    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • jeff hammondJ
      @unearthed said:
      • is there a way in Curviloft, or would another tool do the trick? Due to the extrme bend of the stream it's hard to see a way of using new profiles between the existing one as a way to bridge the problem.
      ignore the bend line you have drawn in that section.. the way it's setup, it's going to result in bad geometry even if it did work.. if you really need that extreme of a bend then you'll have to figure out the profiles which would really work through there as the ones you have now won't do it.
      probably just Loft that section instead using the two edges as the input (the edges in the image that are marked with a red & blue line) .. use the tension controls to obtain the bend while preventing overlaps..
      click pic -> bigger
      • U
        unearthed
        Thanks Jeff - I may not need the extreme bend (If I do I'll draw contours between the sections and skin them with from contours)
        and thanks too for showing a bit more about using Curviloft - I was really amazed when it lofted the individual stretches of stream (and gave the option to tweak the result).
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
        • jeff hammondJ
          no problem.. and really, you might get better results if you eliminate that path curve all together and just loft the whole thing.. select all the profiles at once, loft, follow the steps i showed.. if you have more than two curves selected, you'll be able to individually click each portion (the black parts) and adjust.. then move to the next.. all in one launch of the curviLoft tool..
          but what that would do is make sure you're always tangent through your profiles and will lessen the possibilities of kinks if your path curve isn't exactly tangent to the profiles as it passes under (which is happening in your model)
            jpaparicio
            HI fredo i just bought an Imac running Maverick, im using Sketchup pro 2014...how can i install curviloft?? THANKS ALOT
            • mariochaM
              mariocha
              Install Sketchucation plugin store ( instructions on page) then just look it up in there and click "install". And please do read the instructions and recommendations, like required Lib folder.
              %(#008000)[Mario C.
              • B
                bekans
                Hello everyone,
                I'm sure I've been using curviloft in a previous version whithout any problems, without software problems anyway πŸ˜‰
                On a win7 system I run Sketchup 8 en Make 2014.
                On a win xp system I run Sketchup 8.
                On a new win 8.1 system I have Make 2014 freshly installed.
                All have updated plugins(fredo)installed via plugin store.
                Now,every time I try to use any tool the progressbar freezes after computing the selected edges.
                Same behaviour for all three machines....even with simple shapes with less than 100 edges.
                After quiting the plugin and reactivating it the frozen progressbar appears without showing the plugin menu.
                I've also disabled all plugins except fredos' to exclude possible plugin conflicts.
                Anyone any clue?
                Bekans
                  Did you download fresh copies of Curviloft and LibFredo6 or did you just copy them over from another machine? Make sure you are only downloading and installing fresh copies and install them correctly.
                  • B
                    bekans
                    Yes,that's what I did: all up to date versions auto-installed via the plugin store, no moving or copying. Same procedure for each machine separately. On the new win 8.1 machine everything has been installed for the first time. Besides Total Commander it's only application πŸ˜‰
                    • fredo6F
                      @bekans
                      Do you have any problem like this with my other plugins (if you installed some).
                      Is it just with Curviloft?
                      Also
                      • is it will all 3 Tools of Curviloft?
                      • if you start a Curviloft tool on a pre-selection, do you get the freeze too?
                      • B
                        bekans
                        Hello Fredo,
                        I'll stick to the win 8.1 machine because less chance I messed something up with whatever....
                        Yes, all three
                        I tested that too: with pre-selection, without pre-selection.
                        Maybe it's my model: I tried with very basic shapes, no problems. But I dont think my shape is that compliclated. I recall having skinned more complex models. Anyway, maybe I'm overlooking something. I'll include my model.
                        Many thanks for having a look.
                        Bekans
                        test-curviloft.skp
                        • fredo6F
                          I tried with your model on SU14 (but Win7).
                          No issue with loft
                          But do you mean it happens with some models only, not all of them
                          Fred
                          • alvisA
                            alvis
                            Three almost identical contours, three different results. Why ?
                            curvyskin.skp
                              Interesting. I get similar results. How did you draw them? What did you do differently from one to the next?
                              • alvisA
                                alvis
                                I've used all the means and methods. I drew the curves with ARC tool. Then I tried to with BZ plugin. But the result is the same.
                                  davidbierman2003
                                  I have the plug in working in Sketchup. Is there anyway to not include certain portions of what the surface will form? For example, I am working on creating a surface for roads. The roads cover a large surface, and the program creates a large surface covering everything. I just want a surface to cover the roads.
                                  Thanks,
                                  David
                                  • jgbJ
                                    jgb
                                    @davidbierman2003 said:
                                    Thanks,
                                    David
                                    Pre-select only the perimeter lines of what you want surfaced. You can include any lines within the perimeter, if you want. Then click the skinning icon.
                                    jgb
                                    • N
                                      Negatee
                                      thx !!!
                                        robmoors
                                        Amazing plugin, incredible amount of control. Thank you!
                                        Rob Moors
                                        Architecture Student
                                          jumpjack
                                          I can't understand how (if) I can use this plugin to fill the many holes in this model:
                                          http://img22.imageshack.us/img22/7514/zar8.jpg
                                          I select the contour of a hole, but none of the three buttons of the plugin is able to fill the hole for me.
                                            Why can't you attach the image ?
                                            It's a bit much to ask someone to download and then view it...
                                            You could even attach part of the SKP so we could look at it πŸ˜•
                                            Anyway what makes you think CurviLoft 'heals' holes ?
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 65
                                            • 66
                                            • 50 / 66
