    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 209.3k Views 41 Watching
    • T
      Tenere
      %(#0000FF)[πŸ‘ Hi Tig
      Thanks for responding. My directory looks correct, are there any dependencies I may be missing?
      I did read something in an earlier incarnation about the file naming system having to be basic without spaces ('joliet' stuff!!), it looks a bit more like an issue in that direction perhaps, paths & stuff....he says clutching at straws!!
      Error:]
      Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/freedxf/freedxf.rb
      no such file to load -- inputboxError Loading File freedxf_ext.rb
      %(#0000FF)[.......The file is definitely there!
      Being skint takes up a lot of my time! Just can't justify the Pro version though so your help is much appreciated!]
        JMdesigns
        I am having the same problem? but it does not let me inmport
          The download page's image is wrong !
          There should also be the file
          inputbox.rb
          IF you get the latest zipped version of the tool it should include that file !
          • T
            Tenere
            Bingo....your a star Tig
            That sorted it, many thanks for your expertise. I'm raising a beer to you right now!....Hic!....well it is Friday!
              juergen
              Handling metric units would realy be a plus. It is easily possible to scale from metric to imperial but the reverse is no as easy as it requires to scale by a fractional number.
              As all my DXFs are in cm I can not use FreeDXF.
              Please consider supporting metric drawings.
              PS: If somebody knows a way, please reply!
                1" is 2.54cm
                therefore
                1cm is 0.393700787401574803" [1/2.54]
                However, Sketchup's in-built accuracy regards 0.3937007" as being 'exactly' 1cm... so you can use that [or even 0.3937] as your scaling factor. After all we are talking about modeling 'buildings' here, not 'swiss-watches'...
                • B
                  blackcat1313
                  Hi -
                  I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz.
                  When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks!
                  Bill
                  • pbacotP
                    Hi! try this:
                    Error 404 (Not Found)!!1
                    (support.google.com)
                    • B
                      blackcat1313
                      @pbacot said:
                      Hi! try this:
                      Doh - thanks for that, it's all working now!
                      Bill
                      • BraikenridgeB
                        Braikenridge
                        I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
                        kind regards
                          To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-easy-way-8211-rbz-packages
                            Jim
                            I bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
                            Thanks.
                              srknytgn
                              import in cm or mm would be nice, thanks.
                                Jim
                                I agree, and I am working on it.
                                  πŸ’­ Rather than recode any stuff in the 'data-processing' could you have an opening dialog to just ask the user to choose the input 'units'?
                                  Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN.
                                  A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ?
                                  You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point...
                                    Jim
                                    Just updated to v 0.8.0 with a dialog for selecting the import units.
                                      srknytgn
                                      hey jim,
                                      i'm trying to import a dxf file but it comes in scaled to inches.
                                      as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed.
                                      do you think something was wrong?
                                      dxf_import.dxf
                                        1000 'units' read from a DXF file are taken as 1000 inches.
                                        When you 'scale' it 'to mm' the 1000" --> 25400mm NOT the displayed 2540mm ?
                                        BUT looking into your DXF file... the box's edges are actually 100 'units' long! NOT 1000, so therefore it ought to produce 2540mm when 'scaled' as you showed ??
                                        If your DXF says something is 100 'units' long [taken as 100" as SketchUp's base-units are inches] and you tell it to scale it to 'mm' - then logically you will get something 2540mm long [which is 100" !]
                                        If you want to get it to assume the 100 'units' is actually 100mm then the scaling needs to be NOT 'TO mm' but 'FROM mm'.
                                        The scaling factor would then be:
                                        100.mm / 100.inch
                                        which is actually 1/25.4
                                        So 100 'units' --> 100" - which is then rescaled to be the smaller 'mm' dimension of exactly 100mm [100 / 25.4 = ~4" (3.93700787401574803") in base-units ]
                                          srknytgn
                                          I don't understand why should i scale imported drawing. I have nothing to do with inches, want to import like SU Pro. My base SU file always in cm or mm unit and always draw in Autocad unitless.
                                          Finally my su file's unit is cm and I draw a 100 x 100 square in Autocad and I want to see it in SU as 100 x 100 cm. Is it possible with that plugin or not?
                                            This importer always takes the DXF length of 100 as 100".
                                            Jim's latest update is intended to allow you to 'scale' the input to whatever units you desire.
                                            So if you choose "to-mm" then it currently applies a scaling factor to make 100 into 2540mm
                                            My point was that it should take 1/25.4 as the scaling factor 'from-mm' and therefore you'd get 100mm as your result.
                                            I'm sure Jim will address this shortly... πŸ˜•
                                            • 4 / 8
