    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • U Offline
      unearthed
      Thanks Jeff - I may not need the extreme bend (If I do I'll draw contours between the sections and skin them with from contours)
      and thanks too for showing a bit more about using Curviloft - I was really amazed when it lofted the individual stretches of stream (and gave the option to tweak the result).
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • jeff hammondJ Offline
        no problem.. and really, you might get better results if you eliminate that path curve all together and just loft the whole thing.. select all the profiles at once, loft, follow the steps i showed.. if you have more than two curves selected, you'll be able to individually click each portion (the black parts) and adjust.. then move to the next.. all in one launch of the curviLoft tool..
        but what that would do is make sure you're always tangent through your profiles and will lessen the possibilities of kinks if your path curve isn't exactly tangent to the profiles as it passes under (which is happening in your model)
          jpaparicio
          HI fredo i just bought an Imac running Maverick, im using Sketchup pro 2014...how can i install curviloft?? THANKS ALOT
          • mariochaM Offline
            mariocha
            Install Sketchucation plugin store ( instructions on page) then just look it up in there and click "install". And please do read the instructions and recommendations, like required Lib folder.
            %(#008000)[Mario C.
              bekans
              Hello everyone,
              I'm sure I've been using curviloft in a previous version whithout any problems, without software problems anyway πŸ˜‰
              On a win7 system I run Sketchup 8 en Make 2014.
              On a win xp system I run Sketchup 8.
              On a new win 8.1 system I have Make 2014 freshly installed.
              All have updated plugins(fredo)installed via plugin store.
              Now,every time I try to use any tool the progressbar freezes after computing the selected edges.
              Same behaviour for all three machines....even with simple shapes with less than 100 edges.
              After quiting the plugin and reactivating it the frozen progressbar appears without showing the plugin menu.
              I've also disabled all plugins except fredos' to exclude possible plugin conflicts.
              Anyone any clue?
              Bekans
                Did you download fresh copies of Curviloft and LibFredo6 or did you just copy them over from another machine? Make sure you are only downloading and installing fresh copies and install them correctly.
                  bekans
                  Yes,that's what I did: all up to date versions auto-installed via the plugin store, no moving or copying. Same procedure for each machine separately. On the new win 8.1 machine everything has been installed for the first time. Besides Total Commander it's only application πŸ˜‰
                  • fredo6F Offline
                    @bekans
                    Do you have any problem like this with my other plugins (if you installed some).
                    Is it just with Curviloft?
                    Also
                    • is it will all 3 Tools of Curviloft?
                    • if you start a Curviloft tool on a pre-selection, do you get the freeze too?
                      bekans
                      Hello Fredo,
                      I'll stick to the win 8.1 machine because less chance I messed something up with whatever....
                      Yes, all three
                      I tested that too: with pre-selection, without pre-selection.
                      Maybe it's my model: I tried with very basic shapes, no problems. But I dont think my shape is that compliclated. I recall having skinned more complex models. Anyway, maybe I'm overlooking something. I'll include my model.
                      Many thanks for having a look.
                      Bekans
                      test-curviloft.skp
                      • fredo6F Offline
                        I tried with your model on SU14 (but Win7).
                        No issue with loft
                        But do you mean it happens with some models only, not all of them
                        Fred
                        • alvisA Offline
                          alvis
                          Three almost identical contours, three different results. Why ?
                          curvyskin.skp
                            Interesting. I get similar results. How did you draw them? What did you do differently from one to the next?
                            • alvisA Offline
                              alvis
                              I've used all the means and methods. I drew the curves with ARC tool. Then I tried to with BZ plugin. But the result is the same.
                                davidbierman2003
                                I have the plug in working in Sketchup. Is there anyway to not include certain portions of what the surface will form? For example, I am working on creating a surface for roads. The roads cover a large surface, and the program creates a large surface covering everything. I just want a surface to cover the roads.
                                Thanks,
                                David
                                • jgbJ Offline
                                  jgb
                                  @davidbierman2003 said:
                                  Thanks,
                                  David
                                  Pre-select only the perimeter lines of what you want surfaced. You can include any lines within the perimeter, if you want. Then click the skinning icon.
                                  jgb
                                  • N Offline
                                    Negatee
                                    thx !!!
                                      robmoors
                                      Amazing plugin, incredible amount of control. Thank you!
                                      Rob Moors
                                      Architecture Student
                                        jumpjack
                                        I can't understand how (if) I can use this plugin to fill the many holes in this model:
                                        http://img22.imageshack.us/img22/7514/zar8.jpg
                                        I select the contour of a hole, but none of the three buttons of the plugin is able to fill the hole for me.
                                          Why can't you attach the image ?
                                          It's a bit much to ask someone to download and then view it...
                                          You could even attach part of the SKP so we could look at it πŸ˜•
                                          Anyway what makes you think CurviLoft 'heals' holes ?
                                            jumpjack
                                            You've just to click the above,link, anyway here it is:
                                            Because it does in one case: "skinning" works fine in filling holes on a flat surface; I thought it could also do it for a generic contour.
                                            Anyway I'm not sure it actually can for any contour: that's why the "if" in parenthesis.
                                            Do I need a different plugin?
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 63 / 66
