    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 204.2k Views 41 Watching
      Jim
      @srknytgn said:
      import in cm or mm would be nice, thanks.
      I agree, and I am working on it.
        πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
        Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
        A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
        You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
          Jim
          Just updated to v 0.8.0 with a dialog for selecting the import units.
            srknytgn
            hey jim,
            i'm trying to import a dxf file but it comes in scaled to inches.
            as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed.
            do you think something was wrong?
            dxf_import.dxf
              1000 'units' read from a DXF file are taken as 1000 inches.
              When you 'scale' it 'to mm' the 1000" --> 25400mm NOT the displayed 2540mm ?
              BUT looking into your DXF file... the box's edges are actually 100 'units' long! NOT 1000, so therefore it ought to produce 2540mm when 'scaled' as you showed ??
              If your DXF says something is 100 'units' long [taken as 100" as SketchUp's base-units are inches] and you tell it to scale it to 'mm' - then logically you will get something 2540mm long [which is 100" !]
              If you want to get it to assume the 100 'units' is actually 100mm then the scaling needs to be NOT 'TO mm' but 'FROM mm'.
              The scaling factor would then be:
              100.mm / 100.inch
              which is actually 1/25.4
              So 100 'units' --> 100" - which is then rescaled to be the smaller 'mm' dimension of exactly 100mm [100 / 25.4 = ~4" (3.93700787401574803") in base-units ]
                srknytgn
                I don't understand why should i scale imported drawing. I have nothing to do with inches, want to import like SU Pro. My base SU file always in cm or mm unit and always draw in Autocad unitless.
                Finally my su file's unit is cm and I draw a 100 x 100 square in Autocad and I want to see it in SU as 100 x 100 cm. Is it possible with that plugin or not?
                  This importer always takes the DXF length of 100 as 100".
                  Jim's latest update is intended to allow you to 'scale' the input to whatever units you desire.
                  So if you choose "to-mm" then it currently applies a scaling factor to make 100 into 2540mm
                  My point was that it should take 1/25.4 as the scaling factor 'from-mm' and therefore you'd get 100mm as your result.
                  I'm sure Jim will address this shortly... πŸ˜•
                    Jim
                    @srknytgn said:
                    hey jim,
                    Yes I botched the importer scale. It is now fixed and version 0.8.1 is available in the Plugin Store.
                      srknytgn
                      Hey Jim, please don't mention it : )
                      But the same problem is here, I've attached the screenshot.
                      I've also tried clean install, but no way.
                      100x100_square.dxf
                        Jim
                        I found it - this had to do with updating the options from the UI rather than incorrect scaling factors. Check for version 0.8.2 soon.
                          srknytgn
                          thanks Jim!
                            rungek
                            Just today loaded and tried with Make 2014 on Win 7 x64. Does not work!
                            Removed
                            • BoxB Offline
                              Then you must be doing something wrong, but as you've given no information about how it hasn't worked for you nobody can help.
                                rungek
                                Box. Your right of course so here is the error info. SU reports on startup
                                Error: #<SyntaxError: C:/Users/Laptop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Dxf_In_v2.2.rb:306: formal argument cannot be an instance variable
                                ramFile.each do |@line| #search for entities @line by @line
                                Thanks for any help. Maybe just using provious version of Google SU will be easier.
                                  Jim
                                  Removed
                                  Sorry you are having difficulty.
                                  How did you install FreeDXF? What version did you install?
                                  The only supported download is from the SketchUcation Plugin Store. The most recent version is 0.8.7. In recent versions of FreeDXF this version number appears right in the Plugins menu.
                                  Is this what you see after installing?
                                    Jim
                                    This error is not from FreeDXF - it is from a different plugin named Dxf_in.
                                      rungek
                                      Thanks, still new to this and thought I installed the correct plugin. Works now.
                                      • W Offline
                                        wootton
                                        I'm also having trouble installing this plugin into Sketchup 2014. I may have the wrong version; I see above that the latest is 0.8.7, but in the filename I downloaded it's 0.8.2, which appears to have been created 2 months ago, and I can't find a more current version. Is "0.8.7" a typo? If not, is there a link to the newer version? I got it from the following link at the Sketchucation download store:
                                        404 Not Found
                                        (sketchucation.com)
                                        The filename is freedfx_v0.8.2.rbz
                                        I pasted the file to the following folder on my computer, and restarted SketchUp:
                                        C:\Users\tom\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                        When I try to find it in SketchUp, I don't see a "plugins" icon anywhere, and when I open Ruby console, nothing appears. Have I left out a step?
                                        Thanks in advance,
                                        Tom
                                        Tom Wootton
                                        • W Offline
                                          wootton
                                          Never mind, I figured it out.
                                          Tom Wootton
                                            The latest is v0.8.2.
                                            You need to install the RBZ archive's contents, using Preferences > Extensions > Install... button...
                                            No need to mess on accessing your Plugins folder at all, for this kind of Plugin... Just 'AutoInstall' it...
                                            • 4 / 8
