    • Log Masuk
    Scheduled Pinned Kunci Moved Plugins
    1.5k Kiriman 473 Posters 3.4m Lihat 472 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • massimoM Luar talian
      massimo Moderator
      That is a well known behaviour. At the end, pick the select tool and just click on the created surface where you should have a hole and press del.
      1 Reply Last reply Balas Petikan 0
      • E Luar talian
        eddybo
        Ah, that did the trick. Thank you!
        • M Luar talian
          mattiab
          SketchUp crashes each time i try to use this plugin, do you know why?
          • TIGT Luar talian
            Do you have the latest version?
            Do you have the latest version of the require Lib Fredo ?
            What do you mean by 'crash'?
            Are there any error-messages as SketchUp loads?
            Are there any messages in th Ruby Console when you try using this tool ?
            I note you say you are on SketchUp 7 - that's 3 steps behind most people !
            Expecting compatibility is perhaps hopeful...
            • fredo6F Luar talian
              Do you have an old version of Vray?
              • Dave RD Luar talian
                You sure haven't given much in the way of useful information so that anyone can help you.
                • W Luar talian
                  whitelock
                  Hi I would like to ask what edge prop filter, border and inner edge settings need to be on to have the effect below (I have had to soften all edges and then redraw the lines to show what I need) where the outer edges of the round are visible and the inner edges are hidden. I have tried every kind of variation I can think of and they all end up showing all the additional edges created. Please help if you can
                  thanks
                  Luke
                    Is this what you're after?
                    • W Luar talian
                      whitelock
                      Hi Dave,
                      thanks for the reply I am actually after this look as shown below, where the outer edges of the Radius are shown only so that when I put the model into Layout I not only have points that I can snap to for measurements but you can also make out the edge.
                        You could do this:
                        And maybe you could get the additional edges at the corners if you run the plugin on limited selections and run it more than once.
                        If you aren't able to see the edges in LO, it makes me wonder what you have Profiles set to for the style you use.
                        • W Luar talian
                          whitelock
                          Thanks dave, big help πŸ˜„
                          • N Luar talian
                            numerobis
                            @whitelock said:
                            Hi Dave,
                            I wanted to ask the same today πŸ˜†
                            I need it to get a proper shading in rendering without additional supporting edges. For now i'm doing this manually for every object after i have rounded the corners:
                            • select the whole object and set it to the lowest needed angle to get softed edges.
                            • double click on every side to select the bounding edges, then deselect faces with filter plugin.
                            • hit the edge loop function to select the crossing edges at the corners
                            • set the softening angle to 0
                            So, it would be nice to have an option in RoundCorner to do this automatically!
                            But thanks Dave! πŸ‘ I will try your suggested setting to see if this is enough to get a proper shading (not sure about that).
                              @james kayten said:
                              I find it dismaying that for all the info provided, there's no link to download the plugin. I've been online now nearly an hour trying to figure out how I managed to install the item last year. There's an ill-concieved quality about so much of the SU interface and plugins system - amateurish and fucking annoying.
                              I find it dismaying that despite how obvious it is, you still can't find the links in the first post of the thread. And then have the gall to use foul language and make insults that are uncalled for and expect others to help you anyway. πŸ˜’
                              • Rich O BrienR Luar talian
                                Amateurish is use of foul language to make point.
                                Amateurish is spending an hour trying to figure the obvious.
                                What's even more amateurish is missing out on something so blatantly obvious....
                                http://img.tapatalk.com/d/14/08/13/atade7yd.jpg
                                  Haha.
                                  Did he poke your button too?
                                  • T Luar talian
                                    tkridero
                                    thank mak mak
                                    • T Luar talian
                                      Toon Master
                                      Thank you very much!
                                      • L Luar talian
                                        littleche
                                        hi ...
                                        I have one problem with rounding ...
                                        how to fix it ?
                                        Round error.skp
                                          NEW RELEASE: RoundCorner v2.7a - 19 Oct 14
                                          RoundCorner 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                          • L Luar talian
                                            littleche
                                            hi fredo ...
                                            I test my problom with last version of round corner ...
                                            but I still have the same problem. I'm not overly complicated.I got a lot easier.The film may be able to help :
                                            test
                                            MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                                            MediaFire (www.mediafire.com)
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 73
                                            • 74
                                            • 62 / 74
