    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 79.2k Views 40 Watching
    • cmeedC
      cmeed
      This looks great but I'm missing icons? any ideas.....
      @rickw said:
      Has anyone else had problems with not all commands being available? I'm also missing a lot of icons that exist on other toolbars.
      cheers
      c
        Do you have those icons on the existing original toolbars?
        • cmeedC
          cmeed
          Yes I do, they are all there.
            Aerilius
            Can you right-click on the missing icons and get the image file path? Maybe some commands return an unusual file path?
            Or it is a timing issue, maybe Fredo uses layz-loading techniques, or his tools take longer to load?
            • cmeedC
              cmeed
              im not sure how to do what you asked. right clicking the icons - in the toolbar? (nothing)
              right clicking in toolbarEditor? (nothing in the menu that come up that looked familiar)
              some of fredos icons work. is it possible to compare and find the answer?
              • L
                lionk
                @aerilius said:
                I could not reproduce the problem with the same toolbar names (工具栏, 正常, 具) after restarting SketchUp and opening the toolbar editor. I will continue try.
                I updated the webdialog with improvements for higher dpi settings.
                hi Aerilius,
                maybe fredo6's methord can solve the UTF8 issue. fredo6's plugins show Chinese very well.
                • ely862meE
                  ely862me
                  What about these ones ?
                  After choosing yes I get this :
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Aerilius
                    Are you sure you use the latest version?
                    • ely862meE
                      ely862me
                      I installed it from the scf plugin store and I thought it was the last version but it was not, now it works !
                      Thank you !
                        Andreas updated this toolset twice on the same day, so the second version was not automatically picked up... v1.0.6 will be added to the 'SketchUcation Plugin Store' shortly...
                          Andreas, here's a nice idea that I liked. That in addition to customize toolbar one could paste a snippet for a completely new command: http://sketchucation.com/forums/viewtopic.php?f=15&t=52454&p=475992#p475990
                          This would be a great tool. You think this tool can be tweaked for that?
                          • Bob JamesB
                            Bob James
                            1. Can someone write a sample ruby script to make an icon for a native command that has no icon so I can use it to add the icon to a toolbar made with ToolbarEditor?
                            2. How do you delete an icon in a toolbar made with ToolbarEditor?
                            3. How do you delete a toolbar made with ToolbarEditor?
                            • CadFatherC
                              CadFather
                              1 - which one?
                              2 - click on the icon and drag it slowly on the right panel
                              3 - click on the minus sign - top right of your toolbar header
                              • Bob JamesB
                                Bob James
                                @cadfather said:
                                1 - which one?
                                Generically so I could modify it for any command
                                Thank you
                                duh 😳
                                  Aerilius
                                  As in the API documentation… http://www.sketchup.com/intl/en/developer/docs/ourdoc/command.php
                                  cmd = UI;;Command.new("name of the command"){
                                    AuthorModule;;PluginName.name_of_the_main_method()
                                  cmd.tooltip = "tooltip that describes the command"
                                  cmd.status_bar_text = "text that tells how to use the command"
                                  cmd.large_icon = "./path/to/a/icon24px.png"
                                  cmd.small_icon = "./path/to/a/icon16px.png"
                                  It still can only be used with understanding of what it does, and you would have to look up how a certain plugin is started.
                                  It would probably be sufficient and much easier to edit the plugin's own ruby file, look for "UI::Command.new" and add the icons. The icon path can either be relative to the ruby file or absolute (to the system's root, ie. "C:/" on Windows).
                                  Some plugins add themself only to the menu without creating a command. That looks like this:
                                  UI.menu("plugins").add_item("name of the command"){ name_of_the_method }
                                  and can be replaced by a command object (as above) plus
                                  UI.menu("plugins").add_item(cmd)
                                    danb
                                    Hello, could anyone help. I used this plugin with 2013 but it does not seem to work with 2014. I find it very useful, particularly as I use a mac and you can't stack the toolbars as you do on windows
                                    many thanks
                                    Dan
                                    Macbook Pro
                                    OSX 10.9
                                    Sketchup Pro 2014
                                    Sketchup Pro 2019/20
                                    OSX 10.15.3
                                    Macbook Pro
                                    • BoxB
                                      It throws a load error in SU2014
                                        Aerilius
                                        If you are curious, you can have a sneak-peak on the next version 1.1.0 with custom buttons. You will be able to create your own toolbar buttons for Ruby one-liners, code snippets or other things found on the forum.
                                        fixed LoadError
                                          Aerilius
                                          Thanks, I fixed the load error.
                                            BUT you haven't published it 😒
                                            • 3 / 7
