    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 194.8k Views 41 Watching
      Tenere
      😒 %(#4000FF)[I've got a script not loading error on start with free version 8.0.4811.
      I would assume I had the files in the right places although I can't see the folder layout image in the script posting - just an image name.
      Bound to be missing the obvious, be grateful if someone could nudge me in the right direction......cheers.
      Ooh one other question......Can I load the SU pro trial in tandem with my free version without bu#@ering it up or compromising the trial?....would quite like to see what I'm missing.] πŸ‘
      • TIGT Online
        Capture.PNG Does you Sketchup Plugins folder look like this ?
          Tenere
          %(#0000FF)[πŸ‘ Hi Tig
          Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
          I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
          Error:]
          Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
          no such file to load -- inputboxError Loading File freedxf_ext.rb
          %(#0000FF)[.......The file is definitely there!
          Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
            JMdesigns
            I am having the same problem? but it does not let me inmport
            • TIGT Online
              The download page's image is wrong !
              There should also be the file
              inputbox.rb
              IF you get the latest zipped version of the tool it should include that file !
                Tenere
                Bingo....your a star Tig
                That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
                  juergen
                  Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
                  As all my DXFs are in cm I can not use FreeDXF.
                  Please consider supporting metric drawings.
                  PS: If somebody knows a way, please reply!
                  • TIGT Online
                    1" is 2.54cm
                    therefore
                    1cm is 0.393700787401574803" [1/2.54]
                    However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                      blackcat1313
                      Hi -
                      I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz.
                      When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks!
                      Bill
                      • pbacotP Offline
                        Hi! try this:
                        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=38583
                          blackcat1313
                          @pbacot said:
                          Hi! try this:
                          Doh - thanks for that, it's all working now!
                          Bill
                          • BraikenridgeB Offline
                            Braikenridge
                            I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
                            kind regards
                              To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-easy-way-8211-rbz-packages
                                Jim
                                I bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
                                Thanks.
                                  srknytgn
                                  import in cm or mm would be nice, thanks.
                                    Jim
                                    I agree, and I am working on it.
                                    • TIGT Online
                                      πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
                                      Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
                                      A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
                                      You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
                                        Jim
                                        Just updated to v 0.8.0 with a dialog for selecting the import units.
                                          srknytgn
                                          hey jim,
                                          i'm trying to import a dxf file but it comes in scaled to inches.
                                          as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed.
                                          do you think something was wrong?
                                          dxf_import.dxf
                                          • TIGT Online
                                            1000 'units' read from a DXF file are taken as 1000 inches.
                                            When you 'scale' it 'to mm' the 1000" --> 25400mm NOT the displayed 2540mm ?
                                            BUT looking into your DXF file... the box's edges are actually 100 'units' long! NOT 1000, so therefore it ought to produce 2540mm when 'scaled' as you showed ??
                                            If your DXF says something is 100 'units' long [taken as 100" as SketchUp's base-units are inches] and you tell it to scale it to 'mm' - then logically you will get something 2540mm long [which is 100" !]
                                            If you want to get it to assume the 100 'units' is actually 100mm then the scaling needs to be NOT 'TO mm' but 'FROM mm'.
                                            The scaling factor would then be:
                                            100.mm / 100.inch
                                            which is actually 1/25.4
                                            So 100 'units' --> 100" - which is then rescaled to be the smaller 'mm' dimension of exactly 100mm [100 / 25.4 = ~4" (3.93700787401574803") in base-units ]
                                            • 4 / 8
