    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 72.0k Views 40 Watching
      Aerilius
      I could not reproduce the problem with the same toolbar names (工具栏, 正常, 具) after restarting SketchUp and opening the toolbar editor. I will continue try.
      I updated the webdialog with improvements for higher dpi settings.
      • cmeedC Offline
        cmeed
        This looks great but I'm missing icons? any ideas.....
        @rickw said:
        Has anyone else had problems with not all commands being available? I'm also missing a lot of icons that exist on other toolbars.
        cheers
        c
          Do you have those icons on the existing original toolbars?
          • cmeedC Offline
            cmeed
            Yes I do, they are all there.
              Aerilius
              Can you right-click on the missing icons and get the image file path? Maybe some commands return an unusual file path?
              Or it is a timing issue, maybe Fredo uses layz-loading techniques, or his tools take longer to load?
              • cmeedC Offline
                cmeed
                im not sure how to do what you asked. right clicking the icons - in the toolbar? (nothing)
                right clicking in toolbarEditor? (nothing in the menu that come up that looked familiar)
                some of fredos icons work. is it possible to compare and find the answer?
                  lionk
                  hi Aerilius,
                  maybe fredo6's methord can solve the UTF8 issue. fredo6's plugins show Chinese very well.
                  • ely862meE Offline
                    ely862me
                    What about these ones ?
                    After choosing yes I get this :
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      Aerilius
                      Are you sure you use the latest version?
                      • ely862meE Offline
                        ely862me
                        I installed it from the scf plugin store and I thought it was the last version but it was not, now it works !
                        Thank you !
                        • TIGT Online
                          Andreas updated this toolset twice on the same day, so the second version was not automatically picked up... v1.0.6 will be added to the 'SketchUcation Plugin Store' shortly...
                            Andreas, here's a nice idea that I liked. That in addition to customize toolbar one could paste a snippet for a completely new command: http://sketchucation.com/forums/viewtopic.php?f=15&t=52454&p=475992#p475990
                            This would be a great tool. You think this tool can be tweaked for that?
                            • Bob JamesB Offline
                              Bob James
                              1. Can someone write a sample ruby script to make an icon for a native command that has no icon so I can use it to add the icon to a toolbar made with ToolbarEditor?
                              2. How do you delete an icon in a toolbar made with ToolbarEditor?
                              3. How do you delete a toolbar made with ToolbarEditor?
                              • CadFatherC Offline
                                CadFather
                                1 - which one?
                                2 - click on the icon and drag it slowly on the right panel
                                3 - click on the minus sign - top right of your toolbar header
                                  Bob James
                                  @cadfather said:
                                  1 - which one?
                                  Generically so I could modify it for any command
                                  Thank you
                                  duh 😳
                                    Aerilius
                                    As in the API documentation… http://www.sketchup.com/intl/en/developer/docs/ourdoc/command.php
                                    cmd = UI;;Command.new("name of the command"){
                                      AuthorModule;;PluginName.name_of_the_main_method()
                                    cmd.tooltip = "tooltip that describes the command"
                                    cmd.status_bar_text = "text that tells how to use the command"
                                    cmd.large_icon = "./path/to/a/icon24px.png"
                                    cmd.small_icon = "./path/to/a/icon16px.png"
                                    It still can only be used with understanding of what it does, and you would have to look up how a certain plugin is started.
                                    It would probably be sufficient and much easier to edit the plugin's own ruby file, look for "UI::Command.new" and add the icons. The icon path can either be relative to the ruby file or absolute (to the system's root, ie. "C:/" on Windows).
                                    Some plugins add themself only to the menu without creating a command. That looks like this:
                                    UI.menu("plugins").add_item("name of the command"){ name_of_the_method }
                                    and can be replaced by a command object (as above) plus
                                    UI.menu("plugins").add_item(cmd)
                                      danb
                                      Hello, could anyone help. I used this plugin with 2013 but it does not seem to work with 2014. I find it very useful, particularly as I use a mac and you can't stack the toolbars as you do on windows
                                      many thanks
                                      Dan
                                      Macbook Pro
                                      OSX 10.9
                                      Sketchup Pro 2014
                                      Sketchup Pro 2019/20
                                      OSX 10.15.3
                                      Macbook Pro
                                      • BoxB Offline
                                        It throws a load error in SU2014
                                          Aerilius
                                          If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
                                          fixed LoadError
                                            Aerilius
                                            Thanks, I fixed the load error.
                                            • 3 / 7
