    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.9k Views 20 Watching
    • C
      careca
      Re: [Plugin] Camera Settings Export/Import
      Postby rv1974 on Wed Aug 29, 2012 11:36 am
      Could you add support for hidden geometry, visible layers, style and shadows please?
      thanks for your comment - but to be honest, this was not the intention of this plugin, I only wanted to transfer camera settings between files. going into "hidden geometry, visible layers, style and shadows" will require to write a script for transferring complete scenes/pages, a completely different approach...
      martin
      • C
        careca
        "...with Maintenance 2 release, ACT installs with SketchUp 8.
          jpalm32
          Not free version! Unless I'm getting a missing module.
            mirale999
            Great plugin~ I was worrying how to compare two designs the very last minute~
            paranoia is a higher form of awareness...
            • F
              floffy1983
              Works exactly as advertised,thank you.
                ACT is a Pro-only add-on...
                Just like LayOut, Solid tools, some Exporters/Importers etc...
                • G
                  grasset17
                  Merci beaucoup pour ce script qui fonctionne à merveille
                  • Q
                    qazokm
                    Finally I found it, thanks
                    • lsztukaL
                      lsztuka
                      I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
                      • OxerO
                        Oxer
                        Thanks you very much!! 👍
                        Very useful for a project that I'm working on.
                        • halroachH
                          halroach
                          Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
                          Basically exporting/importing whole scenes, and not just the cameras?
                          FlexTools - Super Quick Windows, Doors, Slats...
                          • OxerO
                            Oxer
                            Hi again,
                            I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
                            Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
                            The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
                            If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
                            SU_export_camera.txt file generated by SU2013
                            Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
                            SU_export_camera.txt file generated by SU2014
                            ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                              This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                              Here is how to fix it...
                              Open the file in Notepad++ on PC or TextWrangler on the MAC.
                              Find line #152, which reads:
                              myfile.write(new_array_entry.to_s)
                              Change it to read
                              if Sketchup.version.to_i < 14
                              else ### >=v2014
                                new_array_entry.each{|e| myfile.write(e) }
                              Save it and restart SketchUp.
                              Now it should write the same format of data-file in all versions of SketchUp.
                              The import [reading] part should remain unaffected across versions...
                                Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
                                • OxerO
                                  Oxer
                                  Thanks TIG!!
                                  • ToboboT
                                    Tobobo
                                    Thank you TIG 👍
                                    Toby
                                    Philippians 4:13
                                    • F
                                      faust07
                                      Thank you careca and TIG - this plugin has saved my day!
                                      • P
                                        poiseis
                                        2d perspective scenes are not exported properly, i hope you add that features soon.
                                        • romboutR
                                          rombout
                                          Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                                          Does anyone know a trick or script?
                                          • jujuJ
                                            juju
                                            a quick search
                                            • in the SketchUcation plugin store
                                              http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                                            • in the extension warehouse
                                              http://extensions.sketchup.com/en/search/site/camera
