    Proper Shadows on Moldings
    renderpluginsextensions
    13 Posts 6 Posters 884 Views 6 Watching
      toddakeson
      You can see the lack of definition in the door in the background.
      • TedVitale_CGT Offline
        TedVitale_CG
        The scene doesn't look very well lit. Where is your light coming from? You may also want to turn on your ambient occlusion, found under the Indirect illumination tab in your Options Editor.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          toddakeson
          The light is entirely from the sun.
            toddakeson
            Ambient occlusion turned on
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              What do you get with "detail enhancement" checked? (uncheck AO)
                toddakeson
                This is with detail enhancement.
                  toddakeson
                  This is with ambient occlusion
                    toddakeson
                    Thanks for the help. I think I need to do some tutorials on interior lighting.
                      jiminy-billy-bob
                      I usually add an invisible rectangle light just behind the windows. So you get casted sun rays, but powerfull soft light from the windows.
                      • dcauldwellD Offline
                        dcauldwell
                        With everything being white, good lighting (be it by the sun or artificial) is really important. The scene has very even lighting which won't show up the mouldings (as you can see). I would get a good punch of sunlight coming in somewhere to improve the lighting levels. (I rarely use artificial lighting myself)
                        TIP: if you add a ground plane on the outside of your building with a light, or white colour, applied to it, then it will help to bounce sunlight into the interior.
                        TIP2: never use 255,255,255 white. White should be roughly 235,235,235
                        Sketchup 2017
                        (vray 2.00)
                        • V Offline
                          valerostudio
                          Light - as suggested
                          Reflection to your material
                          Render higher resolution image, with AO and higher quality settings.
                          • andybotA Offline
                            andybot
                            you could also try brute force rendering instead of irradiance map. Either way, definitely needs more light.
