    [Plugin] Toggle Units
    159 Posts 47 Posters 141.9k Views 47 Watching
      Matt666
      Hi. I apologize for mac bugs, I have no mac to test plugins... 😠
      Did you see there is an option that lets you choose icons you want to display? You can hide fractional icon if you want.
      Frenglish at its best !
      My scripts
      • E Offline
        element
        Useful plugin.
          pololo
          Useful plugin!!! Thanks!!
            Pete
            Matt666, thank you for the very handy plugin. I use this all the time and was wondering if I could make one request...
            Could you add a favorites toggle? What I mean by this is allow the user to set favorite units / precision combinations they could toggle between with one click. In my case I need to toggle CM with 0.0 precision and Inches with 1/16 precision constantly. If I could set these two as favorites and have one button that would switch between only those two I would owe you!!
              Matt666
              Hi Pete! Thank you for your kind words..
              i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! πŸ˜„
              But I love programming so I will try to do something for you..
              I just have to reinstall SU!
              My scripts
                design54
                i have a question please;
                can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
                thank you
                waiting your feedback
                  thank you
                  Obviously you can't 'sell' someone else's creation, but the use of most of the forum's 'free' tools in your 'business' is acceptable, unless there is something specifically in a tool's 'notices' saying you can't... In this case it's 'All Rights Reserved... Free License...' etc but with no other limitations that I can see...
                  Having said that it would be nice to offer an author a modest PayPal donation - after all if you are making money from a tool then sharing some of it would only seem fair... "What goes around comes around..."
                  Matt666 doesn't have a donation button on the 'SketchUcation Plugin Store', but this doesn't prevent you sending him a Private Message and asking the question... If he declines you are no worse off, if he accepts you might feel better in your heart...
                  • atelierpaarA Offline
                    atelierpaar
                    Hello there,
                    I just installed SU 2014,
                    After downloading Matts Toggle_Units.rb using the sketchucation download-Manager I get the following Error message:
                    Fehler beim Laden der Datei Matt_Toggle_Units.rb
                    Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                    Sketchup.register_extension (ext,true)
                    Any Idea how to fix this ?
                    thank`s for your comments,
                    Uli
                    • H Offline
                      hygicell
                      same problem here ! 😒
                      could someone please make this wonderful plugin available for sketchup 2014 ?
                      thanks
                      Frank
                      Error Loading File Matt_Toggle_Units.rb
                      Error: #<SyntaxError: C:/Users/Frank/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                      • jiminy-billy-bobJ Offline
                        jiminy-billy-bob
                        You should try to contact Matt by email or something, so that he can fix it.
                        In the meantime, open the file
                        C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\Matt_Toggle_Units.rb
                        in notepad.
                        Change the last line from
                        to
                        Sketchup.register_extension ext, true
                        Then it should work fine.
                        BTW, even if we can't get in touch with him, we cannot redistribute a fixed version of his plugin, as he states in his files "All Rights Reserved".
                        EDIT : It seems he visited the forum on Feb 27, so he should be around somewhere πŸ˜‰
                          Matt666
                          Hi all, I edited 1st post with a correction of the bug. Thank you.
                          My scripts
                            atelierpaar
                            your right,
                            after changing the last line, everything works fine.
                            thanks for your help jiminy-billy-bob
                            Uli
                              dtrarch
                              Hi all
                              I needed to add extensions.rb to plugins and edit
                              toolbar_manager.html
                              tustrings.en
                              to correct english(engeniery) to Engineering (.en)
                              Now works and spells OK πŸ‘Ž πŸ‘Ž
                              Thank you Matt and what do you play ?
                              dtr
                                dtrarch
                                Error
                                • H Offline
                                  hygicell
                                  it works ! 😍
                                  many, many thanks jimini-billy-bob !
                                    Matt666
                                    What do I play?
                                    My scripts
                                    • BoxB Offline
                                      I believe he is referring to this
                                        Matt666
                                        Aaaah! ^^ I am a drummer!
                                        My scripts
                                        • CadFatherC Offline
                                          CadFather
                                          yeah, we know the types...bad dudes! πŸ˜†
                                            There was a single method (arguments) error in the extension 'loader' .rb.
                                            I've corrected it to method(arguments) so it is now v2014 compliant.
                                            I updated it for the PluginStore entry [v3.000]...
                                            http://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
                                            • 7 / 8
