    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 433.5k Views 92 Watching
    • BoxB Offline
      It works if you use a 10 sided circle rather than a polygon.
      • cottyC Offline
        cotty
        @rich o brien said:
        Did you try Shift + Blue scale?
        Yes, it's the same.
        Same behaviour for polygon, circle, exploded edges, ...
        I think the reason is the not centered position of the gizmo (with every second vertex selected):
        my SketchUp gallery
          Yes, that's because the center of the five selected vertices isn't the center of the polygon.
          You can right-click the Gizmo > Gizmo > Align Custom and then set the position of the gizmo. Note that it works like the Align Axis tool, so you must pick center point and then the X and Y axes.
          You can then scale and get your start. Note that after scaling the gizmo re-centers itself.
          • panixiaP Online
            panixia
            align gizmo to custom πŸ˜‰
            edit: didn't see page 13 of this post 😳
            πŸ˜†
            • xiombargX Offline
              xiombarg
              I know Vertex Tools has been around for a little while but I only recently downloaded the trial version and I just have to say that this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques. I only wish I had noticed it before. I was especially STOKED with the scale tool implementation that not only aligns vertices to a single axis, but that we can finally get rid of artifact lines by scaling a plane to absolute zero. Ya-freakin-hoo, it's about time.
              Also love the extrude edge and merge vertex options. Beautiful man.
                HAppy you like it! πŸ˜„
                  @xiombarg said:
                  ...this plugin finally fills in such a huge hole that Sketchup has been missing in advanced modelling tools and techniques....
                  nice testimonial/endorsement πŸ‘
                  • BoxB Offline
                    I was just trolling through the thread and noticed a number of times you asked for action shots of the tool in use. Here's a quick doodle I did the other day for fun.
                    Fantastic tool, couldn't live without it.
                    • pbacotP Offline
                      Very nice work Box! And a great subject for VT capabilities. Did you subd as well? Other tools?
                        KrisM
                        My question is certainly not as interesting as the above post but here goes -
                        I have need on occasion to introduce a flat area into a terrain. I can move individual vertices but this can sometimes be a lot of work. The planar tool makes a flat surface but not a horizontal surface. What I want to do is select a number of vertices and set them all to the same z elevation. The stamp tool does this somewhat but introduces a bunch of new vertices to do this (unless you create a very exact stamp surface). This option seems like this might be fairly straightforward to incorporate. Any possibilities with this request? Or perhaps there is already a tool around which does what I want. I've looked but haven't found it.
                        Kris
                        • BoxB Offline
                          Pbacot I used a few tools, but mostly VT. A tiny bit of Artisan for sub and smooth mainly because the button is right there. And a bit of poly reduce to keep things under control.
                          But generally speaking I usually make a blob using either curviloft or Extude tools, this way you can control the structure of vertex' quite well. Then I just use the gizmo to push pull and scale until it looks like what I want. I'm pretty haphazard and free form with it, wouldn't want to have to copy anything this way.
                          The image shows how I would start, first with a block cut to rough shape then those edges used to create quadfaced forms that I explode and join then start to work with.
                          • BoxB Offline
                            Krism, do you have Artisan, another wonderful tool.
                            It has a make planer tool that you can specify, Best, XY, YZ or XZ.
                              KrisM
                              Box, Thanks for that. Yes, I do have Artisan but have not sufficiently explored it's options. I will do that now.
                              Kris
                                tspco
                                I just started using the trial, not sure if I am doing something right. I grab terrains from the file>geolocation, mainly because they look much better than anything I can create.
                                What I need to do is take an area and make it flat for placing buildings on. I tried make planer on a rectangle of vertices, I an not sure it did what I thought it should do, am I misunderstanding the tool?
                                SU make 2017, /Twilight Render Hobby
                                Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                  KrisM
                                  Tspco,
                                  I have had the same problem (see question above). Vertex tools will make selection of vertices planar (they are in line on the same plane). This does not mean that the plane is level. Box mentioned the use of Artisan. This works as desired. Vertex tools is great for a lot of things. It just doesn't do this specific task.
                                  Kris
                                    To flatten something to a given axis you can use the scale grip in the Gizmo. Scale it all the way to zero in the Z axis and you will have a level surface.
                                    I used the development version of the next Vertex Tools in that video - I don't recall if version 1.1 will stop at the zero point - but if that's the case you can adjust it with the VCB afterwards.
                                      KrisM
                                      Thomas,
                                      Thanks for the clarification. Sorry about my statement above being incorrect. Great tool.
                                      Kris
                                      • pbacotP Offline
                                        Thanks for asking the question. I don't think I've tried that way to flatten before. This tool (and others like Curviloft and Artisan) just about need a whole "for Dummies" book on their own. Imagine the book we'll need to use the bezier surface tool when it comes...
                                          Don't be shy to ask about workflow questions. Gives me insight to what can be improved and what would use useful improvements to the documentation, FAQ and/or video examples.
                                          Certainly bezier surface is much more complex... and creating documentation for it is something I dread... πŸ˜•
                                          • xiombargX Offline
                                            xiombarg
                                            But the scaling in Vertex Tools works in conjunction with the axis tool so that you can specify any angle or plane in your model and have it flatten to that angle. Artisan's Make Planar only works with the default x,y,z planes and ignores the axis tool, even if you change the world axis outside of any local groupings it still references the original default x,y,z planes. I also generally prefer lasso selection tools vs brush selection tools, especially when aligning single rows of vertices to build clean geometry or frameworks for lofting with plugins such as Curviloft.
                                            If you consider that Artisan video with the lightcycle, think how much more quick and efficient it would have been to also use Vertex Tools to properly move, align, merge etc. some of those problematic areas in the geometry where he kept having to rework.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
