    [Plugin] Toggle Units
    159 Posts 47 Posters 163.5k Views 47 Watching
    • mariochaM
      mariocha
      Hum... in this case, we do not really need the current icon being greyed cause we can see witch is the current unit setting just by looking at the dimensions in the model.
      The main drag is that some do not work. Maybe taking the "greying" part of the code out ? ❓
      update; I deleted the "MF checked-MF unchecked" and "validation" parts and they now all work fine.
      Now If I could find how to disable the greying out of the icons. πŸ˜„
      %(#008000)[Mario C.
        driven
        hay,
        I'm in England, 50% of the population think mm is the Mickey Mouse Club and the rest think a foot is on the end of their leg...
        I work with both
          Matt666
          Hi. I apologize for mac bugs, I have no mac to test plugins... 😠
          Did you see there is an option that lets you choose icons you want to display? You can hide fractional icon if you want.
          Frenglish at its best !
          My scripts
          • E
            element
            Useful plugin.
            • P
              pololo
              Useful plugin!!! Thanks!!
              • P
                Pete
                Matt666, thank you for the very handy plugin. I use this all the time and was wondering if I could make one request...
                Could you add a favorites toggle? What I mean by this is allow the user to set favorite units / precision combinations they could toggle between with one click. In my case I need to toggle CM with 0.0 precision and Inches with 1/16 precision constantly. If I could set these two as favorites and have one button that would switch between only those two I would owe you!!
                  Matt666
                  Hi Pete! Thank you for your kind words..
                  i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! πŸ˜„
                  But I love programming so I will try to do something for you..
                  I just have to reinstall SU!
                  My scripts
                    design54
                    i have a question please;
                    can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
                    thank you
                    waiting your feedback
                      thank you
                      Obviously you can't 'sell' someone else's creation, but the use of most of the forum's 'free' tools in your 'business' is acceptable, unless there is something specifically in a tool's 'notices' saying you can't... In this case it's 'All Rights Reserved... Free License...' etc but with no other limitations that I can see...
                      Having said that it would be nice to offer an author a modest PayPal donation - after all if you are making money from a tool then sharing some of it would only seem fair... "What goes around comes around..."
                      Matt666 doesn't have a donation button on the 'SketchUcation Plugin Store', but this doesn't prevent you sending him a Private Message and asking the question... If he declines you are no worse off, if he accepts you might feel better in your heart...
                      • atelierpaarA
                        atelierpaar
                        Hello there,
                        I just installed SU 2014,
                        After downloading Matts Toggle_Units.rb using the sketchucation download-Manager I get the following Error message:
                        Fehler beim Laden der Datei Matt_Toggle_Units.rb
                        Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                        Sketchup.register_extension (ext,true)
                        Any Idea how to fix this ?
                        thank`s for your comments,
                        Uli
                        • H
                          hygicell
                          same problem here ! 😒
                          could someone please make this wonderful plugin available for sketchup 2014 ?
                          thanks
                          Frank
                          Error Loading File Matt_Toggle_Units.rb
                          Error: #<SyntaxError: C:/Users/Frank/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            You should try to contact Matt by email or something, so that he can fix it.
                            In the meantime, open the file
                            C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\Matt_Toggle_Units.rb
                            in notepad.
                            Change the last line from
                            to
                            Sketchup.register_extension ext, true
                            Then it should work fine.
                            BTW, even if we can't get in touch with him, we cannot redistribute a fixed version of his plugin, as he states in his files "All Rights Reserved".
                            EDIT : It seems he visited the forum on Feb 27, so he should be around somewhere πŸ˜‰
                              Matt666
                              Hi all, I edited 1st post with a correction of the bug. Thank you.
                              My scripts
                              • atelierpaarA
                                atelierpaar
                                your right,
                                after changing the last line, everything works fine.
                                thanks for your help jiminy-billy-bob
                                Uli
                                  dtrarch
                                  Hi all
                                  I needed to add extensions.rb to plugins and edit
                                  toolbar_manager.html
                                  tustrings.en
                                  to correct english(engeniery) to Engineering (.en)
                                  Now works and spells OK πŸ‘Ž πŸ‘Ž
                                  Thank you Matt and what do you play ?
                                  dtr
                                    dtrarch
                                    Error
                                    • H
                                      hygicell
                                      it works ! 😍
                                      many, many thanks jimini-billy-bob !
                                        Matt666
                                        What do I play?
                                        My scripts
                                        • BoxB
                                          I believe he is referring to this
                                            Matt666
                                            Aaaah! ^^ I am a drummer!
                                            My scripts
                                            • 7 / 8
