    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 204.2k Views 41 Watching
      @braikenridge said:
      I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
      To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-easy-way-8211-rbz-packages
        Jim
        I bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
        Thanks.
          srknytgn
          import in cm or mm would be nice, thanks.
            Jim
            I agree, and I am working on it.
            • TIGT Online
              πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
              Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
              A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
              You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
                Jim
                Just updated to v 0.8.0 with a dialog for selecting the import units.
                  srknytgn
                  hey jim,
                  i'm trying to import a dxf file but it comes in scaled to inches.
                  as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed.
                  do you think something was wrong?
                  dxf_import.dxf
                  • TIGT Online
                    1000 'units' read from a DXF file are taken as 1000 inches.
                    When you 'scale' it 'to mm' the 1000" --> 25400mm NOT the displayed 2540mm ?
                    BUT looking into your DXF file... the box's edges are actually 100 'units' long! NOT 1000, so therefore it ought to produce 2540mm when 'scaled' as you showed ??
                    If your DXF says something is 100 'units' long [taken as 100" as SketchUp's base-units are inches] and you tell it to scale it to 'mm' - then logically you will get something 2540mm long [which is 100" !]
                    If you want to get it to assume the 100 'units' is actually 100mm then the scaling needs to be NOT 'TO mm' but 'FROM mm'.
                    The scaling factor would then be:
                    100.mm / 100.inch
                    which is actually 1/25.4
                    So 100 'units' --> 100" - which is then rescaled to be the smaller 'mm' dimension of exactly 100mm [100 / 25.4 = ~4" (3.93700787401574803") in base-units ]
                      srknytgn
                      I don't understand why should i scale imported drawing. I have nothing to do with inches, want to import like SU Pro. My base SU file always in cm or mm unit and always draw in Autocad unitless.
                      Finally my su file's unit is cm and I draw a 100 x 100 square in Autocad and I want to see it in SU as 100 x 100 cm. Is it possible with that plugin or not?
                      • TIGT Online
                        This importer always takes the DXF length of 100 as 100".
                        Jim's latest update is intended to allow you to 'scale' the input to whatever units you desire.
                        So if you choose "to-mm" then it currently applies a scaling factor to make 100 into 2540mm
                        My point was that it should take 1/25.4 as the scaling factor 'from-mm' and therefore you'd get 100mm as your result.
                        I'm sure Jim will address this shortly... πŸ˜•
                          Jim
                          @srknytgn said:
                          hey jim,
                          Yes I botched the importer scale. It is now fixed and version 0.8.1 is available in the Plugin Store.
                            srknytgn
                            Hey Jim, please don't mention it : )
                            But the same problem is here, I've attached the screenshot.
                            I've also tried clean install, but no way.
                            100x100_square.dxf
                              Jim
                              I found it - this had to do with updating the options from the UI rather than incorrect scaling factors. Check for version 0.8.2 soon.
                                srknytgn
                                thanks Jim!
                                  rungek
                                  Just today loaded and tried with Make 2014 on Win 7 x64. Does not work!
                                  Removed
                                  • BoxB Offline
                                    Then you must be doing something wrong, but as you've given no information about how it hasn't worked for you nobody can help.
                                      rungek
                                      Box. Your right of course so here is the error info. SU reports on startup
                                      Error: #<SyntaxError: C:/Users/Laptop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Dxf_In_v2.2.rb:306: formal argument cannot be an instance variable
                                      ramFile.each do |@line| #search for entities @line by @line
                                      Thanks for any help. Maybe just using provious version of Google SU will be easier.
                                        Jim
                                        Removed
                                        Sorry you are having difficulty.
                                        How did you install FreeDXF? What version did you install?
                                        The only supported download is from the SketchUcation Plugin Store. The most recent version is 0.8.7. In recent versions of FreeDXF this version number appears right in the Plugins menu.
                                        Is this what you see after installing?
                                          Jim
                                          This error is not from FreeDXF - it is from a different plugin named Dxf_in.
                                            rungek
                                            Thanks, still new to this and thought I installed the correct plugin. Works now.
                                            • 4 / 8
