    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.9k Views 20 Watching
    • Q
      qazokm
      Finally I found it, thanks
      • lsztukaL
        lsztuka
        I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
        • OxerO
          Oxer
          Thanks you very much!! 👍
          Very useful for a project that I'm working on.
          • halroachH
            halroach
            Would it be possible to export/import also shadow settings and layer visibility along with the camera scenes?
            Basically exporting/importing whole scenes, and not just the cameras?
            FlexTools - Super Quick Windows, Doors, Slats...
            • OxerO
              Oxer
              Hi again,
              I have installed the plugin in SU2014 on Mac OS X 10.9.4 but it doesn't work, it appears this message in Ruby Console when I try to import the cameras exported:
              Error: #<ArgumentError: Cannot create unit vector from zero length vector> /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:ininitialize'
              /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in new' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:240:in block in run_import_camera'
              /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in each' /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:184:in run_import_camera'
              /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/camera_export_import.rb:45:in block in <module:NN_Camera_Export_Import>' -e:1:in call'`
              The plugin works fine on SU2013, the file exported with SU2013 it's opened perfectly with SU2014.
              If this can help you, here the content of the SU_export_camera.txt files for SU2013 & SU2014, the cameras exported are the same for SU2013 & SU2014:
              SU_export_camera.txt file generated by SU2013
              Escena 1xxxxx114.776582759505xxxxx-470.759756047837xxxxx255.52670318483xxxxx-4.73467719892792xxxxx394.780293580179xxxxx-156.71068082903xxxxx-0.0583630895867597xxxxx0.42268478698106xxxxx0.904395555400768xxxxx1xxxxx35.0 Escena 2xxxxx284.515642984778xxxxx24.4839257174341xxxxx100.474199327822xxxxx-646.416139390573xxxxx156.269579438326xxxxx-121.743571298921xxxxx-0.227740570706893xxxxx0.0322396770177899xxxxx0.973187975511354xxxxx1xxxxx35.0
              SU_export_camera.txt file generated by SU2014
              ["Escena 1", "xxxxx", 114.776582759505, "xxxxx", -470.759756047837, "xxxxx", 255.52670318483, "xxxxx", -4.73467719892792, "xxxxx", 394.780293580179, "xxxxx", -156.71068082903, "xxxxx", -0.05836308958675972, "xxxxx", 0.4226847869810601, "xxxxx", 0.9043955554007682, "xxxxx", 1, "xxxxx", 35.0] ["Escena 2", "xxxxx", 284.515642984778, "xxxxx", 24.4839257174341, "xxxxx", 100.474199327822, "xxxxx", -646.416139390573, "xxxxx", 156.269579438326, "xxxxx", -121.743571298921, "xxxxx", -0.22774057070689294, "xxxxx", 0.032239677017789896, "xxxxx", 0.9731879755113538, "xxxxx", 1, "xxxxx", 35.0]
                This is because the way the data is compiled from the array into a string in Ruby1.8 is different to Ruby2. It is currently incompatible with v2014 !
                Here is how to fix it...
                Open the file in Notepad++ on PC or TextWrangler on the MAC.
                Find line #152, which reads:
                myfile.write(new_array_entry.to_s)
                Change it to read
                if Sketchup.version.to_i < 14
                else ### >=v2014
                  new_array_entry.each{|e| myfile.write(e) }
                Save it and restart SketchUp.
                Now it should write the same format of data-file in all versions of SketchUp.
                The import [reading] part should remain unaffected across versions...
                  Because the author allows future changes by others, I have made v1.2 compatible with all SketchUp versions - available here http://sketchucation.com/pluginstore?pln=camera_export_import
                  • OxerO
                    Oxer
                    Thanks TIG!!
                    • ToboboT
                      Tobobo
                      Thank you TIG 👍
                      Toby
                      Philippians 4:13
                      • F
                        faust07
                        Thank you careca and TIG - this plugin has saved my day!
                        • P
                          poiseis
                          2d perspective scenes are not exported properly, i hope you add that features soon.
                          • romboutR
                            rombout
                            Im looking for something to place a camera on exact axis. This way i can copy a camera from different modeling app. Its seems to be missing in some importers.
                            Does anyone know a trick or script?
                            • jujuJ
                              juju
                              a quick search
                              • in the SketchUcation plugin store
                                http://sketchucation.com/pluginstore?listtype=1%26amp;author=0%26amp;category=0%26amp;search=camera%26amp;submit=%3F
                              • in the extension warehouse
                                http://extensions.sketchup.com/en/search/site/camera
                                mshdyh
                                找了这个插件很久了,修改后可以使用,自己修改了下界面换成中文了。
                                • aomaoA
                                  aomao
                                  你好 我发现1.2版的这个插件在处理两点透视(并且缩放平移过)的相机时会出现问题,直观来说就是无法正确的导出和导入,我看了下代码,不知是不是因为没有加入“CX,CY,比例”这三个参数(在普通机位,这三个数值分别为0,0,1),如果是的话,我想请教如何自行添加?如果不是话,那无法正确处理两点透视相机的问题在哪里?
                                    rcnorve
                                    Re: [Plugin] Camera Settings Export/Import
                                    Is there an update for this plugin that works in 2023?
                                    Thanks!!
                                    • 2 / 2
