07
                Thank you careca and TIG - this plugin has saved my day!
                • P
                  poiseis
                  2d perspective scenes are not exported properly, i hope you add that features soon.
                  • romboutR
                    rombout
                    Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                    Does anyone know a trick or script?
                    • jujuJ
                      juju
                      a quick search
                      • in the SketchUcation plugin store
                        http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                      • in the extension warehouse
                        http://extensions.sketchup.com/en/search/site/camera
                        mshdyh
                        找了这个插件很久了,修改后可以使用,自己修改了下界面换成中文了。
                        • aomaoA
                          aomao
                          你好 我发现1.2版的这个插件在处理两点透视(并且缩放平移过)的相机时会出现问题,直观来说就是无法正确的导出和导入,我看了下代码,不知是不是因为没有加入“CX,CY,比例”这三个参数(在普通机位,这三个数值分别为0,0,1),如果是的话,我想请教如何自行添加?如果不是话,那无法正确处理两点透视相机的问题在哪里?
                            rcnorve
                            Re: [Plugin] Camera Settings Export/Import
                            Is there an update for this plugin that works in 2023?
                            Thanks!!
                            • 2 / 2
