    1.5k Posts 477 Posters 4.1m Views 477 Watching
      You could do this:
      And maybe you could get the additional edges at the corners if you run the plugin on limited selections and run it more than once.
      If you aren't able to see the edges in LO, it makes me wonder what you have Profiles set to for the style you use.
      • W
        whitelock
        Thanks dave, big help πŸ˜„
        • N
          numerobis
          @whitelock said:
          Hi Dave,
          thanks for the reply I am actually after this look as shown below, where the outer edges of the Radius are shown only so that when I put the model into Layout I not only have points that I can snap to for measurements but you can also make out the edge.
          I wanted to ask the same today πŸ˜†
          I need it to get a proper shading in rendering without additional supporting edges. For now i'm doing this manually for every object after i have rounded the corners:
          • select the whole object and set it to the lowest needed angle to get softed edges.
          • double click on every side to select the bounding edges, then deselect faces with filter plugin.
          • hit the edge loop function to select the crossing edges at the corners
          • set the softening angle to 0
          So, it would be nice to have an option in RoundCorner to do this automatically!
          But thanks Dave! πŸ‘ I will try your suggested setting to see if this is enough to get a proper shading (not sure about that).
            @james kayten said:
            I find it dismaying that for all the info provided, there's no link to download the plugin. I've been online now nearly an hour trying to figure out how I managed to install the item last year. There's an ill-concieved quality about so much of the SU interface and plugins system - amateurish and fucking annoying.
            I find it dismaying that despite how obvious it is, you still can't find the links in the first post of the thread. And then have the gall to use foul language and make insults that are uncalled for and expect others to help you anyway. πŸ˜’
              Amateurish is use of foul language to make point.
              Amateurish is spending an hour trying to figure the obvious.
              What's even more amateurish is missing out on something so blatantly obvious....
              http://img.tapatalk.com/d/14/08/13/atade7yd.jpg
                Haha.
                Did he poke your button too?
                • T
                  tkridero
                  thank mak mak
                  • T
                    Toon Master
                    Thank you very much!
                    • L
                      littleche
                      hi ...
                      I have one problem with rounding ...
                      how to fix it ?
                      Round error.skp
                      • fredo6F
                        NEW RELEASE: RoundCorner v2.7a - 19 Oct 14
                        RoundCorner 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
                        • L
                          littleche
                          hi fredo ...
                          I test my problom with last version of round corner ...
                          but I still have the same problem. I'm not overly complicated.I got a lot easier.The film may be able to help :
                          test
                          MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                          MediaFire (www.mediafire.com)
                          • fredo6F
                            @littleche said:
                            hi fredo ...
                            RoundCorner cannot do anything for this model, because it is triangulated.
                            The method is to use Subdivision, which you may possibly try with Artisan by Whaat.
                            • T
                              taktakplz
                              hi fredo
                              the round corner is not working on my su13 but the curviloft and tools on surface is working fine.
                              where i can install the higher version of libfredo6?i install it using extension warehouse
                                It's clearly spelled out for you in the first post on the first page of this thread.
                                Which takes you to the first post on the first page of the LibFredo6 thread which has the link you need.
                                Get the SCF Plugin Store tool and use it to auto install your plugins.
                                • T
                                  taktakplz
                                  @fredo6 said:
                                  @mattiab said:
                                  SketchUp crashes each time i try to use this plugin, do you know why?
                                  Do you have an old version of Vray?
                                  fredo i do have the same problem
                                  i have installed V-Ray for SketchUp v1.60.22
                                    Remove VRay for SketchUp. It is has been known to cause problems with other plugins. Or at least use the current version of it. The current version appears to be 2.0.
                                    • T
                                      taktakplz
                                      thanks for the help fredo
                                      • cottyC
                                        cotty
                                        Dave!?
                                        my SketchUp gallery
                                        • L
                                          littleche
                                          thank you fredo for your help .
                                          I thought this work is Possible whit your plugin .
                                          I hope this Reliability Be included in future versions. πŸ˜›
                                          • G
                                            goblinteasemaid
                                            very nice tool, works on SU6
                                            doesnt do groups so you need to group edit or explode
                                            and you only get one chance for offset input. Get it wrong and you must revert to sharp edge start - obvious really, no big deal
                                            think of the time spent doing it manually YUK
                                            thanx mille foix
                                            Goblint
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 74
                                            • 75
                                            • 46 / 75
