    [Plugin] Toggle Units
    159 Posts 47 Posters 151.3k Views 47 Watching
      driven
      hay,
      I'm in England, 50% of the population think mm is the Mickey Mouse Club and the rest think a foot is on the end of their leg...
      I work with both
        Matt666
        Hi. I apologize for mac bugs, I have no mac to test plugins... 😠
        Did you see there is an option that lets you choose icons you want to display? You can hide fractional icon if you want.
        Frenglish at its best !
        My scripts
        • E Offline
          element
          Useful plugin.
            pololo
            Useful plugin!!! Thanks!!
              Pete
              Matt666, thank you for the very handy plugin. I use this all the time and was wondering if I could make one request...
              Could you add a favorites toggle? What I mean by this is allow the user to set favorite units / precision combinations they could toggle between with one click. In my case I need to toggle CM with 0.0 precision and Inches with 1/16 precision constantly. If I could set these two as favorites and have one button that would switch between only those two I would owe you!!
                Matt666
                Hi Pete! Thank you for your kind words..
                i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! πŸ˜„
                But I love programming so I will try to do something for you..
                I just have to reinstall SU!
                My scripts
                  design54
                  i have a question please;
                  can i use the plugin toggle units in commercial use; i mean i will not sell it, i want to use it in my design, i am interior designer and i use sketchup pro 8, to designs designs for clients so is it allowed to me to use it or no?
                  thank you
                  waiting your feedback
                  • TIGT Online
                    thank you
                    Obviously you can't 'sell' someone else's creation, but the use of most of the forum's 'free' tools in your 'business' is acceptable, unless there is something specifically in a tool's 'notices' saying you can't... In this case it's 'All Rights Reserved... Free License...' etc but with no other limitations that I can see...
                    Having said that it would be nice to offer an author a modest PayPal donation - after all if you are making money from a tool then sharing some of it would only seem fair... "What goes around comes around..."
                    Matt666 doesn't have a donation button on the 'SketchUcation Plugin Store', but this doesn't prevent you sending him a Private Message and asking the question... If he declines you are no worse off, if he accepts you might feel better in your heart...
                    • atelierpaarA Offline
                      atelierpaar
                      Hello there,
                      I just installed SU 2014,
                      After downloading Matts Toggle_Units.rb using the sketchucation download-Manager I get the following Error message:
                      Fehler beim Laden der Datei Matt_Toggle_Units.rb
                      Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                      Sketchup.register_extension (ext,true)
                      Any Idea how to fix this ?
                      thank`s for your comments,
                      Uli
                      • H Offline
                        hygicell
                        same problem here ! 😒
                        could someone please make this wonderful plugin available for sketchup 2014 ?
                        thanks
                        Frank
                        Error Loading File Matt_Toggle_Units.rb
                        Error: #<SyntaxError: C:/Users/Frank/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62: syntax error, unexpected ',', expecting ')'
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          You should try to contact Matt by email or something, so that he can fix it.
                          In the meantime, open the file
                          C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\Matt_Toggle_Units.rb
                          in notepad.
                          Change the last line from
                          to
                          Sketchup.register_extension ext, true
                          Then it should work fine.
                          BTW, even if we can't get in touch with him, we cannot redistribute a fixed version of his plugin, as he states in his files "All Rights Reserved".
                          EDIT : It seems he visited the forum on Feb 27, so he should be around somewhere πŸ˜‰
                            Matt666
                            Hi all, I edited 1st post with a correction of the bug. Thank you.
                            My scripts
                              atelierpaar
                              your right,
                              after changing the last line, everything works fine.
                              thanks for your help jiminy-billy-bob
                              Uli
                                dtrarch
                                Hi all
                                I needed to add extensions.rb to plugins and edit
                                toolbar_manager.html
                                tustrings.en
                                to correct english(engeniery) to Engineering (.en)
                                Now works and spells OK πŸ‘Ž πŸ‘Ž
                                Thank you Matt and what do you play ?
                                dtr
                                  dtrarch
                                  Error
                                  • H Offline
                                    hygicell
                                    it works ! 😍
                                    many, many thanks jimini-billy-bob !
                                      Matt666
                                      What do I play?
                                      My scripts
                                      • BoxB Offline
                                        I believe he is referring to this
                                          Matt666
                                          Aaaah! ^^ I am a drummer!
                                          My scripts
                                          • CadFatherC Offline
                                            CadFather
                                            yeah, we know the types...bad dudes! πŸ˜†
                                            • 7 / 8
