[Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
Carsten, it works fine for me. Make sure you've got the current version and didn't just move an old version over from an earlier SU version.
Strange, I reloaded the installer from Artisan's site, installed and same error occurs. Win7 X64
Win7 X64 here, too. It works as advertised.
Did you try copying your previously installed version over first? Maybe you need to make sure the Plugins folder is cleared out first. Are you installing it under Users/...AppData/...Plugins?
I've installed a new version from the extension warehouse and this one is working! (Seems that it's different from the one on the artisan4sketchup website.)
PluginStore version updated to 1.2.3 SU2014 compatible
I removed the previously installed artisan_loader.rb and artisan folder. Installed in user/appdata/...etc/plugins (See image)
edit: removed image because now it works thanks to Cotty (see next post).
We can download Artisan from 3Dwarehouse ?
Time to get the eyes tested Pilou...2 mistakes already today
Excellent! So it really was just updating to the current version.
I appreciate everyone's patience as the plugins authors work to fix any remaining kinks with their plugins for SU2014. Although we have done our best to prepare for SU2014, some bugs only become apparent when it gets released to the masses
Artisan 1.2.4 was released yesterday on
http://artisan4sketchup.com/download/This version resolves a loading bug that was apparent if you have non-english characters in your user name.
The version on the Extension Warehouse will be updated as soon as the QA team reviews it.
Dale -
Hey Whaat,
it seems that since SU2014 the undo-capability after a Subdivide and Smooth operation is broken.
Ctrl + Z doesn't work any more. And if it does, its only on individual smoothing steps, rendering it useless.Has anyone else had these problems?
PS: Once again: Thanks for this superb plugin. Every time I modify a terrain, it gives me great joy!
Ctrl+Z working fine here.
@plot-paris said:
Hey Whaat,
Thanks for the report! I will have to do some testing. I also noticed some strange undo behavior on another plugin I am working on. Do you know if this only occurs when you have 'Subsurface Materials' enabled?
can anyone tell me is there anyway to slect edges and vertice and cerease them? ARTISAN PLUGIN, am manually clicking each vertice and edge?
Anything to consider for SU2015?
Download and install a fresh copy. I did and it works just fine.
I bought the original SDS tool few years ago. I use it with my SU8 but since upgrading to SU2015 and installing the original SDS on SU2015 all icons are "green smiley faces" and I have no problem with that because if I point my cursor on one of the icons it tells me what tool it is but I want to upgrade to a new version with new tools.
Q: how do I upgrade to the new version with new tools added?
Q: will I have to pay for upgrade?ok, just went to extension warehouse and downloaded the new version. It says "free to use for 15 days... after a license must be purchased..." I also read it's free upgrade if I have the original one (I do) but with the original one there was no license, so how do I go about the free upgrade??? wi
Problem, so I'm in extension warehouse>Atisan Oganic Toolset>click on download (directs me to same page with install button)>click on install (opens page with terms and conditions of use and sings me out)>checked accept terms and conditions of use>click confirm> and nothing happens.... ???
Ok, got it
but how do I register now (I have the original SDS, no registaration back then) the new Artisan tool?Thanks
One quick question: Artisan subdividing operation is not enclosed in start/commit operation? Each step is logged separately? I am asking this, because when I subdivide geometry and I need to undo it, it seems to have to do a lot of UNDOs, often ending somewhere in mid process of subdivision, having my geometry ruined, like parts missing.
