    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • W Offline
      whitelock
      Hi I would like to ask what edge prop filter, border and inner edge settings need to be on to have the effect below (I have had to soften all edges and then redraw the lines to show what I need) where the outer edges of the round are visible and the inner edges are hidden. I have tried every kind of variation I can think of and they all end up showing all the additional edges created. Please help if you can
      thanks
      Luke
        Is this what you're after?
        • W Offline
          whitelock
          Hi Dave,
          thanks for the reply I am actually after this look as shown below, where the outer edges of the Radius are shown only so that when I put the model into Layout I not only have points that I can snap to for measurements but you can also make out the edge.
            You could do this:
            And maybe you could get the additional edges at the corners if you run the plugin on limited selections and run it more than once.
            If you aren't able to see the edges in LO, it makes me wonder what you have Profiles set to for the style you use.
            • W Offline
              whitelock
              Thanks dave, big help πŸ˜„
              • N Offline
                numerobis
                @whitelock said:
                Hi Dave,
                I wanted to ask the same today πŸ˜†
                I need it to get a proper shading in rendering without additional supporting edges. For now i'm doing this manually for every object after i have rounded the corners:
                • select the whole object and set it to the lowest needed angle to get softed edges.
                • double click on every side to select the bounding edges, then deselect faces with filter plugin.
                • hit the edge loop function to select the crossing edges at the corners
                • set the softening angle to 0
                So, it would be nice to have an option in RoundCorner to do this automatically!
                But thanks Dave! πŸ‘ I will try your suggested setting to see if this is enough to get a proper shading (not sure about that).
                  @james kayten said:
                  I find it dismaying that for all the info provided, there's no link to download the plugin. I've been online now nearly an hour trying to figure out how I managed to install the item last year. There's an ill-concieved quality about so much of the SU interface and plugins system - amateurish and fucking annoying.
                  I find it dismaying that despite how obvious it is, you still can't find the links in the first post of the thread. And then have the gall to use foul language and make insults that are uncalled for and expect others to help you anyway. πŸ˜’
                  • Rich O BrienR Online
                    Amateurish is use of foul language to make point.
                    Amateurish is spending an hour trying to figure the obvious.
                    What's even more amateurish is missing out on something so blatantly obvious....
                    http://img.tapatalk.com/d/14/08/13/atade7yd.jpg
                      Haha.
                      Did he poke your button too?
                        tkridero
                        thank mak mak
                          Toon Master
                          Thank you very much!
                            littleche
                            hi ...
                            I have one problem with rounding ...
                            how to fix it ?
                            Round error.skp
                            • fredo6F Offline
                              NEW RELEASE: RoundCorner v2.7a - 19 Oct 14
                              RoundCorner 2.7a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                littleche
                                hi fredo ...
                                I test my problom with last version of round corner ...
                                but I still have the same problem. I'm not overly complicated.I got a lot easier.The film may be able to help :
                                test
                                MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                                MediaFire (www.mediafire.com)
                                • fredo6F Offline
                                  @littleche said:
                                  hi fredo ...
                                  RoundCorner cannot do anything for this model, because it is triangulated.
                                  The method is to use Subdivision, which you may possibly try with Artisan by Whaat.
                                    taktakplz
                                    hi fredo
                                    the round corner is not working on my su13 but the curviloft and tools on surface is working fine.
                                    where i can install the higher version of libfredo6?i install it using extension warehouse
                                      It's clearly spelled out for you in the first post on the first page of this thread.
                                      Which takes you to the first post on the first page of the LibFredo6 thread which has the link you need.
                                      Get the SCF Plugin Store tool and use it to auto install your plugins.
                                        taktakplz
                                        @fredo6 said:
                                        @mattiab said:
                                        SketchUp crashes each time i try to use this plugin, do you know why?
                                        Do you have an old version of Vray?
                                        fredo i do have the same problem
                                        i have installed V-Ray for SketchUp v1.60.22
                                          Remove VRay for SketchUp. It is has been known to cause problems with other plugins. Or at least use the current version of it. The current version appears to be 2.0.
                                            taktakplz
                                            thanks for the help fredo
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 74
                                            • 75
                                            • 46 / 75
