    Unreal 4 Engine
    extensions
    87 Posts 20 Posters 24.4k Views 20 Watching
      cadmunkey
      Very impressive Adam, love the materials. Is the depth of field an option in Lightup?
      • AdamBA Offline
        AdamB
        @iichiversii said:
        Adsm s that just using lightup or in unity? im aware lightups lighting can be imported directly into unity and textures can also be baked, can you link us to a tutorial on how to do these, nice render btw ๐Ÿ‘
        Its just modelled in SketchUp and rendered in LightUp.
        Yes, you can export your lit model from LightUp using Autodesk FBX which will be automatically ingested into Unity.
        Or you can export as Collada DAE.
        There is a very old video tutorials showing exporting to Unity (https://www.youtube.com/watch?v=eNI2RjNsRwY)
        I'll see if I can cook up a new one using the latest version of LightUp and Unity.
        • AdamBA Offline
          AdamB
          Yes, during Tourtool you can adjust the Depth of Field using the DOF slider. The focus point is taken in the direction the camera is pointing and marked by a small red circle on the surface that is being focused.
          You can lock the current focus distance by clicking on the small padlock icon. You can then change your view direction but have a fixed focus distance.. So the workflow was to look at the floor tiles, lock focus distance and then look at the wall further away with the result that the floor is sharply in focus, the walls are blurred.
          • AdamBA Offline
            AdamB
            Here's a (realtime) video of how the model was rigged ready for exporting movies.
            • KrisidiousK Offline
              Krisidious
              Very nice Adam... I ran both movies side by side and saw little difference that wasn't modeling.
              By: Kristoff Rand
              • cmeedC Offline
                cmeed
                Adam They look Great!
                Does Lightup have the ability regarding textures to ..... mmm how to explain it (they'll be a word or phase for it) so in Koolaas the textures reflect a roughness so some parts reflect smooth and some rough. the corridor for instance in the movie shows this
                heres another example of Unreal 4 - its german
                http://www.gamestar.de/videos/trailer,3/unreal-engine-4,76683.html
                c
                • cmeedC Offline
                  cmeed
                  here it is found it on youtube
                  • cmeedC Offline
                    cmeed
                    Another Koolaa inspired by RobertPencil
                    • AdamBA Offline
                      AdamB
                      c
                      Sure, its called a specular map and controls which parts of the texture reflect. LightUp creates one automatically for you from your base texture based on grayscale brightness. If you need (or have) something different, you can set a filename with an image. See this video: https://www.youtube.com/watch?v=22FSi1aT2bg (around 10m30s in).
                      Adam
                      • soloS Offline
                        Architecture Real-time - Unreal Engine 4
                        • FrederikF Offline
                          Frederik
                          ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ‘
                          Cheers
                          Kim Frederik
                            miikka1978
                            One more Unreal Engine Architecture video.
                            • olisheaO Offline
                              olishea
                              wow
                              oli
                              • jenujacobJ Offline
                                jenujacob
                                now especially since Unreal engine is now free, we should be seeing more arch viz from this platform.
                                • soloS Offline
                                  That is just it, we are on a Sketchup forum discussing a new engine but there does not seem to be any support for skp files, so how will the workflow go?
                                  I am very interested in using Unreal but I refuse to have to use a 3rd party software to bridge the two as it makes no sense to complicate my workflow.
                                  So, the challenge goes out as to how SKP and Unreal can work together or if if can.
                                    You could use the SDKs of both apps to make a direct pipeline between both.
                                    There's probably one already out there.
                                    I wonder how lightup fbx export would work? It is used a lot in Unity from what I understand.
                                      kaas
                                      @solo said:
                                      ... so how will the workflow go?... the challenge goes out as to how SKP and Unreal can work together or if if can.
                                      I just tried Unreal using this workflow:
                                      • meters as unit in Sketchup
                                      • fbx output from Sketchup.
                                      • textures used were in size n2 (512x512 for instance)
                                      Import the fbx in Unreal:
                                      • place the mesh in the scene, rescale if needed
                                      • refine / add more objects and save selected overwrite the fbx file in Sketchup and re-import in Unreal. no need to re-scale and material settings (bump / reflection in Unreal)are preserved.
                                      Works nicely for a simple scene. What kind of problems / challenges are you expecting?
                                      • cmeedC Offline
                                        cmeed
                                        The latest Unreal includes better uv unwrapping. Suitable for simple geometry such as walls and floors etc. I'm not sure of the details but what was lacking before was uvs and a 2nd uv channel when the fbx exported from SU. I think this is now generated and simple unwrapping is done in unreal. I have managed to get a model in and lit. I only played for 10mins or so when I heard about the new feature.
                                        But it can't handle unwrapping anything complicated like a person.
                                        • soloS Offline
                                          So from a brief dig around I see Unreal only imports fbx and obj meshes, and so far I have not been successful importing materials, some translate but most do not.
                                          What is needed is an exporter of some sort.
                                            miikka1978
                                            I have been experimenting just a little with Game Engines. My understanding has been that Sketchup files donโ€™t work that well with game Engines because the models need to be UV mapped properly. Therefore, I have assumed that it is always need to have tome 3rd party tool to do the UV mapping, for example Blender. Anyway, I am still novice with these so please correct if I am wrong.
                                            • 2 / 5
