    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
      design54
      i have a question please;
      can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
      thank you
      waiting your feedback
        thank you
        Obviously you can't 'sell' someone else's creation, but the use of most of the forum's 'free' tools in your 'business' is acceptable, unless there is something specifically in a tool's 'notices' saying you can't... In this case it's 'All Rights Reserved... Free License...' etc but with no other limitations that I can see...
        Having said that it would be nice to offer an author a modest PayPal donation - after all if you are making money from a tool then sharing some of it would only seem fair... "What goes around comes around..."
        Matt666 doesn't have a donation button on the 'SketchUcation Plugin Store', but this doesn't prevent you sending him a Private Message and asking the question... If he declines you are no worse off, if he accepts you might feel better in your heart...
        • atelierpaarA
          atelierpaar
          Hello there,
          I just installed SU 2014,
          After downloading Matts Toggle_Units.rb using the sketchucation download-Manager I get the following Error message:
          Fehler beim Laden der Datei Matt_Toggle_Units.rb
          Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
          Sketchup.register_extension (ext,true)
          Any Idea how to fix this ?
          thank`s for your comments,
          Uli
          • H
            hygicell
            same problem here ! 😢
            could someone please make this wonderful plugin available for sketchup 2014 ?
            thanks
            Frank
            Error Loading File Matt_Toggle_Units.rb
            Error: #<SyntaxError: C:/Users/Frank/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
            • jiminy-billy-bobJ
              jiminy-billy-bob
              You should try to contact Matt by email or something, so that he can fix it.
              In the meantime, open the file
              C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\Matt_Toggle_Units.rb
              in notepad.
              Change the last line from
              to
              Sketchup.register_extension ext, true
              Then it should work fine.
              BTW, even if we can't get in touch with him, we cannot redistribute a fixed version of his plugin, as he states in his files "All Rights Reserved".
              EDIT : It seems he visited the forum on Feb 27, so he should be around somewhere 😉
                Matt666
                Hi all, I edited 1st post with a correction of the bug. Thank you.
                Frenglish at its best !
                My scripts
                • atelierpaarA
                  atelierpaar
                  your right,
                  after changing the last line, everything works fine.
                  thanks for your help jiminy-billy-bob
                  Uli
                    dtrarch
                    Hi all
                    I needed to add extensions.rb to plugins and edit
                    toolbar_manager.html
                    tustrings.en
                    to correct english(engeniery) to Engineering (.en)
                    Now works and spells OK 👎 👎
                    Thank you Matt and what do you play ?
                    dtr
                      dtrarch
                      Error
                      • H
                        hygicell
                        it works ! 😍
                        many, many thanks jimini-billy-bob !
                          Matt666
                          What do I play?
                          My scripts
                          • BoxB
                            I believe he is referring to this
                            @matt666 said:
                            Hi Pete! Thank you for your kind words..
                            i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! 😄
                            But I love programming so I will try to do something for you..
                            I just have to reinstall SU!
                              Matt666
                              Aaaah! ^^ I am a drummer!
                              My scripts
                              • CadFatherC
                                CadFather
                                yeah, we know the types...bad dudes! 😆
                                  There was a single method (arguments) error in the extension 'loader' .rb.
                                  I've corrected it to method(arguments) so it is now v2014 compliant.
                                  I updated it for the PluginStore entry [v3.000]...
                                  http://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
                                  • B
                                    brendanherri
                                    Hello all,
                                    I still have some troubles with this very usefull extension.
                                    It also seems to be related to a UTF8 issue as you can see the error message below.
                                    I have Win7 64bit pro. Any idea ?
                                    Erreur de chargement du fichier C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                    C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in split' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in block in module:Toggle_Units'
                                    C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in each' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in module:Toggle_Units'
                                    C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:5:in <module:Matt_Tools>' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:4:in <top (required)>'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                    C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
                                      driven
                                      The language string files haven't been encoded as UFT8 and have a silly extensions [.en, .fr]...
                                      it would be simpler to use .txt so people can edit their own copies.
                                        Dam' - missed it - I'll look & update asap...
                                          Only the FR file was wrongly encoded as ANSI !
                                          The EN one worked fine...
                                          The plugin's HTML file shows NO encoding at all - which is just weird !
                                          It'll be fixed and an update published shortly...
                                          [mod=:3i457397]Update v3.001 with correctly encoded FR file etc now in the PluginStore.
                                          .[/mod:3i457397]
                                          • B
                                            brendanherri
                                            Works fine !
                                            Thank you TIG, you're great.
                                            Merci beaucoup.
                                            • 7 / 8
