    [Plugin] Toggle Units
    159 Posts 47 Posters 158.3k Views 47 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      You should try to contact Matt by email or something, so that he can fix it.
      In the meantime, open the file
      C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\Matt_Toggle_Units.rb
      in notepad.
      Change the last line from
      Sketchup.register_extension (ext,true)
      to
      Sketchup.register_extension ext, true
      Then it should work fine.
      BTW, even if we can't get in touch with him, we cannot redistribute a fixed version of his plugin, as he states in his files "All Rights Reserved".
      EDIT : It seems he visited the forum on Feb 27, so he should be around somewhere 😉
        Matt666
        Hi all, I edited 1st post with a correction of the bug. Thank you.
        Frenglish at its best !
        My scripts
        • atelierpaarA Offline
          atelierpaar
          your right,
          after changing the last line, everything works fine.
          thanks for your help jiminy-billy-bob
          Uli
            dtrarch
            Hi all
            I needed to add extensions.rb to plugins and edit
            toolbar_manager.html
            tustrings.en
            to correct english(engeniery) to Engineering (.en)
            Now works and spells OK 👎 👎
            Thank you Matt and what do you play ?
            dtr
              dtrarch
              Error
              • H Offline
                hygicell
                it works ! 😍
                many, many thanks jimini-billy-bob !
                  Matt666
                  What do I play?
                  My scripts
                  • BoxB Offline
                    I believe he is referring to this
                    @matt666 said:
                    Hi Pete! Thank you for your kind words..
                    i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! 😄
                    But I love programming so I will try to do something for you..
                    I just have to reinstall SU!
                      Matt666
                      Aaaah! ^^ I am a drummer!
                      My scripts
                      • CadFatherC Offline
                        CadFather
                        yeah, we know the types...bad dudes! 😆
                          There was a single method (arguments) error in the extension 'loader' .rb.
                          I've corrected it to method(arguments) so it is now v2014 compliant.
                          I updated it for the PluginStore entry [v3.000]...
                          http://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
                            brendanherri
                            Hello all,
                            I still have some troubles with this very usefull extension.
                            It also seems to be related to a UTF8 issue as you can see the error message below.
                            I have Win7 64bit pro. Any idea ?
                            Erreur de chargement du fichier C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                            C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in split' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in block in module:Toggle_Units'
                            C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in each' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in module:Toggle_Units'
                            C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:5:in <module:Matt_Tools>' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:4:in <top (required)>'
                            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                            C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
                              driven
                              The language string files haven't been encoded as UFT8 and have a silly extensions [.en, .fr]...
                              it would be simpler to use .txt so people can edit their own copies.
                                Dam' - missed it - I'll look & update asap...
                                  Only the FR file was wrongly encoded as ANSI !
                                  The EN one worked fine...
                                  The plugin's HTML file shows NO encoding at all - which is just weird !
                                  It'll be fixed and an update published shortly...
                                  [mod=:3i457397]Update v3.001 with correctly encoded FR file etc now in the PluginStore.
                                  .[/mod:3i457397]
                                    brendanherri
                                    Works fine !
                                    Thank you TIG, you're great.
                                    Merci beaucoup.
                                      jimmylomax
                                      First, this extension is incredibly valuable for me. So many thanks for it! When I find things like this I feel stupid [face palm], I didn't seek it earlier... so much time wasted!
                                      2nd on feature request for presets. For example, it would be amazing if I could have/make three:
                                      1. decimal, mm, 0mm precision (sometimes I do my detailed work or reference other models)
                                      2. decimal, in, 0.000" precision (most of the time when I'm doing detail work, this is my preference)
                                      3. architectural, 0" precision (my output presentations are almost always feet and whole inches)
                                        atelierpaar
                                        Hello
                                        I just installed SU 2019
                                        Unfortunately i get the following errocode :
                                        Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                                        Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:205: Invalid return in class/module body
                                        return if not settings.include?("tr...
                                        C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
                                        anyone any idee how to fix this problem ?
                                        thanks for looking into the this
                                        Uli
                                          The newer Ruby version is unsympathetic to coding errors !
                                          Using a plain-text editor, like Notepad++, edit the file:
                                          Find line #205
                                          return if not settings.include?("true")
                                          Add an initial #
                                          #return if not settings.include?("true")
                                          Save the file and restart SketchUp, to test it...
                                          Other 'returns' in the code seem OK...
                                            atelierpaar
                                            Hello and good morning,
                                            thanks TIG, that was it. What a difference a # makes !!
                                            Toggle_Units works fine again.
                                            thanks again for your quick reponse
                                            Uli
                                            • 7 / 8
